trans question
Old 10-24-2009, 10:37 AM   #1
Ride:  89 crx hf && 2-85 crx dx
Rep Power: 1 crxhfz6 is on a distinguished road
Cool trans question
im in the process of switching transmissions in my 89 crx. I have an hf trans that is going in and we noticed that the input shaft had a little wiggle to it that we thought we would need to fix. i went ahead and took out the one in the car in it had the same deal. so is this actually normal or do both have the same problem?
crxhfz6 is offline   Reply With Quote
Old 10-24-2009, 08:47 PM   #2
D16SiHatch's Avatar
Rep Power: 33 D16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud of
no it's not normal. the input shaft bearings are most likely fubared.
the broken one in this picture
pulled from this site
http://www.performanceforum.com/wesv...ans/trans.html
which you may end up needing it turns out lol
91 Civic Si
b18b1, I/H/E, 6000k HID kit, 94 teg cluster
Parting mustang out to buy another civic
D16SiHatch is offline   Reply With Quote
Old 10-24-2009, 08:54 PM   #3
Prof. Bottles
mikey bottles's Avatar
Ride:  Swapped 88' Rex
Rep Power: 14 mikey bottles is a jewel in the roughmikey bottles is a jewel in the roughmikey bottles is a jewel in the rough
Send a message via AIM to mikey bottles myspace
not trying to thread jack, but do you know where you can buy just the input shaft bearing instead of in a whole kit? ive looked everywhere but cant find just the bearing, im sure crxhf would appreciate the info as well!
"LAYIN' IT DOWN ON THE STOMPIN' GROUND SINCE 1985" NJ856!
mikey bottles is offline   Reply With Quote
Old 10-27-2009, 10:40 AM   #4
jlicrx's Avatar
we buy them from the local Honda dealer - there are 2 different bearings available, one for the small bearing case (DX/HF/etc.) and one for the large bearing case (Si/EX/ZC)
small bearing Part No. 91002-PHR-003 - 26mm i.d. x 52mm o.d. x 15mm thk.
large bearing Part No. 91002-PS0-003 - 26mm i.d. x 58mm o.d. x 15mm thk.
you will want to also replace the seal:
Part No. 91216-PL3-005
ZCspeed Racing
Old 10-27-2009, 11:23 AM   #5
thanks. i just used one off of a disassembled hf i had lying around because it looked brand new. i got all of the seals in and it almost ready to be put back together
One more trans question 92sihatch Civic and del Sol - EG and EK 16 04-11-2008 04:42 PM
Trans question CrixSi91 HYBRID -> ED-EF / DA 4 06-30-2007 12:31 PM
Question>> About L3 Trans ceehris Civic and CRX - EF 5 11-29-2006 07:57 PM
trans question Ignorant import guy HYBRID -> EG-EK / DC 1 05-28-2006 01:06 AM
90 Crx Trans Question nickcwell HYBRID -> ED-EF / DA 2 05-31-2003 10:13 AM
