D15A2 12 valve holes in head
Old 02-02-2008, 07:23 PM   #1
Rep Power: 0 itjstagame is on a distinguished road
Default D15A2 12 valve holes in head
I want to try Somender's Grooves out on my DX head, for fun and because the head is already off and well why not because if I grenade the drivetrain it's an excuse to look for a D16A1 and transmission.
Anyway what's involved is adding grooves like this http://themoportal.com/articles/sing...-groove_sm.jpg in the squish area to try and get the flame front to move more easily there and make the compression a bit more efficient. You can read more here if you like: Somender SINGH: Squish Zone Grooves: 20%+ improved performance of IC Engines -- 3 articles & US Patent
Anyway as you can see in the attached pictures, there isn't too much squish area on our heads but I think I can put one right in the center of the squish area and aim it toward the spark plug, similar to this other one with a small amount of squish area: http://img291.imageshack.us/img291/4571/grooovesys6.jpg
There is this tiny hole right where I would like to make my cut and as you see in the other attachment there's these 'dead valves' that do get moved by the cam shaft and I was wondering if this hole goes all the way through and if it will cause me problems. Will I be ok if I groove near this hole. Should I fill it with JB Weld or block it off somehow? Does the 'valve' actually actuate and move up and down this hole?
Anyone know, I'm looking for thoughts. Otherwise I can just do two small cuts but just curoius if anyone can tell me about these holes and 'dead' valves.
itjstagame is offline   Reply With Quote
Old 02-02-2008, 10:51 PM   #2
HNFTuning
D15Beater's Avatar
Ride:  91 B7/Y8 mini Hatch
Rep Power: 13 D15Beater has a spectacular aura aboutD15Beater has a spectacular aura aboutD15Beater has a spectacular aura about
Google CVCC .....youll find everything you need to know.
D15Beater is offline   Reply With Quote
Old 02-04-2008, 08:21 AM   #3
Wow, that's crazy. I couldn't find too many sources but I get the main idea of stratified charge. I went out and put a spark plug in and was suprised I couldn't see it, so I guess that protrudes into a cavity and I think that large 'spark plug' looking hole in the head and that small hole are connected and the 'dead valve' actuates and injects a richer mixture and ingites out of these holes. So maybe my grooving isn't needed if there's already a hole here in the squish area.
Does anyone know a bit more about CVCC, like how exactly does it inject into a fully pressurized cylinder and where does it pull the charge from, I don't see any intake runner along that 'dead valve'.
Forum Jump
WTB D16A6 Complete Head A.S.A.P ! Or ANY SOHC 16 VALVE COMPLETE HEAD egrob94 Parts: For Sale/Trade/Wanted 0 12-11-2006 12:33 AM
Which valve seals for a B16A head? civicious General Tech and Maintenance 2 11-09-2004 12:47 PM
B16a2 valve springs in a 99 ls head Sed8ed Engine Building 2 12-22-2003 08:00 PM
LS-VTEC/CR- VTEC Info pissedoffsol General Tech Articles 1 11-10-2002 03:19 AM
valve lash specs for Y8 (99 Ex) head? teal_dx General Tech and Maintenance 3 10-23-2002 02:18 PM
SEO by vBSEO 3.2.0
 | a SkeyMedia Network site
