Well, changed my mind again!! Help pls??
Old 04-24-2008, 01:59 AM   #1
Hates Cunts!
Aleaf.CRX's Avatar
Aleaf.CRX has a reputation beyond repute
Aleaf.CRX has a reputation beyond reputeAleaf.CRX has a reputation beyond reputeAleaf.CRX has a reputation beyond reputeAleaf.CRX has a reputation beyond reputeAleaf.CRX has a reputation beyond repute
Default Well, changed my mind again!! Help pls??
So, I actually do want to put my body kit on. Right now, I have a front bumper and sid skirts. I'll get a rear bumper later. Anyway, i've never done this and can't find much info on putting them on. What do you need exactly (Tools, foam, anything)??? I'm pretty sure I can get it apart and put them on myself, but if anyone has pointers, feel free to let me know! Thanks much!
Aleaf.CRX is offline   Reply With Quote
Old 04-24-2008, 02:24 AM   #2
K2e2vin's Avatar
Ride:  88 Honda Civic HB
K2e2vin has a reputation beyond repute
K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin  FaceBook
Not sure about side skirts but to take the bumper off you just need a philips screwdriver and 10mm socket/ratchet. Take the bumper lights off and unscrew the 10mm bolts from there. Also, unscrew the pair of screws on either side holding the bumper to the fender.
Once that's out, just unscrew the screws holding the bumper cover on, and put your new bumper on.
Sideskirts might just be screwed on, I never really looked at it.
Rear bumper has the philips screws that hold it to the quarter panel(similar to the front bumper screws to the fender); undo the two 10mm or 12mm(I forgot what size exactly) bolts from the inside and two from under the car. These bolts hold on the bumper support btw; to find them just follow the "frame rail".
1988 Honda Civic Standard-Hiatus
1992 Honda Accord LX-DD
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 04-24-2008, 12:05 PM   #3
AHHVTEC's Avatar
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
if its fiberglass theres a 90% chance its not gona fit right.
Old 04-24-2008, 01:20 PM   #4
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
reikoshea has a reputation beyond repute
reikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond repute
myspace
werd...ive never had a fiberglass one fit right.
reikoshea is offline   Reply With Quote
Old 04-24-2008, 01:41 PM   #5
Hates Cunts!
Aleaf.CRX's Avatar
Hm.... It is. Is there a way to make it fit right? And if not, what kind should I get if I want a body kit still?
Old 04-24-2008, 01:43 PM   #6
AHHVTEC's Avatar
a body shop can make it fit right,
Old 04-24-2008, 01:44 PM   #7
Hates Cunts!
Aleaf.CRX's Avatar
What's their technique? I'm sure I can do it too. but if I can't, what will it cost to have it done?
Old 04-24-2008, 01:47 PM   #8
AHHVTEC's Avatar
most of the time they have to cut it and add bondo to it.
Old 04-24-2008, 01:54 PM   #9
Hates Cunts!
Aleaf.CRX's Avatar
Fuck that, I can totally do that. I bondoed my hood (Which I painted black) I'm about to bondo the tiny paintball dents in my doors. I know how to work with bondo. What would make me want to go to a shop do you think? And where exactly do they bondo, just where the kit meets the body???
Old 04-24-2008, 01:58 PM   #10
AHHVTEC's Avatar
well it really depends on how bad its off, you may get luck and it fir fine but i have seen where they have had to cut some parts all the way in half and add to it
Old 04-24-2008, 02:15 PM   #11
Hates Cunts!
Aleaf.CRX's Avatar
I wouldn't mind. I have some knowledge in fiberglass and bondo, so I'll figure it out. I'd rather just take care of it myself. I don't want to pay someone to do something learnable and probably fairly easy once you get the hang of it.
Old 04-24-2008, 03:53 PM   #12
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
myspace  FaceBook
Just get a lip kit. Looks so much better, fits better, and is a lot cheaper.
Old 04-24-2008, 04:03 PM   #13
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
hell motherfuckin yes
but for the sideskirts get yourself some self tapping screws and put 2 in the rear(wheel well)and two in the front(fender)then 2-3 in the door jam on the kick panel...
also pop rivets look good for holding kits on,,,
and fiberglass kits are shit,,they crack,scratch and break easily,,
Old 04-24-2008, 06:03 PM   #14
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
Well, fiberglass really isn't for the beginner but if you've played around with it before, go for it.
92civicb18b1 is offline   Reply With Quote
Old 04-24-2008, 08:58 PM   #15
Hates Cunts!
Aleaf.CRX's Avatar
Well, if I run into a problem, my mom's bf used to racecars/ repair his. He's an expert with fiberglass. Yeah, I was thinking of just keeping the front bumper (It's decent) but getting new side skirts and a rear bumper.
