Greenhorn
hey i ahve a 91 civic dx with a d16z6 swap the swap was just done i have the pre obd0 to obd1 jumper harness and now i have a problem with the car wont turn over at all. all the lights are on in the dash including the high beam indicator.hazards, and all other lights and the car wont even spin over. i know the engine is good as for the starter i have put on two and every thing is free nothing binded. If you can help i would appericate it.
Ride: 1990 ED DX jdm D15B dual carb;x 1991 ED DX B16A OBD0
Did you do your own engine harness or did you get a custom monotech harness or something along those lines along with the ecu jumper harness? I'd make sure that you have everything pluged in to their proper places and make sure all of your grounds are hooked up and clean. Any spark or fuel?
Greenhorn
yes it has fire to the starter. but idn if it has any fuel or spark because the engine or starter wont even turn over wont move. because of the lighting situation with all the lights on in the dash it just wont do shit.
#6 |
starting system is seperate from the ecu. if it has power, is grounded properly, and has a functioning ignition switch, then it should crank over just fine.
op: you should have multiple grounds to the chassis. one from the valve cover to the radiator core support area, one from the tranny to the pass. side chassis area, and one that goes into your main engine harness at the thermostat. you should have power going from battery positive, to the starter, and to the fusebox. if all thats good check to see if you're getting 12v at the trigger terminal at the starter when you have the car turned to crank. __________________
91 Civic Si b18b1, I/H/E, 6000k HID kit, 94 teg cluster Parting mustang out to buy another civic
#8 |
Greenhorn
well i have tried the ecu sitiation and thats not it i have like 3 p28's but thats not the problem.....The car when you turn on the key every light in the dash will be on including the hazards and high beam indicator and will not go out if you try and crank the car the high beam and hazards will just get like brighter. but the starter will never kick over i have tried starters and all
#9 |
yep sure will
#12 | |
goldgeen90ef
Ride: 96 civic cx b18c-r,95 celica battle daily grinder, chuck taylors
#13 |
Greenhorn
so you said the same thing was the thermostat ground well on my orginal harness had two grounds on the thermostat and i ran a test light to one of them and one of the grounds have current on it idn why or what not but it was there the first time so idn. and also GOLDGREEN what did you do to fix your ground
| car wont turn over!!!HELP PLEASE!! | 93delsol-racer392 | HYBRID -> EG-EK / DC | 4 | 08-16-2008 02:14 AM |
| 92DA ls/vtec swap - wont turn over - wont return key-5spd conversion as well. | TurboColt | HYBRID -> ED-EF / DA | 18 | 08-18-2006 04:27 PM |
| car wont turn off | 1Twin1 | Engine Building | 4 | 08-02-2006 08:32 PM |
| f22 with h23 wont turn over | FTPRACING | HYBRID -> BA-BB /CA-CD | 4 | 10-16-2003 10:26 PM |
| Wont Turn Over! | mattcalica | General Tech and Maintenance | 5 | 01-21-2003 11:00 PM |
