what is VTEC
Old 02-27-2008, 03:51 PM   #1
8ballsin's Avatar
Ride:  1990 Honda CRX Si
8ballsin is on a distinguished road
myspace
Default what is VTEC
what is vtec and what exactly is the difference than non vtec
8ballsin is offline   Reply With Quote
Old 02-27-2008, 05:01 PM   #2
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
are you serious?!?!?
Old 02-27-2008, 05:04 PM   #3
8ballsin's Avatar
myspace
yes i just got a 90 crx and to give you little background of my i am a redneck that only drives 4x4's im here in germany and cannot afford the gas so i bought a honda
Old 02-27-2008, 05:12 PM   #4
90_EF_Hatch's Avatar
Ride:  93 BMW 325i sedan, 93 Teggy four door
90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of
myspace
VTEC - Wikipedia, the free encyclopedia
90_EF_Hatch is offline   Reply With Quote
Old 02-27-2008, 07:15 PM   #5
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
myspace  FaceBook
Easy now, you were a noob once too.
Old 02-27-2008, 08:02 PM   #6
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
dude all you have to do is go to a search bar and type in "what is vtec" or "how does vtec work" i guarantee there will be millions of sites that you can read...vtec is probably the most searched word in the world
Old 02-27-2008, 08:06 PM   #7
West West Y'all
Mugen Accord's Avatar
Ride:  '88 Honda Accord LX,
Mugen Accord is on a distinguished road
Send a message via Yahoo to Mugen Accord
Here is a basic definition of VTEC:
In the regular four-stroke automobile engine, the intake and exhaust valves are actuated by lobes on a camshaft. The shape of the lobes determines the timing, lift and duration of each valve. Timing refers to an angle measurement of when a valve is opened or closed with respect to the piston position (TDC or BDC). Lift refers to how much the valve is opened. Duration refers to how long the valve is kept open. Due to the behavior of the working fluid (air and fuel mixture) before and after combustion, which have physical limitations on their flow, as well as their interaction with the ignition spark, the optimal valve timing, lift and duration settings under low RPM engine operations are very different from those under high RPM. Optimal low RPM valve timing, lift and duration settings would result in insufficient filling of the cylinder with fuel and air at high RPM, thus greatly limiting engine power output. Conversely, optimal high RPM valve timing, lift and duration settings would result in very rough low RPM operation and difficult idling. The ideal engine would have fully variable valve timing, lift and duration, in which the valves would always open at exactly the right point, lift high enough and stay open just the right amount of time for the engine speed in use.
VTEC was initially designed to increase the power output of an engine to 100 ps/liter or more while maintaining practicality for use in mass production vehicles. Some later variations of the system were designed solely to provide improvements in fuel efficiency, or increased power output as well as improved fuel efficiency.
In practice, a fully variable valve timing engine is difficult to design and implement.
The opposite approach to variable timing is to produce a camshaft which is better suited to high RPM operation. This approach means that the vehicle will run very poorly at low RPM (where most automobiles spend much of their time) and much better at high RPM. VTEC is the result of an effort to marry high RPM performance with low RPM stability.
Additionally, Japan has a tax on engine displacement, requiring Japanese auto manufacturers to make higher-performing engines with lower displacement. In cars such as the Toyota Supra and Nissan 300ZX, this was accomplished with a turbocharger. In the case of the Mazda RX-7 and RX-8, a rotary engine was used. VTEC serves as yet another method to derive very high specific output from lower displacement motors.
1988 Honda Accord LX:
Bone Stock
My Ex's:
1992 Saturn SL2- Blew Up
1995 Honda Prelude VTEC:
JDM H22A- Sold
Mugen Accord is offline   Reply With Quote
Old 02-27-2008, 08:45 PM   #8
HNFTuning
D15Beater's Avatar
Ride:  or die....