Old 04-24-2008, 10:19 PM   #16
autox 89 dx's Avatar
Ride:  91 SI SOHC ZC mini me
autox 89 dx will become famous soon enough
usually the front bumper they leave it long on the top(the part thats under the head lights that you dont see) so you have to trim it to fit propper and depending on wich one you have you might have to remove the steel bumper completely. the body kit just covers were the bumper was
autox 89 dx is offline   Reply With Quote
Old 04-24-2008, 10:42 PM   #17
Hates Cunts!
Aleaf.CRX's Avatar
Originally Posted by Blanco View Post
You're a cool chick.
Wtf? lol.
Old 04-25-2008, 01:57 AM   #18
•°o.O KOOP™
Koop's Avatar
Ride:  98' D-Series SI (CAN)
Koop is infamous around these parts
myspace
Nah, not trying to leg hump or anything. I just think it's cool that you're doing all of this.
mos def
Koop is offline   Reply With Quote
Old 04-25-2008, 01:57 PM   #19
is lol'ing @ you
newb's Avatar
Ride:  '98 Z28
newb has a reputation beyond reputenewb has a reputation beyond repute
Send a message via AIM to newb myspace
One nice thing about fiberglass is you can flex it a lil. When you get the bumper on leave all the bolts and screws loose, so you can still move it around. From there work with one area at time, push/pull the bumper into place then tighten the coresponding bolts down, then move to the next area. Never done it on a Honda, but on other cars I go from side to side then to the end (i.e. front or rear, wut ever bumper your workin with). I think someone said earlier to use pop rivets, if you can hide em and keep em away from the edges of the fiberglass they actually work good. Try to keep em a lil more than twice the diameter of the rivet from the edges (i.e. 1/8" rivet a lil more than 1/4" from the edge) to reduce the risk of the glass crackin later. If you have to cut sections out to alter the bumpers to make em fit I suggest just gettin a fiberglass kit and replacing wut you cut out with all new material. If you bondo the piece you cut out back into place, after you get it all sanded down and ready for paint youll have a really weak spot in your bumper since the only thing holdin the piece in place is the bondo on the surface.
Locate approximately as shown
"I'm a bad man." -Cassius Clay
Originally Posted by Battle Pope View Post
this thread makes me facepalm.
newb is offline   Reply With Quote
Old 04-25-2008, 02:19 PM   #20
Hates Cunts!
Aleaf.CRX's Avatar
Yeah, I heard bondo wasn't a good choice, also considering the cracks in a couple places. I'll definitely be getting some fiberglass.
Old 04-25-2008, 02:22 PM   #21
|Chaz|'s Avatar
Ride:  92' EG Sedan
|Chaz| has a reputation beyond repute
|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute
Send a message via AIM to |Chaz| Send a message via MSN to |Chaz| Send a message via Yahoo to |Chaz|
Lmao. Aleaf you should take some progress pictures of your project .
|Chaz| is offline   Reply With Quote
Old 04-25-2008, 02:26 PM   #22
Hates Cunts!
Aleaf.CRX's Avatar
K. I'll try to. But I don't know when i'll be starting it lol. I'm sure it'd probably be a good idea to get rear bumper first lol.
Btw, anyone know anything light than steel to brace the pieces with, so they don't crack anymore?
Old 04-25-2008, 02:26 PM   #23
is lol'ing @ you
newb's Avatar
Ride:  '98 Z28
Ya, the whole problem with bondo on fiberglass is bondo doesnt flex, fiberglass does. Itll work, and you can make it look good, but if you were to just barely bump into somthin with your bumper thatls most likely cause it to crack.
Try some aluminum flat bar. Light, cheap, and easy to form/drill without special tools. you can get some 1/8"x1" for dirt cheap. And you can buy it by the inch so you dont hafta buy a bunch that you dont need.
Old 04-25-2008, 07:17 PM   #24
instead of bondo use glazers putty it cost alittle more but comes out nicer less pores in it
Old 04-25-2008, 08:57 PM   #25
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
i agree,,not many chicks actually do shit to their own cars,,
and as for light and cheap go with the aluminum like newb said
good luck and do post pix
Wipers with a mind of their own... Lemur6 Prelude 0 09-06-2006 09:07 PM
feels like ABS, just changed brakes Periculum Wheels / Suspension / Tires / Brakes 6 07-11-2006 10:50 PM
Techno Fans dveit Members' Lounge 86 08-04-2003 04:07 AM
Weird Mind Thing asmallsol Members' Lounge 42 05-26-2003 09:23 PM
Changed mind abt the zc crxracing77 HYBRID -> EG-EK / DC 9 10-04-2002 12:18 PM
