Towing my Rex adds miles to odometer
Old 11-23-2006, 01:37 PM   #1
Ride:  1990 Honda CRX HF
Rep Power: 7 therobesons is on a distinguished road
Default Towing my Rex adds miles to odometer
I tow my CRX behind a motorhome.
When I do, it racks up the miles on the Odometer.
Is there a fix so it will show the miles when I drive but NOT when I tow?
I fuse to pull or a switch I can install or ????
TIA
Bob
1990 CRX HF
White, Stock
therobesons is offline   Reply With Quote
Old 11-23-2006, 02:12 PM   #2
Rep Power: 25 MXDesa will become famous soon enoughMXDesa will become famous soon enough
Send a message via AIM to MXDesa
Unplug the speedometer sensor on the top of the tranny when you tow. Thats a really easy fix.
2003 EP3 Civic SI - Pretty Much Stock (for now)
1990 Eagle Talon TSI Turbo AWD
2005 Kawasaki ZX-6R - 10.58 ET at 137 MPH
MXDesa is offline   Reply With Quote
Old 11-25-2006, 09:38 AM   #3
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
Sounds like the right thing to do to me
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 12-01-2006, 12:18 PM   #4
Its Da Mad Hatter
mad_hatter's Avatar
Ride:  acura integra
Rep Power: 8 mad_hatter is on a distinguished road
you can find out how many miles about you towed it pull the guage cluster and turn the miles back with drill in the speedo connector
mad_hatter is offline   Reply With Quote
Old 12-01-2006, 01:30 PM   #5
Ninja Member
Cashizslick's Avatar
Rep Power: 117 Cashizslick has a reputation beyond repute
Cashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond repute
Anymore info on this procedure??
Originally Posted by Canadian Finance Minister Jim Flaherty
the recent public policy of privatizing profits and socializing losses is unacceptable to taxpayers
Cashizslick is offline   Reply With Quote
Old 12-01-2006, 02:30 PM   #6
I need some ligaments!!!
turbo sol's Avatar
Location: laurel, montucky (ten minutes out of billings)
Ride:  89 crx hf, turbo'd 95 del sol si, 87 shaggin wagon(astro)
Rep Power: 17 turbo sol has a spectacular aura aboutturbo sol has a spectacular aura about
Send a message via MSN to turbo sol myspace
pull the cluster.
car + vinyl = big hp!!!
wipe your mouth, there's still a tiny bit of bullshit around your lips
Achmed the dead terrorist:
I once threw a penny between two jews and watched them fight to the death! I did the same thing with two Catholic priests except I threw in a small boy! And the winner had to fight Michael Jackson!
(\__/)
( 0.o )
( > < ) The bunny will rule teh world! Bwahahahaha!!!!
turbo sol is offline   Reply With Quote
Old 12-01-2006, 04:58 PM   #7
Its Da Mad Hatter
mad_hatter's Avatar
Ride:  acura integra
yeah pull the guages out and there be two harness plugs and the speedo cable just unclip it and there it is
Old 12-01-2006, 07:09 PM   #8
You cant turn miles backwards. Do not give false information. If you do not know then dont post.
Old 12-01-2006, 11:05 PM   #9
Its Da Mad Hatter
mad_hatter's Avatar
Ride:  acura integra
ok well if its false information you can explain to me how i did it three days ago i had my cluster off and i was running a new cable for it and i just started messing with it since i dont know how many miles are on my swap anyways i stuck a bit in there and ran the drill if you go foward it works as if the car was driving at 40mph i reverse it and the speedo drops and the miles go down at 40 miles an hour so how is that false information i mean if its not supposed to do that and mine is screwed up i dunno but def. worked for me.....why would i waste time giving false info anyway if you want ill set up my camera and even give you a little how to clip of it in action
Old 12-02-2006, 01:05 PM   #10
Andrew's Avatar
Ride:  1991 CRX Si
There was a thread on H-T with detailed pics on how to do it.
I'm searching around, but can't seem to find it. It's possibly on here
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 12-02-2006, 01:11 PM   #11
Its Da Mad Hatter
mad_hatter's Avatar
Ride:  acura integra
it may be a clip or something that needs to be removed to do it but i was just messing around since it was out and it infact worked its just slow cause the drill only reads at 40mph so 160,000, takes a long time i put a hose clamp on my drill and let it run but the battery gets slow to fast
02 Acura RL - 36K miles - clean, mint condition ms-acura Vehicles: For Sale/Trade/Wanted 0 11-07-2005 02:54 PM
97 civic shell (perfect swap) b18c1civic97 Vehicles: For Sale/Trade/Wanted 36 04-25-2004 06:42 PM
The latest GS-R find UDT General Tech and Maintenance 24 04-01-2004 01:20 AM
