Squeaky lower contol arms..wtf?
Old 07-20-2008, 03:44 AM   #1
scottie fizzle
HATCHET_HONDA's Avatar
Ride:  90 civic si hatch, 91civic dx hatch
Rep Power: 17 HATCHET_HONDA has a spectacular aura aboutHATCHET_HONDA has a spectacular aura aboutHATCHET_HONDA has a spectacular aura about
Send a message via AIM to HATCHET_HONDA myspace
Default Squeaky lower contol arms..wtf?
recently i installed some new megan LCA'S on my 90 ef hatch....buut the damn things squeak like a sonofabitch!! ive greased them , tried wd 40, everything.. nothing seems to work.. any suggestions?
admit it..your a ricer....
90 si hatch jdm d15b swap(done)
91 dx hatch b16 swap (in progress)
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
stage 3 act clutch ftw
HATCHET_HONDA is offline   Reply With Quote
Old 07-20-2008, 04:11 AM   #2
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin  FaceBook
WD40 is not a lube!!!
Try lithium grease. If that does not work, try a lot of lithium grease. Also, this should be in the EF forum.
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 07-20-2008, 04:21 AM   #3
scottie fizzle
is the spray any good?or just get a tube of it ans smear a butt load on the bushings.. and yea thanks i just noticed i posted in the wrong forum..its 2am..oops
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
Old 07-20-2008, 04:30 AM   #4
K2e2vin's Avatar
I've used the spray and it works well, but I'd recommend the grease in a tub/tube because it's thicker
RIP
Old 07-20-2008, 12:07 PM   #5
B ( . )( . )B's
Rep Power: 73 Ethan has a reputation beyond repute
Ethan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond repute
Send a message via AIM to Ethan Send a message via MSN to Ethan myspace
I hate WD-40!
My 91 Civic HB Project
add me on ps3.... my account is "SOHCivic"
Ethan is offline   Reply With Quote
Old 07-21-2008, 12:05 AM   #6
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Check to make sure that the bushings aren't broken in some way. Lots of people have had problems with the bushings in the Megan LCAs, and quite a few people also replaced the bushings with new polyurethane ones.
Old 07-21-2008, 01:05 PM   #7
scottie fizzle
ya know that mite be the problem..theyre not broken but theyre quite stiff and like plastic feeling to me...where could i pick up new bushings?
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
Old 07-22-2008, 12:28 AM   #8
Calesta's Avatar
Ride:  2003 S2000
Energy Suspension
Prothane
etc...
Old 07-22-2008, 12:44 AM   #9
99sidude's Avatar
Ride:  gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Rep Power: 50 99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of
Send a message via AIM to 99sidude
Sounds like you already have some kind of poly bushing, which are known to squeek alot when not lubed correctly. Regular grease won't work.
I have energy suspension bushings on my car. They say to either use their grease, or a "marine grease" as a substitute. After about 6 months of use they became really noisy, so I used some gereric marine grease I got at autozone to fix the problem. Has worked like a charm so far.
Originally Posted by Celerity View Post
The worst thing that car ever had installed was your lying two-bit fat ass in the left seat.
My Build: http://hondaswap.com/auto-multi-medi...sc-buld-94841/
93' dx hatch
jdm b18c - jrsc 8psi
s300 440cc RC's
99sidude is online now   Reply With Quote
Old 07-22-2008, 05:16 AM   #10
scottie fizzle
HMMM marine grease huh? i take it that stuffs water proof? did you remove the bushings then smear the grease over the collar inside? seriously ill try anything the squeaking is driving me nuts!!
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
Old 07-22-2008, 06:17 AM   #11
99sidude's Avatar
it would prolly work better if you did that, but I just smeared everything really heavily
93' dx hatch
s300 440cc RC's
Old 07-31-2008, 03:03 AM   #12
scottie fizzle
got an update for ya....i just got done slappin some of that marine grease all over them bushings inside and out. lowered the car down and poof!! quiet as a mouse! seems to be some good stuff and it was pretty cheap too.. thanks
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
Old 07-31-2008, 06:19 AM   #13
99sidude's Avatar
Nice!
93' dx hatch
s300 440cc RC's
Tags
bushings, lca's, squeaky, wtf
Lower Control Arms Kit Integra 90 - 01 91 92 93 94 MR S RSS-Bot Auctions 0 02-28-2008 12:23 PM
Lower Control Arms Kit Integra 90 - 01 91 92 93 94 MR R RSS-Bot Auctions 0 12-23-2007 01:53 PM
lower control arms civiclxb16 Wheels / Suspension / Tires / Brakes 9 07-02-2005 01:23 AM
SRR lower control arms hayabusa160 Wheels / Suspension / Tires / Brakes 1 07-30-2003 03:23 AM
Lower Control Arms! I Need them MXDesa Parts: For Sale/Trade/Wanted 4 07-22-2003 10:11 PM
