Radiator fan won't turn on
Old 09-11-2008, 08:09 PM   #1
Rep Power: 4 vg_Ace is on a distinguished road
Default Radiator fan won't turn on
So while I am driving around town I never hear the radiator fan turn on.My car doesn't overheat, and it drives just fine, but I never hear or see the radiator fan turn on. How do i diagnose this? Should I just buy another fan motor and put it in and see if it works? Is it really bad for the radiator fan to never come on?
vg_Ace is offline   Reply With Quote
Old 09-11-2008, 10:45 PM   #2
Rep Power: 0 avelinolee is on a distinguished road
just run a toggle switch
avelinolee is offline   Reply With Quote
Old 09-12-2008, 12:29 AM   #3
AHHVTEC's Avatar
its only suppose to come on when it needs to if the car never gets hot enough to turn the fan on then dont worry about it
Old 09-12-2008, 12:57 AM   #4
really? so it is not damaging anything? isn't there a way to just test it? whats a toggle switch?
Old 09-12-2008, 01:06 AM   #5
AHHVTEC's Avatar
as long as its not over heating your fine, but un plug the fan and run a wire from the battery to it and see if it cuts on
Old 09-12-2008, 01:55 AM   #6
So wait unplug the fan motor and run a wire directly to the plug? What do I touch the wire to? I mean it should automatically come on right? if not i know i have a bad fan motor.
Old 09-12-2008, 02:33 AM   #7
I'll be back...
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 91 Civic DX
Rep Power: 156 B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
run one wire to the positive terminal on the battery and the other wire to a ground or the negative terminal on the battery. Don't worry about mixing the wires because if you get them mixed up the fan will just spin the opposite way. If it doesn't turn on when you touch the wires to the battery, your fan is toast...
Real Eyes Realize Real Lies
B16RacerN2NR is online now   Reply With Quote
Old 09-15-2008, 06:28 PM   #8
Rep Power: 13 Periculum is off the scale
It was several months of pizza delivery before I finally heard the fan turn on. It doesn't happen often and it's usually just for a minute or two. I hope your fan isn't toast, but if it is, there are many hondas that have the same fan as the EF.
91 CRX HF-ZC motor and tranny swapped
-This is what the HF should have been, just a low redline.....
"My Car should Qualify as an ULEV.
An Ultra Low Expectations Vehicle" -no more that motor is outta here!
Periculum is offline   Reply With Quote
Old 09-15-2008, 09:14 PM   #9
yeah i tested it and it came on strong. I guess the motor just doesn't get hot enough for it ever to come on. Thanks for all the help everyone.
Old 09-16-2008, 12:11 PM   #10
Beer its whats for dinner
4U2H8ME's Avatar
Ride:  91 Accord LX coupe, Jdm H22a with LSD trans.
Rep Power: 6 4U2H8ME has a spectacular aura about4U2H8ME has a spectacular aura about
Have you tried changing the temp sensor on thermostat housing, that sensor signals the fans to turn on and off.
4U2H8ME is offline   Reply With Quote
Old 02-23-2009, 11:58 AM   #11
Greenhorn
Ride:  1997 Acura Integra Ls
Rep Power: 0 Sharwood2009 is on a distinguished road
Default Acura Integra Radiator Fan Will Not Turn On
So I've tried everything on this forum on how to get my fan to switch on.
1 I switched the Coolant Tempurature Switch at the same time while I was down there i switched out hte thermostat " which was alittle worn down but fine ". reinstalled all the hoses added coolant and ran the car to operation tempurature. still no dice the car gets up to operating temperator but still the fan does not kick in. i checked the realys the fuses everything was fine i even put a wire into the relay end to end and the fans kicked fine when i added power at the sensor the fans started fine. so now i was lost about why this could happen.
2 this last weekend i switched out my timing belt at the same time i replaced the water pump where i was reading on this forum that could have been a problem but it still was not the fan does not turn on when it gets to operating temperature.
still my car is getting to operating temperature the fan does not turn on and the car is starting to smell like there is coolant burning. i have looked below my car and there is alittle fluid around the overflow / lower rad hose area - so i am going to switch my lower rad hose out to see if that will fix the problem, the rad is brand new replaced in the summer - i was driving to work a few weeks ago and the upper rad hose blew a whole which was a quick fix but a major piss off at 7am but still the fan does not kick.
so ive tested everyhting else on these forums and was going to wire in a fan switch but i dont want to make the engine to cold and it will eventually go into cold loop and will effect my fuel injection and i dont want ot waste gas. so i think my problem may be alot worse and it could be a possible air lock - head gasket issue but i will try anything that may sound like a fix. but i also may go the route in just getting a new engine rather than doing a rebuild... thoughts
Sharwood
Sharwood2009 is offline   Reply With Quote
Old 02-23-2009, 01:52 PM   #12
Green on the scene.
MthaFuknGreen's Avatar
Ride:  Fuckin Prelude Si 2.1l 1990
Rep Power: 70 MthaFuknGreen has a brilliant future
Send a message via AIM to MthaFuknGreen myspace
why do you think you have a problem?
maybe your car just isnt getting hot..
i see that you live in vancouver, its pretty cold up there.
ambient temperature plays a big role in the temp of your engine.
fuckin mustangs..
Originally Posted by kdizzyvtec View Post
ill do that then dick
Go Green
^go listen.
its me.
MthaFuknGreen is offline   Reply With Quote
Old 02-23-2009, 05:34 PM   #13
dude you have a fan switch already installed on your engine. It senses the temp and turns on or off depending on how hot it is. I switched mine out with a good one and it still never comes on. I would replace the fan switch and call it good. Just look at your temp gauge on your gauge cluster. If it goes too high then you have a problem, if not do not worry about it.
What to do when you turn 18. 90_EF_Hatch Members' Lounge 55 04-19-2008 11:54 PM
When i turn left....... mmmcarl Civic and del Sol - EG and EK 4 05-07-2007 05:46 PM
Let's turn this around Silverchild79 Members' Lounge 11 03-29-2006 05:17 PM
my turn TurboMirage Members' Lounge 34 11-09-2004 02:44 PM
my turn 2000Si Auto Multi-Media 20 04-18-2004 04:53 PM
