Ride: 1988 Civic LX>> D16Z6
I have a D16Z6 in a 88 lx. I did not do the swap.
Im not sure if the person who did the swap used the stock tranny or if they used a si tranny. So my question is how would I be able to tell if it is the Lx tranny or a Si tranny? |
2 SLOW CREW
Ride: 88 Hatch and a harley
I'd get under the tranny and look for some number on it then research the number u find....prolly ur best bet!
2 Slow Crew Racing 88 Civic Hatch- TURBO H22 swap
#5 | |
I need some ligaments!!!
Location: laurel, montucky (ten minutes out of billings)
Ride: 89 crx hf, turbo'd 95 del sol si, 87 shaggin wagon(astro)
you should be able to tell by the feel of the tranny. there is a large drop in rpm between 1st nad 2nd if you have the lx trans. i found that reikoshea has a sticky on this. you should go check that out when you find the numbers on your trans. it tells you the gear ratios of the trannies and what models they come in. i'll try to pull up the link.
Honda Transmission specs that should take you there. __________________
car + vinyl = big hp!!! ![]() wipe your mouth, there's still a tiny bit of bullshit around your lips Quote:
( 0.o ) ( > < ) The bunny will rule teh world! Bwahahahaha!!!! Last edited by turbo sol; 11-29-2006 at 02:32 PM. |
| Trans. help please | tcdraco | HYBRID -> EG-EK / DC | 1 | 05-09-2006 11:34 PM |
| HYDRO TRANS INTO CRX | gettocrx | HYBRID -> ED-EF / DA | 5 | 03-16-2006 09:30 PM |
| si trans v/s dx trans | pdqcrx | HYBRID -> ED-EF / DA | 2 | 03-09-2006 09:54 PM |
| trans swap in rex | 88rex | HYBRID -> ED-EF / DA | 8 | 02-08-2005 12:06 PM |
| Leak from a new trans?? | 4DRonDUBS | General Tech and Maintenance | 5 | 03-25-2004 02:13 PM |
