throttle body power gains
Members have access to more features and see fewer ads! It's free, what are you waiting for?
Old 06-28-2008, 01:49 AM   #1
The name's Sam
philyphreak2127's Avatar
Ride:  98 civic dx sedan, 80 trans am
Rep Power: 16 philyphreak2127 will become famous soon enough
Default throttle body power gains
Alright guys I figured I would pose this question to you guys since I got into it with a guy over this on another site. Okay so this guy has a vitara and eagle built z6 block with a minorly home ported z6 head, turbo motor. He was pushing around 300 horsepower on 19 lbs of boost, on 550 cc injectors. I asked him what intake manifold (to which he replied y7 manifold, he had been running a y7 head until he bought a z6 head to add a little more power)he was running and mentioned a quick cheap way to wake a couple more horses would be to run to a junkyard and get a throttlebody off of a b, h, or f series motor since they will bolt onto a d-series manifold and are 60 mm rather than 55 mm. This other guy began to argue that with a properly ported manifold and throttlebody would make a 20+ horsepower gain. I responded telling him that I wasn't saying anything about the manifold and that I didn't doubt it that getting a z6 or y8 manifold and porting it properly with a bigger throttle body that he would make a 20+ horse gain but I was simply talking about how just throwing a junkyard throttle body on his setup wouldn't be a huge power gain on the stock manifold he has on the motor. So does anyone who knows a bit about the flow dynamics of a motor know about how many horsepower can be had from simply taking a throttle body from a b, h, or f-series motor and putting it on his setup? Keep in mind I am not looking for a specific number just a ball park estimate with a quick explanation as to why he would gain that. I am not asking to argue anymore but hell if I gain anywhere over 5 horsepower I will throw my f22 throttle body on my motor.
philyphreak2127 is offline   Reply With Quote
Old 06-28-2008, 03:08 AM   #2
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 77 K2e2vin is a splendid one to beholdK2e2vin is a splendid one to beholdK2e2vin is a splendid one to beholdK2e2vin is a splendid one to beholdK2e2vin is a splendid one to beholdK2e2vin is a splendid one to behold
Send a message via AIM to K2e2vin
If it's not port-matched, he won't see any gains. If it is, he'll probably see minor gains; but don't know about +20hp.
Reason being; the runners are still the same size and the VE of the engine doesn't change.
1988 Honda Civic STD-more mods than I want to list
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 06-28-2008, 11:49 AM   #3
my cars go fast
SLOWdelawareEG's Avatar
Ride:  B16 TURBO ef hatch
Rep Power: 7 SLOWdelawareEG will become famous soon enough
a 5mm larger tb will make minimal gains and probably wont be noticeable. saying it will make 20hp, port matched or not, is fucking preposterous. upgraded tb's should be on the bottom of the list in said situation(vitara+boost setup). if the bottom end's built, add fuel and boost, and retune that shit.
SLOWdelawareEG is offline   Reply With Quote
Old 06-28-2008, 08:25 PM   #4
The name's Sam
well I am not arguing with the owner of the car himself but a guy who supposedly owns a flow bench. But then again obviously the guy can't read for him to understand I didn't mention the manifold. As for the owner of the car he runs low 11 second passes with this setup in a gutted ef.
Old 06-28-2008, 09:02 PM   #5
Inveteratus
Blanco's Avatar
Ride:  '93 BMW 325i
Rep Power: 203 Blanco has a reputation beyond repute
Blanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond repute
myspace
Actually, the VE does change...just for the worse. The larger throttle body provides higher volume at the sacrifice of velocity.
Originally Posted by Albert Einstein
"Great spirits have always found violent opposition from mediocrities. The latter cannot understand it when a man does not thoughtlessly submit to hereditary prejudices but honestly and courageously uses his intelligence."
Originally Posted by Scrubs
That's nonsense, people are bastard coated bastards with bastard filling.
Originally Posted by Shawn Pelton
It's not good to be a drummer unless you got some bad motherfucker up inside you.
Blanco is offline   Reply With Quote
Old 06-28-2008, 09:39 PM   #6
żUnKnOwN?
