advice please
Old 11-25-2007, 02:14 PM   #1
crx modding
Ride:  1990 Honda CRX HF
Rep Power: 5 1990.honda.crx.hf is on a distinguished road
Send a message via MSN to 1990.honda.crx.hf
Arrow advice please
I am new to the tuner concepct and I am looking to beef up my 1990 Honda CRX HF but I am at a lost. it has the d15b6 engine in it. I am planning on later doing a body and suspension mod but I am at a lost as for the motor. I don't know if I should just keep the motor in it or swap. I do know that what ever I do I will want to keep the working AC and PS. Any ideas will be helpful.
1990.honda.crx.hf is offline   Reply With Quote
Old 11-25-2007, 03:53 PM   #2
AHHVTEC's Avatar
1st gen b16a
Old 11-25-2007, 03:56 PM   #3
ej1-94's Avatar
Rep Power: 5 ej1-94 is on a distinguished road
couple of options
1 turbo kit
2 b16a
or go all out and get a GSR or Civic Type R (B16B) or Integra Type R (B18C5)
CousCous the food so good they named it twice
ej1-94 is offline   Reply With Quote
Old 11-25-2007, 04:03 PM   #4
AHHVTEC's Avatar
or a jdm itr b18c.. or with money k20
Old 11-25-2007, 04:05 PM   #5
ej1-94's Avatar
i agree, but some turbo SOHC will beat a k20. 200 WHP SOHC with ls rods and Vitara pistions.
Old 11-25-2007, 04:08 PM   #6
AHHVTEC's Avatar
true because ive saw 400+whp sohc motors....but for the ts the least amount of money and ease to swap will be a b series motor. all you will have to do is run a wire for vtec on some motors. but its a very easy sawp to do.
Old 11-25-2007, 04:53 PM   #7
Rep Power: 12 Dasfinc will become famous soon enough
You realize thats an 8 valve head on his car right?
MiniMe swap and ECU, LS Rods Vitara slugs, and a Transmission that doesn't suck= $800+
D16Z6 engine and a cable SI trans = 400-800 and there's alot less work if you just do the whole thing, I learned this lesson the hard way, Lol..
Teggy Powered Civic CX Hatch, and a 07 Ford Focus.
Check out my Mini-Me Write-up!
http://hondaswap.com/hybrid-eg-ek-dc...rite-up-96144/
Check out my B18B1 Swap Write-up!
http://www.honda-tech.com/zerothread?id=2239971
Dasfinc is offline   Reply With Quote
Old 11-25-2007, 09:07 PM   #8
crx modding
[quote=Dasfinc;897373]You realize thats an 8 valve head on his car right?
quote]
Are you saying that I have an 8 valve head on my D15B6?
Old 11-26-2007, 03:13 PM   #9
ignore
Ride:  90 crx si, e36 m3, cbrF3, 87 civic gl
Rep Power: 12 charleskwinter has a spectacular aura aboutcharleskwinter has a spectacular aura aboutcharleskwinter has a spectacular aura about
myspace
if you are new to tuning the last thing you want to do is complicate your life with an engine transplant... unless you happen to be a mechanic that is new to what some call the 'import' or 'tuner' scene. i don't know you personally but the impression is... you need to learn a few things before you start transplanting.
i once had a book that was about tuning your honda. the MOST IMPORTANT thing about this book is that it detailed this author's opinion of the proper steps for tuning your honda. the book started with basic air filter and exhaust modifications and gave direction for general tuning. although you managed to purchase the lowest hp motor, i have seen from europe that you can get a lot of relative hp/weight power from small displacement. keep in mind that mini coopers (the originals) are 1.3l.
keep in mind you want to have fun driving this car. save some energy for suspension and maybe some gentle 15" wheels.
point being, keep it simple, and as always, this is only my opinion and i hope it helps...
-edit- for future reference your car should not and probably does not have power steering so no needs to worry about that. and it is in good taste to not add a body kit to the crx... take some crx si parts and 15 or 16" wheels, slightly lowered and it looks like a different car. just my opinion.
charleskwinter is offline   Reply With Quote
Old 11-26-2007, 03:54 PM   #10
[quote=1990.honda.crx.hf;897468]
quote]
Yes, I am.
8 valve heads have Zero potential.
Old 11-26-2007, 04:03 PM   #11
ignore
myspace
as for the other 1.5l article that is similar... i say again. start with making modifications that are interchangeable with other transplants. and although an 8 valve head is not ideal, it is still capable of more power than stock.
-intake
-exhaust (maybe even header)
-suspension and 15' civic si wheels...
make the car fun to drive!!
Old 11-26-2007, 04:14 PM   #12
I'd strongly suggest doing the MPFI Swap at very least.
