rebuilding for boost
Old 03-23-2008, 01:17 PM   #1
8ballsin's Avatar
Ride:  1990 Honda CRX Si
Rep Power: 3 8ballsin is on a distinguished road
myspace
Default rebuilding for boost
first of all i have a D16A6 completely tore apart i am going to rebuild it and i want to boost it i have never done anything like this before so i nned some help what are the things i should change i am assuming cam, pistions, valves but i dont know what would be the better brands i am looking to spend about $1000 on parts i am doing all the work myself
8ballsin is offline   Reply With Quote
Old 03-23-2008, 04:19 PM   #2
żUnKnOwN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 98 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
what are your power goals???
your not going to get far with 1g...
in any rebuild you need all new bearings,seals,gaskets,hardware(bol ts,nuts,washers)
then a hone,and its good idea to have the block checked for problems
http://hondaswap.com/auto-multi-medi...st1144603.html <my CRX
R.I.P BEN LEE2/24/08 we love and miss you
R.I.P Rex 8/18/08 coolest dog ever!!!
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
INJEN78 is online now   Reply With Quote
Old 03-23-2008, 05:20 PM   #3
8ballsin's Avatar
myspace
the block is fine it only had a blown head gasket that i done im in germany so its kinda hard to get shit done for cheap so im doing all the work myself in the auto shop here on the army post the block has been cleaned and the only thing is the head i have to choices i can rebuild my head or i can put on the vtec head i have one here the reason i havent swapped them yet was because ive heard that when you boost a vtec it fucks shit up but didnt know for sure
Old 03-23-2008, 06:45 PM   #4
Crusher of Noob Ambitions
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 145 BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
You heard wrong. It's fine to boost on a VTEC engine. You just need to make sure it's tuned well, but that should be a necessity for any turbo build anyway...
If you find something I say helpful, please rep it up!
97 Integra LS Coupe:
*AEM Intake/Megan Header/Magnaflow Exhaust
*Tokico Shocks & Springs
*Megan Strut Braces & H-Brace
*98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys)
Old 03-23-2008, 06:57 PM   #5
żUnKnOwN?
INJEN78's Avatar
Ride:  91 CRX si
ok so power goals??
GOOD FAST CHEAP,
Old 03-24-2008, 03:06 AM   #6
8ballsin's Avatar
myspace
250-300 whp
Old 03-24-2008, 04:02 AM   #7
Got V-tec?
monotech909's Avatar
Ride:  Whip!
Rep Power: 3 monotech909 is on a distinguished road
Sleeve the block and then take it from there.
Eagle rods are good for its price.
Arias turbo pistons are definately a good choice.
If you plan on building it for that much Hp you will need to spend top dollar and that way you can make good boost. $1,000 is nothing for trying to gain that much horse power. Thats just enough to get you some pistons and rods.
monotech909 is offline   Reply With Quote
Old 03-24-2008, 06:10 AM   #8
The Kicker of Elves.
Blanco's Avatar
Rep Power: 222 Blanco has a reputation beyond reputeBlanco has a reputation beyond repute
Blanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond repute
You can get a set of Tuner Toys rods and Vitara pistons for around $500 and all of the new gaskets, seals, and bearings
You don't need to touch the valves unless they're bent, burned up, or otherwise not seating properly. You can find out if they're seating properly by shining a flash light into the ports while the valves are closed, if you can see light they aren't sealing fully.
You don't need an aftermarket cam, but you'll make the power easier with one. You'll want a turbo grind instead of a all-motor grind.
Don't misinterpret what I say.
Originally Posted by The Secrets of Body Language
93% of communication is done through body language.
Originally Posted by http://humanresources.about.com/od/interpersonalcommunicatio1/a/nonverbal_com.htm
One study at UCLA indicated that up to 93 percent of communication effectiveness is determined by nonverbal cues. Another study indicated that the impact of a performance was determined 7 percent by the words used, 38 percent by voice quality, and 55 percent by the nonverbal communication.
Originally Posted by Shawn Pelton
It's not good to be a drummer unless you got some bad motherfucker up inside you.
Blanco is offline   Reply With Quote
Old 03-24-2008, 06:24 AM   #9
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 40 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
Good information Scott, but your method of checking the seats isnt exactly sufficient enough. When the engine is under load is when the seats take the beating. A cylinder leakage test would be the correct method. Although your method will work IF they are severely unseated.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 03-24-2008, 10:29 AM   #10
żUnKnOwN?
INJEN78's Avatar
Ride:  91 CRX si
250-300 whp
honestly i dont think your goals are realistic with the budget...
you will need a good tune,all the new parts def new rods,because stock is guaranteed up to 200hp
GOOD FAST CHEAP,
Old 03-24-2008, 04:15 PM   #11
Ride:  89 honda crx si and 94 chevy s10 dropped
Rep Power: 6 sevenhillsbilly will become famous soon enough
i am doing the same build and if you are going to keep your budget to 1000 u wont do it
and the vtec head is a great idea because it adds like 20 to 30 hp automaticly but the biggest thing is the tune after you bolt on a turbo and dont run over 16-18psi or you will blow your motor
sevenhillsbilly is offline   Reply With Quote
Old 03-24-2008, 04:20 PM   #12
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
sevenhillsbilly, keep in mind PSI means nothing. If your engine only makes 200whp on 20psi due to the tiny blow dryer under the hood than its fine. Now on the other hand if you have a massive 60-1 under the hood, 20psi would definately toast your stock engine. 10psi on that engine with that much larger turbo will make more power than the smaller snail on double the boost. Fuel Tuning is key.
Forum Jump
fully rebuilding b18c honda/JDM Engine Building 12 03-25-2008 10:04 AM
B16 engine rebuilding hatukazi Engine Building 17 02-29-2008 06:46 AM
pics a EG hatch (rebuilding it ) goldHB94 Auto Multi-Media 32 01-20-2008 10:49 AM
Questions Rebuilding H22a Head .. FasH22405 Engine Building 0 08-05-2003 02:03 AM
Rebuilding Engine CivicB18A Engine Building 1 04-27-2003 02:41 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