INJEN78's Avatar
Ride:  91 civic si
Rep Power: 66 INJEN78 has much to be proud ofINJEN78 has much to be proud ofINJEN78 has much to be proud ofINJEN78 has much to be proud ofINJEN78 has much to be proud ofINJEN78 has much to be proud ofINJEN78 has much to be proud ofINJEN78 has much to be proud of
and b series tb dont fit on d's i already tried
the bolt holes are not spaced coreectly
R.I.P BEN LEE2/24/08 we love and miss you
R.I.P Rex 8/18/08 coolest dog ever!!!
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 06-28-2008, 10:33 PM   #7
Honda Enthusiast
Luis998's Avatar
Ride:  '94 EG sedan w /Z6, '97 EK hatch
Rep Power: 55 Luis998 has a brilliant futureLuis998 has a brilliant futureLuis998 has a brilliant futureLuis998 has a brilliant futureLuis998 has a brilliant futureLuis998 has a brilliant futureLuis998 has a brilliant futureLuis998 has a brilliant futureLuis998 has a brilliant future
I'd just get one of those "tornado" gizmo's that "guarantee you" fifteen horsepower for adding a piece of aluminum to your intake.
Max? There is no max. Max just means you gave up.
This is my thread: http://hondaswap.com/engine-building...g-wind-110848/
My for sale/trade thread http://hondaswap.com/parts-sale-trad...1/#post1048406
Originally Posted by Blanco View Post
Headers and a turbo, eh? Brilliant advice, Doctor. Simply brilliant.
Originally Posted by LS_VTEC View Post
lol... you could say that doing it right will "get you bitches". ;x
Originally Posted by efhondakid View Post
"Im so JDM I sleep on the right side of the bed"
Luis998 is offline   Reply With Quote
Old 06-28-2008, 10:50 PM   #8
Inveteratus
Blanco's Avatar
Ride:  '93 BMW 325i
myspace
That's the first time I've heard that. A lot of people on D-Series.org are running B-Series TBs on their D-Series IMs.
Old 06-29-2008, 09:15 AM   #9
The name's Sam
well would you still have a porblem with velocity when it comes to forced induction? And as far as the b-series throttle body not fitting your intake manifold that suprises me. I was under the impression that all honda 4 cylinder throttle bodies besides maybe the k-series throttle bodies swap between each other.
Old 06-29-2008, 09:48 AM   #10
żUnKnOwN?
INJEN78's Avatar
Ride:  91 civic si
i dunno..i tried to put the one from my b18a1 on my d16a6 mani..i thought the tps was arbage and tried swapping,,it didnt fit
bolt holes were off a little bit
GOOD FAST CHEAP,
Old 06-29-2008, 01:28 PM   #11
VTEC or NOTEC
Justin66's Avatar
Ride:  1990 Intergra GS/XSi
Rep Power: 7 Justin66 will become famous soon enough
20HP from the TB alone is questionable, but if its tuned with some good cams and port matched, bigger intake manifold and filter im sure it can be.
90 Integra GS/ XSi
- JDM B16A SiR2 w/ full exhaust & CAI
- Skunk2 stage 1 cams (not installed yet)
- J1 Tranny
- H & R lowering springs
- Rear strut bar and front camber kit
- HKS Hi-Power exhaust
- Powersteering removed
Sk2 Cam gears and Intake Manifold soon.
My ultimate VTEC juice:
- Shell Vpower 91 octane
- Castrol SynTEC
- Simmer for 3000rpm
- VTEC should rise
- Allow other car to catch up and let stand for 5 mins
Justin66 is offline   Reply With Quote
Old 06-29-2008, 05:28 PM   #12
The name's Sam
But he is saying 20+ horsepower gain on a vitara/eagle built z6 block with a minorly ported z6 head with a turbo setup I don't know the turbo right off hand but I know when it was dynoed he was putting down around 300 hp on 19 psi with 550 cc injectors. The funny part is upon rereading what the guy arguing with me was saying he ended up making himself sound like a douche becuase he was essentially backing up exactly what I said about how a 60 mm throttle body from one of the bigger honda motors will not add much in the way of performance especially if he sticks with the stock manifold. I just decided it wasn't worth my time to argue with a dude who can't even fully comprehend what he reads when he reads it. With that said. I have no doubt should he replace the intake manifold with say a z6 or y8 manifold port the runners and port match even a 60 mm stock throttle body and make sure the port is done well he could potentially see 20 horses. I wouldn't doubt it especially when it is used in a forced induction setup. I also think that with 19 psi on that build he would be well off to go ahead and swap out the fuel rail and injectors with an aftermarket aem or venom fuel rail and some bigger say 750, or 1000 cc injectors along with the intake manifold, and throttle body he could potentially turn the boost back up to 25 where he was running it retune the thing and be pushing close to 400 horses. But some people are penny pinchers and don't want to spend any money.
