Hey i am new to the site and was wondering if it is hard to do a b18 swap on these cars. I found a Integra i think its 92 with a b18 automatic. How can i fabricate engine mounts for it? And what axles do i use?
TTIWWOP
Ride: 90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
hasport.com has the mount kit
review the installation instructions for details on axles etc __________________
I'll blow a hole in your face then go inside and sleep like a baby. |
#4 | |
Brutal Moderator
Ride: 97 Integra LS Coupe
Check out the site the other guy pointed you towards, they have a mount kit that will make the swap easy and if you read their instructions it should tell you what axles can be used. |
#6 |
Brutal Moderator
Well if you want low budget then I'd say you should probably try and fab something up. If you're good with cutting and welding metal then you could probably do it yourself, otherwise let a machine shop or performance shop do it for you, although that will cost you for labor.
I don't know how low budget you can really get with this unless you're able to fabricate mounts yourself. |
#7 | |
#8 |
you could probably fabricate the mounts yourself - look at this and you can see what the needed mounts look like:
Installation instructions for i believe you will run into a serious problem if you try to use the B-series automatic transmission - the B-series manual transmission sits right next to the passenger side frame rail and the automatic is quite a bit larger than the manual - you cannot move it toward the driver's side to get the transmiision to clear since you will already need to bash in the driver's side frame rail in order to clear the alternator - if the car is not the Si model, you will have a nightmare with the wiring and you will need the complete fuel system (tank, pump, lines, etc.) out of a Si model to swap into the car - only the Si used a pressurized fuel system which you need to work with the fuel injection - you will need to swap out the knuckles/hubs for ones from 86-89 Integra in order to use the larger Integra axles - there are no stock axles that will fit with a B-series engine in a 3rd gen Civic - you will need custom axles you would be much better off to swap the 86-89 Integra D16A1 engine and transmission into the car - it will bolt right in using the stock mounts, using the stock 86-89 Integra axles , knuckles/hubs and shift linkage, since the 86-89 Integra used the same chassis platform as the 3rd gen Civic/1st gen CRX - it would still be a major job with the wiring and fuel system, but nothing like trying to install a B-series with automatic __________________
ZCspeed Racing |
#9 | |
#11 |
I think i am not going to swap a b18 because the guy that is selling the dam car is asking 800 for it and the car doesn't start. And he doesn't call me. So i am looking into a 87 integra with 5 sp tranny, started to search on tuesday so i don't know whren i will get the owner of that car, gave him my number yesterday to call, but nothing yet. Still looking.
#13 |
#15 |
Hasport sells the mounts for 600 bucks, but its easier to make your own for the b18. The zc engine will swap with only changing the tranny mount.
#16 |
#20 |
#23 | |
HNFTuning
The hardest part of a b series swap in the 1st gen rex is wiring the electrical advance distributor and changing the crx spindles out for the 86 integra ones. Down hill from there on, youll need a custom set of axles. |
#24 |
SO now youre going to use a 1-gen teg body?? or just the engine/trans?
Get the front suspension out of the teg if you use the civic. It will swap right in and you'll have a bigger swaybar and pwr steering. If it's a civic hatch, use the rear complete axle with e-brake cables. If youre intrested, I have a pair of Eibach rear civic springs that I'm not going to use. Pm me if you want. E __________________
"If you can read, thank a teacher" "If you can read it in English, thank a VET" |
#25 |
Brutal Moderator
This thread is from three years ago guys, and I don't see any need for it to be resurrected, so it's getting locked. 86 white rex, please check the dates on threads before you hit "Reply" from now on. Feel free to start a new thread in the appropriate forum though...
| 99-00 civic Si cluster swap into EF How To (pics0) | B18C5James | HYBRID -> ED-EF / DA | 30 | 07-11-2007 06:25 PM |
| 88+ ECU Error Codes | pissedoffsol | Reference Materials | 1 | 05-19-2005 01:03 PM |
| 94 CIVIC COUPE 4 SALE!!! B18 SWAP IN NJ!!! | randxvtec | Vehicles: For Sale/Trade/Wanted | 0 | 02-15-2005 01:26 AM |
| 6th gen Civic Basic swap overview | pissedoffsol | Swap Articles | 0 | 01-12-2004 02:14 AM |
| Chassis Code | VSMB16A2 | General Tech and Maintenance | 10 | 01-22-2003 05:32 PM |