Old 11-26-2007, 04:28 PM   #13
AHHVTEC's Avatar
he has a hf its already mpfi
Old 11-26-2007, 04:29 PM   #14
AHHVTEC's Avatar
just buy a jdm d15b and be done with it maybe put a 1200 buck turbo on it and wax ass all day
Old 11-26-2007, 10:14 PM   #15
ej1-94's Avatar
i agree with everyone here...
if you want to get your car to breathe right. do the MPFI conversion, go with the 99-00 EX intake manifold (d16y8) and same exhaust manifold (unless header), those are some of the cheapest, and best working (best bang for buck)... those are know as the OEM type R parts
Old 11-26-2007, 10:50 PM   #16
AHHVTEC's Avatar
dude read he has a hf its already mpfi
Old 11-26-2007, 10:54 PM   #17
übber ɐɾuıu etarip
Z6CRX's Avatar
Ride:  1995 BMW 318ti, 1985 Honda VF500F(now legal)
Rep Power: 73 Z6CRX has a reputation beyond repute
Z6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond repute
Send a message via AIM to Z6CRX Send a message via Yahoo to Z6CRX myspace  FaceBook
WTF..
HF's were MPFI already.
DX and STD were DPFI.
In the end it all turns out to be your budget and ability that will limit you.
D would probably be the most cost effective.
Originally Posted by Celerity View Post
No one hates anyone around here more than people hate Celerity. He's an asshole.
Z6CRX is offline   Reply With Quote
Old 11-27-2007, 02:13 AM   #18
Rep Power: 13 blackice90HB is an unknown quantity at this point
Two choices
DOHZ ZC
D16Z6
turbo whichever you choose and kick as all day. D16Z6 needs some minor wiring mods, ZC is plug and play (well minus the dizzy connector but if it comes with a harness you are good to go). And you can use your stock mounts and tranny. Yay....... cake!
Im gonna redline inline 4's until I flatline.........
1990 Honda Civic STD Hatch
DOHC ZC, Finally
PG7 ECU,
Neuspeed Springs
Currently hunting for 16"/17" Enkei OR52's and a camber kit
*vouches for sellers:* HatchSpeeD, B16RacerN2NR, Phyregod
blackice90HB is offline   Reply With Quote
Old 11-30-2007, 10:10 PM   #19
crx modding
Just because I an new to tuners does not mean i am new to custom vehicals. I have had many modified lowriders with more engine then needed. I just am new to imports. It shouldn't be assumed that if someone asks questions and is honest about not knowing everything about engines, that this would be someone's first car. The pride of my toys is a 1996 S10 with a blown 454 tubed, dropped, and setup for spray.
Now that that has been said... I like the ZC idea but I wonder, is it DOHC? and what did it come out in ( from factory )?
Old 11-30-2007, 10:13 PM   #20
crx modding
on another note my hf already has a K&N Airfilter and a set of 17 in Racing Wheels. but it is not enough I have already been looking at a baffeled tip muffler for it and or a cat black exuast system.
Old 11-30-2007, 11:23 PM   #21
ambitious...but rubbish
hatukazi's Avatar
Ride:  91 Si hatch GSR swap
Rep Power: 17 hatukazi is a jewel in the roughhatukazi is a jewel in the roughhatukazi is a jewel in the roughhatukazi is a jewel in the rough
myspace
see if you can trade those 17's for some 14 or 15's and I didn't notice any one suggesting a tranny swap, but an Si tranny will make it feel quicker.
rear disk brakes help alot too, and easier to work on.
hatukazi is offline   Reply With Quote
Old 12-01-2007, 12:38 PM   #22
crx modding
I already have an SI Tranny in it. The factory tranny went out and it was the only replacement I could get, lucky me. and I am currently trying to get this other CRX Si that has title issues for parts, but I would like to know what car did the DOHC ZC engine come out factory in, and what liter is it? It would make it easier for me to find one if I knew.
Old 12-01-2007, 01:08 PM   #23
übber ɐɾuıu etarip
Z6CRX's Avatar
theres a DOHC ZC
pretty much all D series your going to find are 1.5 or 1.6, and the occasional 1.7 single cam.
pre 90 integra's had the DOHC and I don't remember what was all involved in the swap.
You can always swap the head off of your for a SOHC Vtec head, or a DOHC if you can find the right one. Just getting a longblock should be less time consuming though.
Also, how does your HF have power steering?
Old 12-02-2007, 09:18 PM   #24
crx modding
Is it possible to swap a SOHC head for a DOHC head on a D15B6 block to make it a DOHC engine?
Old 12-02-2007, 09:28 PM   #25
ignore
myspace
if you are getting an si for parts, it would be nice to put that d16a6 in the hf and all other si parts, esp the seats!! i think the si seat is one of the best seats eva
-me
oh, and use this site better, search "engine codes" for all honda hearts, the bodies they came in, and more!
Need some Tranny advice??... PLT-1 Civic and CRX - EF 2 07-13-2009 10:54 PM
Repainting some parts, need advice SlushboxTeggy Body / Exterior / Interior / Cosmetics 14 06-18-2007 08:10 AM
Old man looking for advice Alans97 General Tech and Maintenance 27 09-18-2006 08:37 PM
a little advice turbodreams HYBRID -> BA-BB /CA-CD 8 08-18-2006 08:27 PM
Finally Done!!! Need advice for the next step. leonc HYBRID -> EG-EK / DC 9 09-03-2005 01:58 AM
