85 si cam gear on later 1500??
Old 10-13-2009, 07:59 PM   #1
Rep Power: 14 78civic will become famous soon enough
Default 85 si cam gear on later 1500??
Good evening. I was rummaging thru my shtuff and found a adjustable cam gear from a 86 civic si I sold a while back.
Will this gear work on my later D15b2??
I'll be doing a timing belt change soon (well, when I fix the ECU problem..) SO I can swap it on at that time if it will work.
And on a STOCK cam, how many degrees adv should I make it?
I had it at 3 for the last engine but it had a little work done to it.
Thanks.
"If you can read, thank a teacher"
"If you can read it in English, thank a VET"
78civic is offline   Reply With Quote
Old 10-13-2009, 09:01 PM   #2
HNFTuning
D15Beater's Avatar
Ride:  or die....
Rep Power: 19 D15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of light
Send a message via Yahoo to D15Beater myspace
No but it will fit a f series engine. I ran a F22a1 timing gear on my 85 Crx si with no problems at all, I thought a lighter cam gear would cut parasitic drag....blah blah blah.
D15Beater is offline   Reply With Quote
Old 10-15-2009, 01:52 PM   #3
So, how many degrees did you advance it? Did you have an aftermarket cam in the 85?
Did it mess up the timing enough to widen out the holes that tighten it to the head? i had to do that to my older 89 prelude.
On the older cvcc's you could jump it a tooth or so where the cam and driven gear and even had adjustment under the head of the 'dizzy'.
E
Old 10-15-2009, 02:13 PM   #4
HNFTuning
D15Beater's Avatar
Ride:  or die....
Didnt do anything at all to it, the F22 timing marks, and tooth count are the same as the D15a3/EW4
Old 10-15-2009, 10:03 PM   #5
I'm sorry, i thought it was adjustable.
E
Old 10-15-2009, 10:25 PM   #6
HNFTuning
D15Beater's Avatar
Ride:  or die....
What im saying is the F22ax adjustable gears work on the D15a3/Ew4 camshafts...
$1500 bike AHHVTEC Motorcycles 4 01-09-2008 09:23 AM
FS: drag kit, b18, $1500 gregprep29 Parts: For Sale/Trade/Wanted 3 12-09-2004 01:10 AM
89 CRX SI w/ b16 $1500 Bri94lst Vehicles: For Sale/Trade/Wanted 14 07-31-2004 04:08 AM
1500 turbo set-up? possible? SPEEDFREAK0920 Forced Induction 25 07-05-2004 03:48 PM
Possible swaps in 91 dx HB for around 1500 Bri94lst HYBRID -> ED-EF / DA 15 12-05-2003 02:30 PM
