87 civic si at a loss
Old 08-24-2009, 11:37 AM   #1
Greenhorn
Rep Power: 0 87civicsi is on a distinguished road
Default 87 civic si at a loss
ok iv got an 87 civic si ran great no smoke, dident burn oil, car over all ran good, well last night i was letting a buddy of mine drive it and he was at about 5000 rpm in second gear and went to first insted of third some kind of way well directly he pressed the clutch back in and the car died and now when you turn the key the stater just winds and wont turn the motor it wont jump off neither i have no clue what it is the timing belt is still on i pulled the valve cover the rocker arms arent loose and i pulled the plugs none were crushed im at a loss plz hheeeeelllppppp!!!!
ps. when i put it in gear and turn the key it jumps forward so that eliminates the fly wheel right
87civicsi is offline   Reply With Quote
Old 08-24-2009, 12:45 PM   #2
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
compression test?
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 08-24-2009, 02:16 PM   #3
Rep Power: 14 78civic will become famous soon enough
Sounds like your 'buddy' needs to help you pull the starter and look in there to see if the T/O bearing got cocked at the end and won't release back. Was the clutch pretty worn already?(adjusted up all the way?) He may have toasted it for you..
Can you shift it to any other gears including R?
E
78civic is offline   Reply With Quote
Old 08-24-2009, 02:53 PM   #4
he cant even start the car.
Old 08-24-2009, 06:22 PM   #5
Greenhorn
i just put a clutch in it so dont think it would be the clutch. and also how would u do a compression test if it wont turn over and when me and my buddys where pullin home it would run as we where pullin it but when i push in the clutch it shut off
loss of gears JDMB20Coupe Civic and del Sol - EG and EK 7 07-07-2008 11:00 AM
ECU - at a loss civicnoob Civic and del Sol - EG and EK 2 05-02-2007 05:31 PM
loss in 12v power Dark91zc ECU's, Electronics, and Tuning 2 01-23-2006 10:51 PM
Loss Of Rpm's When Stopping crxracing77 General Tech and Maintenance 10 03-18-2003 09:53 AM
