radiator fan
Old 11-29-2007, 12:15 AM   #1
Rep Power: 6 Speed Box is on a distinguished road
Default radiator fan
ok new swap same motor Si to Si.
For some reason my radiator fan does not turn on . Maybe because car did not run long enough, maybe.
On the back of the block its the 2 pins that stick out next to each other above the oil filter right?
How long does the motor have to run for the fan to turn on?
Speed Box is offline   Reply With Quote
Old 11-29-2007, 12:18 AM   #2
Honda Master Technician
norcalgsr's Avatar
Ride:  88 Prelude Si and a CBR 600 Hurricane
Rep Power: 21 norcalgsr is a jewel in the roughnorcalgsr is a jewel in the roughnorcalgsr is a jewel in the rough
myspace
It's based on temperature.. just hold your engine around 2-3k rpm until it either kicks the fans on or your temp starts rising above normal. Another option would be to swap the fan switch from your old engine onto the new engine since it looks like that one was working properly.
Do not PM with tech questions without providing a link to your topic on the forums. This way everyone has access to the information..
norcalgsr is offline   Reply With Quote
Old 11-30-2007, 12:07 AM   #3
Bro, does anybody know what size is that bolt???????
I don't have a wrench or deep socket to get it.
Honda dealer told me its 24mm , well 24mm can't even get it around the sensor let alone the bolt.
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
