passenger cv axle will not go into the Hub???
Old 08-11-2008, 03:34 AM   #51
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 89 K2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud of
Send a message via AIM to K2e2vin
He will not need OBD0 injectors or resistor box if the injector plugs fit or he swaps the plug connectors over to work with the OBD1 injectors.
OBD0 Injectors are like 2-3ohms with ~10ohm resistor= ~13ohms
OBD1 Injectors= ~13-15ohms.
OBD0 injectors or any low-impedance injectors without a resistor box=fried ECU.
1988 Honda Civic STD-more mods than I want to list
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 08-11-2008, 03:35 AM   #52
Banned
Ride:  89 Civic Hatch
Rep Power: 0 TravisCadello is infamous around these partsTravisCadello is infamous around these partsTravisCadello is infamous around these parts
myspace
Originally Posted by efhondakid View Post
After I got to thinking, that is really the only difference. He will still need the OBD0 injectors and resistor box though.
the injectors on the motor now are obd1 right??? whats the difference don't they have the same connection?
TravisCadello is offline   Reply With Quote
Old 08-11-2008, 03:37 AM   #53
K2e2vin's Avatar
If the connectors are the same(I do not know because I never checked); then run the D15B7 injectors. Also, when you wire up the DPFI/MPFI conversion, you could go ahead and use the OBD1 injector plugs.
Difference is the impedance. The OBD0 injectors need the resistor box because they're peak and hold/low impedance types. The OBD1 injectors are saturated/high impedance and do not need the resistor box.
RIP
Old 08-11-2008, 03:37 AM   #54
My name is Byron.
efhondakid's Avatar
Ride:  `89 DX Hatch w/JDM B16
Rep Power: 107 efhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
Its late, I cant think, Ill let someone else handle it. Ive hopefully at least helped you understand the concept of the conversion.
Looking for a P28 and B-series turbo parts, PM me.
Old 08-11-2008, 03:40 AM   #55
Banned
myspace
Yes, and I appreciate that a LOT !
Old 08-11-2008, 03:41 AM   #56
Banned
myspace
So, I don't need a injector resistor box on the injectors on the 93 motor?
Old 08-11-2008, 03:42 AM   #57
K2e2vin's Avatar
Nope.
RIP
Old 08-11-2008, 03:44 AM   #58
Banned
myspace
So, how would i do the dpfi to mpfi swap? because the site im going by has the whole dpfi to mpfi wiring from the ecu to the injector box and from the injector box to the injectors.
D2G Automotive Articles 88-91 Civic - DPFI to MPFI Conversion
Old 08-11-2008, 03:48 AM   #59
K2e2vin's Avatar
This one will help you a little better(has pictures and IMO more complete):
FourthGenHatch
RIP
Old 08-11-2008, 03:55 AM   #60
My name is Byron.
efhondakid's Avatar
FourthGenHatch
I used the same write-up when I did my dp to mp conversion.
Old 08-11-2008, 04:00 AM   #61
Banned
myspace
How did you do yours?
Old 08-11-2008, 04:01 AM   #62
Banned
myspace
should i go ahead and just get a injector resistor box from the junk yard since every write up i see they use one?
Old 08-11-2008, 04:02 AM   #63
K2e2vin's Avatar
If you're using the OBD1 injectors, no. All it'll do is make the OBD1 injectors response sluggish. In most of the DPFI/MPFI write-up; they're using parts sourced from a 88-91 HF/Si, hence why they're using the resistor box.
RIP
Old 08-11-2008, 04:08 AM   #64
Banned
myspace
my motor came with a wiring harness. i just thought about this and it has i think maybe 3 big connections and thats it. the regular obd0 connection just connect to them or how does this work?
Old 08-11-2008, 04:13 AM   #65
Banned
myspace
Well, hopefully the next day i get off, I'm gonna go over their and try and fix that cv axle somehow get it to go into the splines or just buy a new one. and after that all the machanical work is done completely. and I'll have it towed over here to my house and ill see what i can do myself with the electrical. and I'll let yall know whats going on from their. Thanks a Lot for all the help guys yall really helped me understand most of it and im not lost near as much as i was! lol ill let yall know if i have any more problems ! Thanks !
Old 08-11-2008, 04:26 AM   #66
K2e2vin's Avatar
Originally Posted by TravisCadello View Post
and if i swapped them would the Si axles fit my D- series tranny?
It'd use an OBD0 harness. Much easier.
If you were to try to use the grey OBD1 connectors, you'd need to repin the connectors or retrofit in a OBD1 main harness(huge pain in the ass).
RIP
Forum Jump
End of ED6 axle mated to 90-93 Integra axle shaft? integrawow HYBRID -> ED-EF / DA 1 06-22-2007 12:47 PM
NTB: driver and passenger side axle for '90 teg Swaps Parts: For Sale/Trade/Wanted 0 01-30-2007 08:43 AM
WTB Civic passenger side axle 92CHB Parts: For Sale/Trade/Wanted 5 10-31-2005 07:54 AM
a D axle is a D axle, correct? seanjuan General Tech and Maintenance 4 10-04-2005 01:34 PM
WTB: p08ecu and Dseries passenger side axle crazkene13 Parts: For Sale/Trade/Wanted 0 08-17-2004 07:36 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
