question on a 90 swap crx
Old 10-14-2006, 01:07 AM   #1
Rep Power: 0 reasonlost is on a distinguished road
Default question on a 90 swap crx
hey what up guys ok straight to the point this is whats going on dudes:
first i'll tell u what i did to the car
1990 crx dpfi automatic
swapped to d16z6 enine block with a y8 head sohc vtec
now i have done the auto to manual swap already and also the dpfi to mpfi conversion i used an obd0 si distribuitor and pr4 obd0 integra ecu everithing plugged in with the appropiate wiring conversions well the thing is that when its time to turn it on it wont
it sounds like it'll go but i get no spark or gas
and when i turn the key to the on possition the ecu blinks but turns right off
what do you guys think it is ?????
am i fucking up somewhere in the process??
help
thanks
90 rex d16y8
reasonlost is offline   Reply With Quote
Old 10-14-2006, 01:23 AM   #2
HS TECH
AHHVTEC's Avatar
Ride:  dc5,mk4 gti,2nd gen civic,
Rep Power: 164 AHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
you should use the ecu thats propper for the head your using obd2 and it also sounds like your main relay has gone bad so check that first
Old 10-16-2006, 04:43 PM   #3
Rep Power: 0 90_crx_si is on a distinguished road
like he said switch out ur ecu becuz it's obd2 even my crx ecu does that to me to0 and check if ur gas pump is pumping gas or check your throttle sensor.
90_crx_si is offline   Reply With Quote
Forum Jump
B16 Auto Swap Question 1995EGGuy HYBRID -> EG-EK / DC 8 08-13-2006 11:35 PM
EG LS swap exhaust Question MrYang HYBRID -> EG-EK / DC 0 07-19-2006 02:17 AM
B16B Swap Question punhatch HYBRID -> EG-EK / DC 6 05-12-2006 09:25 PM
swap question Blackhatch94 HYBRID -> EG-EK / DC 1 11-13-2003 01:21 AM
Another 95cx Swap Question - From A Dad score00 HYBRID -> EG-EK / DC 5 02-28-2003 04:46 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
