ZC Sohc Swap Questions
Old 07-27-2008, 06:19 PM   #1
Ride:  1990 Civic Hatchback
Rep Power: 0 douglaslovin is on a distinguished road
Default ZC Sohc Swap Questions
I have a 1990 hatchback and it currently has a D15B1 w/ 5sp standard tranny. It's old and junky and the cost to rebuild it exceeds the cost to just buy a swap.
The engine I am looking at getting is the SOHC ZC from hmotorsonline.com Here is the link to the engine I want. http://www.hmotorsonline.com/shop/sc...age&item=30020
It comes with the following:
- Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
- 5 Speed ZC Transmission(Add $200) - I am buying as well.
- Motors (what ever this is)
What else will I need to buy and do to complete this swap?
DPFI to MPFI?
New Axles?
Different Mounts?
Any help is appreciated. Thanks guys!
douglaslovin is offline   Reply With Quote
Old 07-27-2008, 08:39 PM   #2
I made the millionth post
hosmer's Avatar
Ride:  03 350z, 03 CL-S, 02 Excursion, 91 CRX Si, 86 CRX Si
Rep Power: 58 hosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud of
Send a message via AIM to hosmer
DPFI to MPFI and an ECU
motor mounts and axles are the same
-that motor is the same as a D16A6 out of an Si...only difference is the cam which you can pickup for like $100 or get a regrind for yours...
Hold it fellas. I'm afraid you're just too darn loud. Next please. BRING THE NEXT GROUP PLEASE.
hosmer is online now   Reply With Quote
Old 07-27-2008, 09:52 PM   #3
Thanks for the advice. This is going to be an easy swap then.
Forum Jump
sohc zc questions tealed9 HYBRID -> ED-EF / DA 0 05-28-2008 06:22 PM
B18C1 Swap Questions and Gauge/Cluster Swap Questions |Chaz| HYBRID -> EG-EK / DC 14 03-22-2008 12:36 AM
obd1 to obd2 sohc vtec swap questions...what do i need? evodave HYBRID -> EG-EK / DC 9 01-13-2008 11:28 PM
SOHC TURBO BUILD-UP QUESTIONS whos_the_master Engine Building 17 10-10-2004 06:49 PM
Sohc Questions sohcslammer Engine Building 15 06-06-2003 04:25 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
