z6 + hf tranny
Old 10-06-2009, 11:29 AM   #1
Ride:  89 crx hf && 2-85 crx dx
Rep Power: 1 crxhfz6 is on a distinguished road
Default z6 + hf tranny
i have an 89 crx hf with z6 and a 90 si trans. the tanny is at the point now that im just going to replace it. considering that almost all of my driving is to and from school (around 250 miles round trip) i thought that an hf tranny would be nice to get a little better mileage and to quiet things a bit. will any 89-91 hf trans just bolt in or is there going to be anything else that will need changed.
crxhfz6 is offline   Reply With Quote
Old 10-06-2009, 11:33 AM   #2
AHHVTEC's Avatar
it will bolt right up, no problems at all
Old 10-06-2009, 11:42 AM   #3
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
^yep..and then you will be set for mileage and even lower revs
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 10-06-2009, 11:46 AM   #4
thanks a lot. that was easy
Old 10-06-2009, 11:48 AM   #5
AHHVTEC's Avatar
just make sure you use the clutch and flywheel for the tranny you use
Old 10-06-2009, 03:27 PM   #6
also some people have told me not to do this because the tranny would be a weak point in the drivetrain with this motor while others have said it will handle it just fine. is that anything to worry about
Old 10-06-2009, 03:46 PM   #7
D16SiHatch's Avatar
Rep Power: 33 D16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud of
it will be fine, the hf trans is plenty strong enough to handle a z6
91 Civic Si
b18b1, I/H/E, 6000k HID kit, 94 teg cluster
Parting mustang out to buy another civic
D16SiHatch is offline   Reply With Quote
Old 10-06-2009, 05:39 PM   #8
jlicrx's Avatar
the only thing different between HF and other L3 transmissions is the gear ratios
ZCspeed Racing
Old 10-06-2009, 05:53 PM   #9
Senior Citizen
91civisedaner's Avatar
Ride:  1991 civic sedan 1972 datsun 620
Rep Power: 3 91civisedaner is on a distinguished road
If your super worried about it use a DX/LX tranny it's ratios are in between si and hf .
91civisedaner is offline   Reply With Quote
Old 10-06-2009, 11:52 PM   #10
HNFTuning
D15Beater's Avatar
Ride:  or die....
Rep Power: 19 D15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of light
Send a message via Yahoo to D15Beater myspace
A hf transmission should put you around the 2000-2500 rpm range when crusing the interstate. 50-55mph in first gear... Personally i wouldnt think it would be any fun at all to have a HF transmission unless youre putting out the power to fully take advantage of the stretched out gearing....about 220mph, who wants to do that in a civic? According to this calculator anyways
Honda Transmission Calculator by ZealAutowerks
Reference
Honda Tranny Gear Ratios
D15Beater is offline   Reply With Quote
Old 10-07-2009, 01:28 PM   #11
jlicrx's Avatar
the high altitude CRX HF, like we have here in Colorado, has a 3.777 final drive in the transmission - 3rd gear is about like an Si in 4th gear and 4th gear is about like an Si in 5th gear
ZCspeed Racing
Old 10-07-2009, 03:53 PM   #12
do you think that with an almost stock z6 it would be even able to push the car to 220.
Old 10-07-2009, 04:14 PM   #13
D16SiHatch's Avatar
with the front of the car jacked up in the air maybe lol, but other then that not even remotely close. that is a theoretical top speed, assuming there was no friction from the road or air.
91 Civic Si
Old 10-26-2009, 03:20 AM   #14
Rep Power: 5 maykelcj is on a distinguished road
go with the HF. I have a DOHC ZC on my 89 hf and long trips are awesome. nothing like making 80 MPH @ 2500 RPM. The tranny will handle the power, but forget about taking off fast. On the trade off you will get great MPG. Mine with some problem I can't figure out yet, makes 47mpg on highway. just remember to put it in 3rd to pass hahahaha.
maykelcj is offline   Reply With Quote
Old 10-28-2009, 01:26 AM   #15
crxprojectcar's Avatar
Ride:  88 b16a rex
Rep Power: 1 crxprojectcar is on a distinguished road
I think he was convinsed he could go like 220 ... it would be scetchy at 120 without great rubber and suspention plus perfect alignment .. i had my rex at 130 and thats enough fo me, little scary
crxprojectcar is offline   Reply With Quote
Old 10-28-2009, 01:42 AM   #16
Better get some wings cause you are gonna fly!
Old 10-28-2009, 02:26 PM   #17
no i never actually thought i could get it up that high. i was fun enough getting it to 115 with the shorter gears
Old 10-28-2009, 02:28 PM   #18
it was more of a why mention it cause its not really possible
Old 10-29-2009, 10:27 PM   #19
Senior Citizen
has any one ever put hf 5th gear in a si trans?? one of my friends has a gsr trans w/an ls 5th gear.
also the gears in an hf are very close to the si trans just the final drive is different 2.95/3.25ca (si is 4.25)Lx/Dx trans has same gears as si but final drive is 3.88 compared to si's 4.25. now seeing this I want to use a hf trans with a si final drive you can take off fast but gears would be longer and a better 5th for freeway cruise'n
01-05 civic tranny gears swap into 96-00's tranny e jackie late Civic - EP, FA, FG 1 09-28-2009 12:45 AM
WTB: AUTO bseries tranny mount or b18 manual tranny 93integraxchic Parts: For Sale/Trade/Wanted 0 06-23-2007 11:58 AM
gsr tranny to ls tranny swap. cracked bellhousing bannacrx Integra 8 04-02-2007 12:47 PM
Cable tranny on engine that came with hydro tranny. jason22ga Civic and CRX - EF 4 03-25-2007 04:02 PM
Cable Tranny to Hydrolic Tranny Swap slick469 HYBRID -> ED-EF / DA 7 02-16-2004 10:55 PM
