Hates Cunts!
Hey, I wanted to do some simple things to keep my car working better for longer. I know changing the oil regularly and such is good, but I want some more in depth things. My car has broken down since I got it about every month from the day the last thing was fixed. I wanted to know if there was simple tests and things to make sure major things are working well. Thanks. (Sorry for being such a newb lol.)
#2 | |
HS Official Hippie
do the basics and change plugs,wires, oil filter/oil (as you know), I also suggest changing your fuel pump every 3 years
Hates Cunts!
K, cool, thanks. I've change all the electrical things up there, including plugs, wires, dizzy, cap, battery, etc. as you probably remember my bitching about it lol. How much would a fuel pump be for my car???
#4 | |
HS Official Hippie
fuel pumps are actually kind of expensive, your looking at $150-$200
#7 |
Ride: dc5,mk4 gti,2nd gen civic,92 accord cp,88 crx hf
it can but not likely, most of the time when its a bad fuel filter it will stumble when you try to pass ppl and stuff like that
#8 | |
HS Official Hippie
you'd be surprised the amount of power you can lose from a bad fuel pump
#10 | |
HS Official Hippie
not all at once no
#12 | |
HS Official Hippie
loss of mpg, loss of power, but the kicker before it goes completely bad is it will stall when given gas and what I mean is you give it gas and it takes a few seconds to engage.
#14 | |
HS Official Hippie
that could be a few things, but I'd definetly advise against running a fuel injected car low on gas
#16 |
its' because the fuel pump on "in tank" pumps are cooled by the fuel in the tank. when johnny-racer runs around all day at 1/4 tank, blipping the throttle at every light, bouncing off the rev limiter at every shift, his fuel pump takes a beating. the hotter the pump gets, the lower its' life expectancy.
#17 | |
HS Official Hippie
because the fuel is sucked from the tank through the pump to the engine, running the car low on fuel will cause dirt to get sucked into your fuel pump thus causing a bad fuel pump.
#18 |
um.... if you have dirt in your fuel tank, you've got a lot worse problems to worry about than a bad pump. I won't say it's impossible, but it's highly unlikely. Water however..... running low on fuel lets more air into your gas tank at any given time. all that air contains moisture, which condenses, turning back into water. the problem with water is that it's heavier than fuel, so it sinks to the bottom of your tank, the fuel rises to the top. all that water in there can cause corrosion in your tank, or stalling when you got very low on gas and some water got picked up by the pump, but for the most part, it's never noticeable unless you live in a VERY humid climate and the vehicle is very old. the problem like previously stated, is heat, not "dirt." the water I wouldn't worry about if i were you, everyone's got some, most never have any ill effects.
#19 | |
HS Official Hippie
well not necessarily dirt but its not uncommon for their to be debris in your fuel tank, especially when its an 89
#21 | |
Ride: 88 crx si w/b16a
and walbros are everywhere.__________________
Any b-series and crx parts local to southwest michigan area...feel free to pm. |
#22 |
..is grounded.
Ride: '84 buick (rusted)
ps i was always told fuel pumps either work or fail spectacularly. they don't halfway work. my advice on keeping your rex happy: clean out the injection system and fuel system regularly. fresh air filter every 6 months. oil at 3,000 on the dot, and use the high mileage oil. and drive it with respect and balls. lugging hondas is a bad deal.
#23 |
Ride: 92 civic hb
wow, this actually answered a lot of questions I had, like for example I still wasn't sure how often a fuel filter needed to be changed, I figured that would be a big one, so every 3 years? I figured it would be more often than that. I think I should just shell out for a manual....except I have a hybrid, so I would need like 2 manuals. Of course I always have Hondaswap to answer my questions.
| Looking for a turbo tapped or regular oil pan | demonboy1300 | Parts: For Sale/Trade/Wanted | 0 | 05-17-2007 09:57 AM |
| cold air, regular, or short ram intake | infamouz | General Tech and Maintenance | 21 | 10-15-2005 01:27 PM |
| Iridium Spark Plugs Or Regular Spark Plugs | Drenni | ECU's, Electronics, and Tuning | 6 | 04-21-2003 01:39 PM |
| Whats A Regular Weight For 16 Or 17" Wheel? | Civic98HB | Wheels / Suspension / Tires / Brakes | 5 | 03-24-2003 01:41 PM |
| Were Can I Buy Preformance Cams That Are Regular? | hondacivicnos | Engine Building | 10 | 03-01-2003 03:25 PM |
