Carb'd honda's rule
Ride: 1987 CRX base model with HF transmisison
I'm converting my crx to a manual. It's the base model crx from 87 with a d15a2. I'm wondering if an HF manual transmission will fit to my engine since they both have a d15a2, and any other advice would be super great.
I know i'll need the linkage, pedals, and shifter. What else will I need? I've already got the transmission. Thanks P.S. does anyone know a good place I can get an oem used or new flywheel? |
you get the BRAKE
The transaxle will fit, but a mounting bracket may be required. As for the rest, you will need the pedal, cable/rod, all fittings, shift linkage, all hardware and fresh gear oil.
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold |
won't bolt up to the D15A2 engine - not even close
ZCspeed Racing |
#5 |
Watanabe Whore!!!
Ride: datsuns & Subarus
I got a flywheel or two kicking around....if you can make it up to my swap meet in CT on May 17th, I'll just give them to you...and I might have a crap load of other parts you might want or need.
#6 |
Carb'd honda's rule
I went to a junk yard and was pulling parts from a similar 1st gen crx, but it had an ew1 engine. I got the pedals, clutch cable, and the shifter assembly, but it looked like the actual shift rod was in a different place on that transmission. Any ideas if it's different?
#7 |
Carb'd honda's rule
Hey Airjockie I'm super interested in your flywheel offer because I need one bad and don't feel like dropping a tranny at a junkyard and trying to fish out one. is it a flywheel for a d15a2?
| 1987 Civic Hatchback Swap options? | Psycho0124 | Civic and CRX - EW | 6 | 12-30-2007 06:10 PM |
| auto to manual conversion | d112crzy | HYBRID -> BA-BB /CA-CD | 0 | 09-13-2006 11:27 AM |
| transmission swap for 88 prelude | lguyton | HYBRID -> BA-BB /CA-CD | 1 | 03-06-2005 04:04 AM |
| 95 LS transmission Swap | mcash | Engine Building | 6 | 02-03-2004 11:06 PM |
| F22 SWAP TRANSMISSION ??? | onlockdown | HYBRID -> EG-EK / DC | 2 | 09-29-2003 11:49 PM |