Old 06-29-2008, 05:33 PM   #13
żUnKnOwN?
INJEN78's Avatar
Ride:  91 civic si
id be happy with a 300hp D...
but i dont know about the 20 horses from im,tb and bigger injectors..
GOOD FAST CHEAP,
Old 06-29-2008, 07:05 PM   #14
The name's Sam
well I also mentioned turning the boost back up to 24 psi though. If I could think of what turbo he is running you would understand why I say that. His tuner is pretty good as well, and its hard to explain but if you saw the dyno sheets you would understand, his turbo is far from maxed out its just his intake manifold, throttle body, and injectors are maxed out and you can tell from his dyno graphs.
Old 06-29-2008, 10:42 PM   #15
Inveteratus
Blanco's Avatar
Ride:  '93 BMW 325i
myspace
How can you tell that his TB and IM are maxed out from a dyno when every professional engine builder in the world needs a flow bench to determine that?
Look at it like water flowing through a tube. Better yet, let's use a funnel. Does making the mouth of funnel larger get the fluid out of the other end faster or does it actually create a back up due to too high a volume? Then, why would putting a larger throttle body on an otherwise stock intake system do anything positive? It doesn't matter how hard you shove the charge in there, the engine can only use what it's able to use. TB and IM size should be matched to cam profile by using a flow bench chart for the exact head being used. If you want to just throw a bunch of parts at an engine, you'll never see any real gain. But if you take the time to properly match all of your parts then you start to see big gains. This is where things stay pretty much the same regardless of n/a or f/i.
Old 06-29-2008, 10:57 PM   #16
The name's Sam
well its not so much that I can tell from this one dyno chart. its from repeated dyno charts after every new part and retune he does. I mean with the same setup merely changing from a stock y7 head to a ported z6 head even though the port was far from full race, he only gained around 11 horsepower. So I pretty much figure after seeing about 4 different dyno charts and multiple mods that his holset turbo is either maxed out, or he needs better air flow. And pardon me if I said the manifold and TB are maxed out I hardly think that would be possible on only a minor build like this if at all but they could be much better than they are now... Like I said its hard to explain and you probably think I am either crazy, or talking out of my butt, but after watching this build for quite a while now its relatively easy to tell he needs to upgrade the manifold, and throttle body. His torque curve is also very slow to rise to the peak. So a throttle body could help throttle response correct? Not to mention with a semi built block, ported head, but stock intake "system" so to speak and a turbo that has pushed all the way up to 24 psi and still not gone higher than 300 hp he needs to either upgrade the air flow or fuel flow to gain some more power.
Old 06-30-2008, 10:00 AM   #17
żUnKnOwN?
INJEN78's Avatar
Ride:  91 civic si
hes running a ginormous turbo huh??
GOOD FAST CHEAP,
Old 06-30-2008, 07:51 PM   #18
The name's Sam
it is pretty big. I couldn't find the measurements of it though looked but haven't found where he had posted them. its a holset h1c if that helps. Seriously the guy has to be one of the best drivers I have ever heard of. 11.20 on only 279 hp in a gutted ef hatch. Now he is up to a little over 300 hp in the same car on less boost.
Old 06-30-2008, 08:38 PM   #19
żUnKnOwN?
INJEN78's Avatar
Ride:  91 civic si
his torque is slow to rise to peak due to the fact the turbo is sooo big,,takes long to get full boost..if he went smaller hed probably have better times
GOOD FAST CHEAP,
Old 06-30-2008, 11:09 PM   #20
The name's Sam
