will a si harness fit on a d15b6
Old 03-02-2008, 11:22 PM   #1
jdmcivicef's Avatar
Rep Power: 0 jdmcivicef is on a distinguished road
Default will a si harness fit on a d15b6
jus got a d15b6 and i wanted to kno be4 i tried it .... thanx
jdmcivicef is offline   Reply With Quote
Old 03-03-2008, 12:12 AM   #2
Cogito Ergo Sum Steampunk
Celerity's Avatar
Ride:  1972 Plymouth Satellite, 1982 Chevy truck, 1987 Jeep Wrangler, 1987 CRXSi,
Rep Power: 303 Celerity has a reputation beyond reputeCelerity has a reputation beyond repute
Celerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond repute
Send a message via AIM to Celerity Send a message via MSN to Celerity myspace
Yes. Your only wiring problems in this gen is the DPFI / MPFI wiring. And of course VTEC wiring if you're going to go that route.
The connectors may need to be transplanted if the two are from different years.
Originally Posted by SlushboxTeggy View Post
Cel is the biggest pussy and the biggest bad ass at the same time. He is enlightened and not . He can go after someones mind with scalpel like precision or smash their head in with a rock tied on a stick. The best way to describe him... He is an enigma.
Celerity is offline   Reply With Quote
Old 03-03-2008, 12:15 AM   #3
jdmcivicef's Avatar
i have dpfi.... could i jus swap manifolds off the D15B6????
....thanx
Old 03-03-2008, 03:01 PM   #4
Ride:  89 honda crx si and 94 chevy s10 dropped
Rep Power: 6 sevenhillsbilly will become famous soon enough
as long as you styay with the dpfi most of the dseries parts are interchangeable. once you get to the mpfi you will have harness probs like celerity said.
sevenhillsbilly is offline   Reply With Quote
Old 03-04-2008, 01:44 AM   #5
Plan B
roninallout79's Avatar
Ride:  91 Hatch Si D16Z2
Rep Power: 4 roninallout79 is an unknown quantity at this point
Send a message via Yahoo to roninallout79 myspace
The SI harness will fit on the DX but the manifold needs to be changed over to MPFI. The harness will not hook up to the DPFI mani. But if your already running the MPFI mani just swap the MPFI mani onto the B6 and slap it in.
PLAN B
CURRENT RIDE
91 CIVIC HATCH
PAST RIDES
94 JEEP CHEROKEE
79 JEEP CJ7
80 JEEP CJ7
90 CIVIC HATCH
69 CHEVY C10 LONG BED
82 S10
roninallout79 is offline   Reply With Quote
Old 03-04-2008, 11:40 AM   #6
The Kicker of Elves.
Blanco's Avatar
Rep Power: 222 Blanco has a reputation beyond reputeBlanco has a reputation beyond repute
Blanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond repute
You'll want to make sure they're wired the same, because not all of them are.
It's really not difficult to make the wiring changes to your stock harness.
Don't misinterpret what I say.
Originally Posted by The Secrets of Body Language
93% of communication is done through body language.
Originally Posted by http://humanresources.about.com/od/interpersonalcommunicatio1/a/nonverbal_com.htm
One study at UCLA indicated that up to 93 percent of communication effectiveness is determined by nonverbal cues. Another study indicated that the impact of a performance was determined 7 percent by the words used, 38 percent by voice quality, and 55 percent by the nonverbal communication.
Originally Posted by Shawn Pelton
It's not good to be a drummer unless you got some bad motherfucker up inside you.
Blanco is offline   Reply With Quote
Old 03-23-2008, 02:32 AM   #7
Got V-tec?
monotech909's Avatar
Ride:  Whip!
Rep Power: 3 monotech909 is on a distinguished road
Yeah just make sure to use OBD-0 injectors due to the clips. Thats if you are MPFI Si and just swapping out manifolds. If you don't change the injectors off the D15B6 you will have to change out the injector pig tails to obd-1 grey plugs and eliminate the resistor connection due to saturated injectors.
monotech909 is offline   Reply With Quote
Forum Jump
ecu? AKUMA§KILLERGLASS ECU's, Electronics, and Tuning 11 05-13-2008 02:48 PM
will a si harness fit on a d15b6 jdmcivicef Civic and CRX - EF 1 03-05-2008 03:14 PM
wanted.atuto ecu and harness d15b6 996superhawk Parts: For Sale/Trade/Wanted 2 11-26-2007 09:50 PM
B16A3 harness tie in to D16Z6 harness 93 sick civic HYBRID -> EG-EK / DC 16 07-31-2007 01:00 PM
Is This The Right Harness For Cel Diagnostic? Pics Hybrid93Hatch General Tech and Maintenance 1 04-18-2003 03:11 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
