What is this thing called?
Old 11-07-2006, 06:47 PM   #1
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
Default What is this thing called?
I don't know the proper name for it... it's the sensor with 2 prongs above the oil filter.
Thanks
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-08-2006, 08:53 AM   #2
Andrew's Avatar
Ride:  1991 CRX Si
nurbody knows?
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-08-2006, 09:24 AM   #3
Rep Power: 0 90_civic_Si is on a distinguished road
It`s the coolant temp switch. It tells the fan when to come on.
90_civic_Si is offline   Reply With Quote
Old 11-08-2006, 12:45 PM   #4
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
you sure?
there is a similar connection on the radiator...
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 11-08-2006, 01:57 PM   #5
jlicrx's Avatar
you are correct - #22 in this picture
https://www.hondapartsdeals.com/hond...omponent=E++06
ZCspeed Racing
Old 11-08-2006, 05:42 PM   #6
Andrew's Avatar
Ride:  1991 CRX Si
Cool. Thanks fellas.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-11-2006, 01:30 PM   #7
Rep Power: 7 NightCat is on a distinguished road
Hey Andrew, which book did you get that out of? btw, is that the same one seen in your head gasket threat?
NightCat is offline   Reply With Quote
Old 11-12-2006, 06:31 PM   #8
Andrew's Avatar
Ride:  1991 CRX Si
It's a .PDF shop manual for a Civic/CRX I downloaded from the 'net.
I've got a file I can Email you. It's about 7mb.
give me your Email and I'll try to send it over.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-20-2006, 03:49 PM   #9
F22HB's Avatar
Rep Power: 7 F22HB is on a distinguished road
What? that doesn't have anything to do with coolan. It is an oil pressure sender that clicks on when your oil pressure goes lower than a certain level and then your oil pressure light comes on.
"Father was killed by ninjas.
Need money for karate lessons."
--random bum's sign.
F22HB is offline   Reply With Quote
Old 11-20-2006, 04:50 PM   #10
Andrew's Avatar
Ride:  1991 CRX Si
No, thats the oil-pressure switch, which is the Single Plug(the one in the picture I posted).
The 2 prong sensor is indeed the Fan switch/coolant sensor
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
this thing is effed who can help it cameronman General Tech and Maintenance 3 07-27-2005 04:26 AM
cool little thing tylonalsnifnfool Members' Lounge 10 04-23-2005 08:27 PM
Funniest thing I have ever seen 98EX Members' Lounge 7 10-19-2002 10:55 PM
Stock tach vs Autometer Monster Thing paragus General Tech and Maintenance 7 10-16-2002 08:27 PM
