| | LinkBack | Thread Tools |
| | #1 |
| Junior Member Join Date: Nov 2006 Location: melbourne Age: 25
iTrader: 0 / 0% Ride: 1990 Civic Hatch
Rep Power: 7 | i have a 90 lx sedan with a d15b VTEC. i was wondering if the zc cable tranny has shorter gears or any other differences than lx tranny. i have to get a different tranny because mine is about to crap out. |
| | #2 |
| Junior Member | I believe the ZC transmission does indeed have shorter gearing. Just keep in mind that the ZC transmission requires different axles than a DX transmission. It actually uses an equal length setup similar to B-series motors. Also, the D15B block may or may not even have bolt holes to mount the intermediate shaft to the back of the block. So a ZC transmission may not even be possible. Your best bet would be to simply run a 1988-1991 SI transmission if shorter gearing is what you want. |
| | #5 |
| Senior Member Join Date: Jan 2003 Location: Raleigh, NC Age: 22
iTrader: 2 / 100% Ride: 88 Honda Civic HB
Rep Power: 195 | Only the DOHC ZC and CG(won't work correctly with regular D-series)has the shorter gears. The SOHC ZC has gears similar to the Si/DX. Only differences are the final drives: Gear Ratios The D15B(and from my experience non of the 88-91 D15s) have holes for the Intermediate shaft, which is different from the B-series one but works with the 90-93 Integra axles. It's not necessary to use the intermediate shaft and Teg axles. What you can do is swap in a big-bearing(EX/Si) differential and countershaft. This will improve the acceleration(from 3.888 to 4.25) and allow you to run the stock axles. This is what I did, but chose a 92-95 EX differential due to the 88-91 differentials having a weak differential pin. Remember to check the shim clearance!
__________________ 1988 Honda Civic Standard-Hiatus 1992 Honda Accord LX-DD Terrorists have successfully attacked our imagination. RIP Jon Eban Nie, August 31, 1991 - May 7, 2006 Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006 |
| Help find s2000 motor and trans | torch26 | s2000 | 11 | 11-04-2008 09:35 PM |
| si trans v/s dx trans | pdqcrx | HYBRID -> ED-EF / DA | 2 | 03-09-2006 08:54 PM |
| trans swap in rex | 88rex | HYBRID -> ED-EF / DA | 8 | 02-08-2005 11:06 AM |
| Leak from a new trans?? | 4DRonDUBS | General Tech and Maintenance | 5 | 03-25-2004 01:13 PM |
| Sir Trans On B16a Turbo | possessed imports | Forced Induction | 9 | 05-04-2003 12:06 AM |
