zc swap problem
Old 11-22-2006, 07:43 PM   #1
Ride:  89 civic dx w/zc
Rep Power: 7 89 hatch is on a distinguished road
Default zc swap problem
I just did a zc swap on my 89 hatch and now i have a rev limiter a 3000 rpm im using a usdm pg7 89 teg computer with a home made dx to si wiring conversion when i had a sohc in with same ecu and wiring i could rev to 7600 with no problem. it also jerks when im trying to stay at a givin speed say like 45mph i replaced the tps but it did change anything. any suggestions
89 hatch is offline   Reply With Quote
Old 11-24-2006, 10:07 AM   #2
jlicrx's Avatar
are you showing any codes at the ECU? like 4 or 9?
ZCspeed Racing
Old 11-25-2006, 04:02 PM   #3
hey i had code 14 and 10 but i redid my wiring and found that i had the map sensor plugged into the iac motor so it runs great now that i switched the pluggs but does any one know how to ajdust the idle? thank alot for your help though
ek swap b18c1 jdm idle problem jdmenthusiast HYBRID -> EG-EK / DC 1 11-05-2006 08:34 PM
90 CRX DX b18b1 swap axles and controol arm problem nathansnation Civic and CRX - EW 3 10-17-2006 01:32 AM
H22a4 SH Swap Problem Sparky2211 HYBRID -> BA-BB /CA-CD 7 08-18-2006 02:32 PM
LS/VTEC head swap problem mdixonjam HYBRID -> EG-EK / DC 3 07-27-2004 04:23 AM
D15 Sohc Non-vtec Head Swap Problem auggiereg HYBRID -> EG-EK / DC 1 02-10-2003 02:30 PM
