#27 |
Ride: 88 Honda Civic HB
I wish I still had the axles and knuckles to compare. Sounds very off to me; I've had 2 sets of 88 CRX DX kncukles and a set of 88 Std knuckles laying side by side. I just threw them all away like a month ago though.
Price would depend. You can probably get DX/Si knuckles for like $50 from the junkyard or some third party. Then you'd need axles; which is $20-$130 depending on who you get them from($130 is for pair at Advance or something with a core).
1988 Honda Civic STD-more mods than I want to list Terrorists have successfully attacked our imagination. RIP Jon Eban Nie, August 31, 1991 - May 7, 2006 Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006 |
#30 |
Well even if he did, then the axles would've fit! lol. Maybe you had upgraded knuckles, and the parts dealer sold you Std axles(which I'm sure is very possible, especially at Advance Auto or Auto Zone)?
#31 |
HS TECH
Ride: dc5,mk4 gti,2nd gen civic,
yea thats what i mean the kid before me could have got the dx hubs and put them on there i guess.
but wait i remember i went to the next part store and they had std axles and it fit fine so were back where we started std= bigger lol |
#32 |
That would mean they're bigger than B-series/DA axle ends!
#33 |
Banned
Ride: 89 Civic Hatch
is this a good page of how to dpfi to mpfi? D2G Automotive Articles 88-91 Civic - DPFI to MPFI Conversion
#34 |
Banned
and everybody says i need a Si intake manifold?? can i just use the one on my 93 civic motor aren't they the same just about?
and a A6 dizzy? is this a si dizzy or what? |
#35 |
My name is Byron.
Ride: `89 DX Hatch w/JDM B16
Yes you will need the Si dizzy and Si IM.
Dont PM me with tech questions. I will not answer them. Looking for a P28 and B-series turbo parts, PM me. |
#37 |
My name is Byron.
The 93 intake is OBDI, your car is OBD0, so to keep things simple youll need the 88-91 Si mani.
#39 |
My name is Byron.
An OBD conversion.
#40 |
Banned
This site right here show me how to wire up my stock ecu. and if i wanted to do this I'd have to buy a Si intake and injector resistor box and thats it correct???
D2G Automotive Articles 88-91 Civic - DPFI to MPFI Conversion |
#41 | |
My name is Byron.
OBD0 Si intake manifold. OBD0 Si dizzy. PM6 ECU. Injector resistor box.
#42 | |
Banned
Sorry about all the questions bro, But I'm just lost to as why the hell do i need a Si Manfold when mine is the same thing. and also why do i need a PM6 ECU ? |
#43 |
Banned
I dont know maybe I'm just to dam dumb to understand it but to me i dont get why i cant just switch the 2 wires on the ecu for the TPS sensor and move on to adding the 4 extra wires need to run the injectors and run them to the injector resistor box. and fire it up.
I think it says in their you need a Si manifold to do a dpfi to mpfi swap but if i already got a entire motor with a manifold that already has 4 injectors that should be the same thing dont you think? and the stock dizzy and stock ecu should work by just changing those few wires that this site show you to do D2G Automotive Articles 88-91 Civic - DPFI to MPFI Conversion shouldn't it? |
#44 |
My name is Byron.
Like I said you will have to do an OBD conversion to make the 93 intake work. And you need the PM6 because it is the Si computer. Your stock ECU wont work its for the dual point motor. The multi points have two more injectors and a cylinder position sensor in the dizzy, the dual points dont. So to make the conversion work you will need all the stuff the Si has that the DX/STD doesnt. Your making your car into an Si, so you need all the parts that make an Si an Si. Do you understand what Im getting at here?
#45 | |
HS TECH
#46 |
You can use a 93 intake manifold; you do not need a Si one. Only difference is the MAP mounting. The 93 has it on the throttle body, while the Si is external. Luckily, the plugs are the same so it does not matter. No OBD conversion needed. Only "OBD" conversion part would be is if you used an OBD1 distributor.
#47 |