D15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of light
Send a message via Yahoo to D15Beater myspace
D15Beater is offline   Reply With Quote
Old 02-27-2008, 09:05 PM   #9
|Chaz|'s Avatar
Ride:  92' EG Sedan
|Chaz| has a reputation beyond repute
|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute
Send a message via AIM to |Chaz| Send a message via MSN to |Chaz| Send a message via Yahoo to |Chaz|
That was a really good video D15beater. Very easy to understand, if it doesn't help the guy that created the thread, I don't know what will.
|Chaz| is offline   Reply With Quote
Old 02-27-2008, 09:40 PM   #10
universal logic protocol
whiterabbit06's Avatar
Ride:  99 VW GTI 07 Jeep Compass
whiterabbit06 has a reputation beyond repute
whiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond repute
Send a message via AIM to whiterabbit06 Send a message via MSN to whiterabbit06 Send a message via Yahoo to whiterabbit06
Most Searched New York Times Words and Phrases - The New York Times
whiterabbit06 is offline   Reply With Quote
Old 02-27-2008, 10:06 PM   #11
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
ok so not the most searched but..easy as hell to find definition to
Old 02-28-2008, 03:24 AM   #12
you get the BRAKE
LS_VTEC's Avatar
Ride:  all motor eg6
LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
Send a message via AIM to LS_VTEC
Variable valve timing and electronic lift control
LS_VTEC is offline   Reply With Quote
Old 02-28-2008, 07:54 AM   #13
Yes, that's road salt.
awptickes's Avatar
Ride:  1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
awptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond repute
 FaceBook
Where in germany are you?
awptickes is offline   Reply With Quote
Old 02-28-2008, 09:30 AM   #14
8ballsin's Avatar
myspace
I am in Heidelberg
Old 02-28-2008, 07:09 PM   #15
Ride:  nothing
khrisb is a jewel in the roughkhrisb is a jewel in the roughkhrisb is a jewel in the rough
Send a message via AIM to khrisb myspace
i'm pretty sure I've read somewhere other than wikipedia that honda didn't invent variable valve timing
khrisb is offline   Reply With Quote
Old 02-28-2008, 07:20 PM   #16
HNFTuning
D15Beater's Avatar
Ride:  or die....
Corliss Orville Burandt - Wikipedia, the free encyclopedia
Old 02-28-2008, 07:43 PM   #17
Cogito Ergo Sum Steampunk
Celerity's Avatar
Ride:  1972 Plymouth Satellite, 1988 Jeep Wrangler
Celerity has a reputation beyond repute
Celerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond repute
Send a message via AIM to Celerity Send a message via MSN to Celerity myspace
Aw Pee Tickles and Eight Balls In are together in Germany.
GREAT.
Celerity is offline   Reply With Quote
Old 02-29-2008, 04:39 PM   #18
West West Y'all
I Liked The Video D15Beater. Also Checked Out The Turbo'd VTEC Vid As Well
Old 02-29-2008, 04:52 PM   #19
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
phyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
It is no longer VTEC.
Its "mAd VEETACH off the HiZzY yO!
damn noobs.
Old 02-29-2008, 05:35 PM   #20
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
damn noobs.
LIES!!!
its m@d TyT3 jDm Vt3c s0n!1!1!1!
Old 02-29-2008, 08:29 PM   #21
SlushboxTeggy's Avatar
Ride:  1997 Integra
SlushboxTeggy has a reputation beyond repute
SlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond repute
Send a message via AIM to SlushboxTeggy Send a message via MSN to SlushboxTeggy
There is no way those are the most searched words. They did get one right... Bush. And tit, ass, fuck. End.
SlushboxTeggy is offline   Reply With Quote
Old 03-01-2008, 05:57 PM   #22
•°o.O KOOP™
Koop's Avatar
Ride:  98' D-Series SI (CAN)
Koop is infamous around these parts
myspace
also you will FEEL the v tec kick in. I just figured out today that i had v tec and now i can notice it clearly!
Koop is offline   Reply With Quote
Vtec Solenoid Troubles RandomTask76 HYBRID -> EG-EK / DC 5 05-20-2009 12:05 AM
D15B Vtec swap/boost/vtec/? 93civicracer HYBRID -> EG-EK / DC 396 03-16-2008 11:33 AM
vtec help gabrielaeschliman HYBRID -> EG-EK / DC 14 10-11-2007 12:01 PM
d15b vtec swap questions regal1975 HYBRID -> ED-EF / DA 1 05-23-2006 11:05 PM
LS-VTEC/CR- VTEC Info pissedoffsol General Tech Articles 1 11-10-2002 03:19 AM
