weird idle
Members have access to more features and see fewer ads! It's free, what are you waiting for?
Old 06-18-2008, 02:08 PM   #1
dsix
hondadsix's Avatar
Ride:  1990 crx dx jdm b16 swap ls tranny future turbo
Rep Power: 0 hondadsix is on a distinguished road
Angry weird idle
Ok i just put my newer B16 in my car, with the old motor i was having a problem at highway speed if i ran at a constant speed i would loose power, like i was only running on three cylendars. when i switched the ignition off then right back on it quit and ran fine. now with my newer motor the problem has arrisn at idol and sometimes at highway speed. still if i switch it off and then on real quick it straightens out.i thought it was wiring but i checked all of the connections no help. ajusted TPS, did timing check, new fuel filter. i was thinking maybe injectors or fuel pressure regulator. if anyone has had this problem and fixed it please tell me it is driving me crazy.
hondadsix is offline   Reply With Quote
Old 06-18-2008, 04:44 PM   #2
..is grounded.
dacheat's Avatar
Ride:  '84 buick (rusted)
Rep Power: 106 dacheat has a reputation beyond reputedacheat has a reputation beyond repute
dacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond repute
idle...sorry i can't help it...i see this when i read your thread title.
as for the problem it sounds like limp mode. but i don't know much about that.
Originally Posted by klyph View Post
God: Yo Charlie, do your Moses act again.
Charlton Heston: LET MY PEOPLE GO!
Moses: Har de fuckin har har
Jesus: (giggles)
Originally Posted by Battle Pope View Post
Maybe it would be easier to type if you weren't using both hands to shove things up your ass.
dacheat is offline   Reply With Quote
Old 06-20-2008, 01:01 AM   #3
dsix
hondadsix's Avatar
nice that is a weird idol
Old 06-20-2008, 01:04 AM   #4
My name is Byron.
efhondakid's Avatar
Ride:  `89 DX Hatch w/JDM B16
Rep Power: 64 efhondakid has a brilliant futureefhondakid has a brilliant futureefhondakid has a brilliant futureefhondakid has a brilliant futureefhondakid has a brilliant futureefhondakid has a brilliant futureefhondakid has a brilliant futureefhondakid has a brilliant futureefhondakid has a brilliant future
I was thinking American Idol?
H22 head for sale.
http://hondaswap.com/parts-sale-trad...5/#post1073448
Wanted CRX parts.
http://hondaswap.com/parts-sale-trad...6/#post1073450
Old 06-20-2008, 07:03 AM   #5
Rep Power: 0 crsexy is on a distinguished road
Sounds like you might have an ingintion control module going out. Or else it's the main relay under your dash.
crsexy is offline   Reply With Quote
Old 06-20-2008, 09:19 AM   #6
..is grounded.
dacheat's Avatar
i've had both of those issues and his problem description didn't set off my radar for them. worth checking i guess...
Jesus: (giggles)
Old 06-20-2008, 09:25 AM   #7
Crusher of Noob Ambitions
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 101 BrutalB83 has a reputation beyond repute
BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
That's what I thought when I saw the thread title too...
If you find anything I say helpful, please leave me some rep...
97 Integra LS Coupe:
*AEM Intake/Megan Header/Magnaflow Exhaust
*Tokico Shocks & Springs
*Megan Strut Braces & H-Brace
*98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys)
Please DO NOT PM me with tech questions! Ask your questions on the forum so we can all benefit from the answers...
Old 06-20-2008, 02:41 PM   #8
dsix
hondadsix's Avatar
yea yea so i can not spell sorry idle from now on. how do i check both of those i have a book from integras but they are the wrong obd. i don't know what mine is i think it is OBDO it has three plugs on it a long one(white) and two small ones(black). the ecu is a pr3-J00 i do know that but not much more.also all of the plugs on the harness are diff. color. the injector plugs are cream color. i also have a rex book would that help?( i will look at it tonight) Also could it be that i swaped to a blox 72mm throtle body, with port match on the stock mani. the throtle body covers the bottom hole in the mani. could that be it?
Old 06-20-2008, 05:10 PM   #9
..is grounded.
dacheat's Avatar
oy - regarding the ignition module, it is part of the distributor assembly. the main fuel relay typically hangs out inside the cabin, lower left of steering wheel up under where all the important wiring is . here's an example of what your ignition module could look like (i don't know for the setup you have, this is just a general 'what it looks like' deal):
here's what the fuel relay looks like:
the interwebs have all kinds of how to replace 'em notes. there are a few threads here on HS talking about the symptoms of each failing too. click 'search' and then type 'ignition module' and then hit enter.
Jesus: (giggles)
Old 06-20-2008, 06:22 PM   #10
dsix
hondadsix's Avatar
thanks for the help and the pic i will try that out and see what happens. i don't think it is the ignition module because it did it with two different distributors. thanks i will let you know what happens
Old 06-20-2008, 08:00 PM   #11
My name is Byron.
efhondakid's Avatar
That would be my guess, that TB is too big for a stock motor, and covering those holes will make it idle like shit, swap it back to stock and see if it makes a difference.
H22 head for sale.
Wanted CRX parts.
Old 06-21-2008, 12:11 AM   #12
B
Administrator
B's Avatar
Ride:  m3, dakota
Rep Power: 115 B has a reputation beyond reputeB has a reputation beyond repute
B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
myspace
fixod yeur type
B is online now   Reply With Quote
Old 06-21-2008, 12:27 AM   #13
Rep Power: 6 BrokenRex has a spectacular aura aboutBrokenRex has a spectacular aura about
the picture that dacheat posted was correct, however you might think the plug closer to the camera is the one that's being pointed at, when it's the one behind that. the larger one with the maroonish bottom. btw cheat, did you remove your whole dash to take that picture, or are you just a contortionist? rep+ for your great pic or great flexibility!
BrokenRex is offline   Reply With Quote
Old 06-21-2008, 01:15 AM   #14
..is grounded.
dacheat's Avatar
hehe naw, that's an intarweb photo and a manhand - but i did do some super sleuthing with teh google to find it .
for the record, i don't think that shot is possible - it has to be photoshopped
i kid, i kid....
Jesus: (giggles)
Old 06-22-2008, 04:53 PM   #15
dsix
hondadsix's Avatar
i will swap back to stock and see what happens but damn that thing gives me kick ass top end power. i will save it for track use. that module is a pain to get to for real so i will try the body first thanks.
Old 06-27-2008, 02:20 PM   #16
dsix
hondadsix's Avatar
The stock throttle body fixed it. Damn it. it would have worked fine if i hadn't ported the intake manifold. but o well thats tunin for ya. thanks all for the help, hopefuly i can be of service to yall in the future. later
Forum Jump
b16a idle problem not iacv or fast idle toqeer1986 HYBRID -> EG-EK / DC 9 12-12-2007 02:06 PM
h22 weird idle prob stevo11811 HYBRID -> BA-BB /CA-CD 1 03-12-2006 11:41 PM
Having idle problems, idle keeps surging 91civicsiracer General Tech and Maintenance 17 10-04-2004 07:40 AM
High Idle Than Bam Irratic Idle Accordturbo94 General Tech and Maintenance 39 11-07-2003 11:22 PM
Weird idle SixtySecondAssassin General Tech and Maintenance 3 09-18-2003 01:11 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
