Facebook Twitter
EW1 vaccum lines
This is a discussion on EW1 vaccum lines in the Civic and CRX - EW forum
i bought a 1985 crx hf a few months back and i am somewhat new to the honda cvcc engines, i have done a lot of reading about them and understand how they work. i am wondering if anybody has removed all the vaccum lines ...
Old 05-06-2010, 11:02 PM   #1
Default EW1 vaccum lines
i bought a 1985 crx hf a few months back and i am somewhat new to the honda cvcc engines, i have done a lot of reading about them and understand how they work. i am wondering if anybody has removed all the vaccum lines and black boxes and only kept the necessary items for basic carb operation. i know the carb concept is not basic but i am a certified mechanic so i can figure things out and make it work. just wondering if someone else has done it before. thanks for input
tasertotts is offline   Reply With Quote
Old 02-17-2011, 11:44 AM   #2
New to the forum too.
Debatting about the same question as this carb is an absolute headache, or should I say that the carb control system is too much to deal with as the carburation controls mostly the amount of air that is passing thru various ports and valves.
I am failing smog for High NOx as the engine is running lean, the smog tech said that a new cat may fix it.... May be, may be not.... the egr is working and the O2 sensor is cycling. So for the price of a new cat I can get a weber...
Michel
86 civic DX
letank is offline   Reply With Quote
Old 02-17-2011, 12:25 PM   #3
TurboMirage's Avatar
Red Pepper Racing has a full how to on desmogging the carburetor. Not recommended in colder climates though.
Old 02-17-2011, 02:12 PM   #4
DarkHand's Avatar
Or in a state where you need to get visually inspected. You'll fail right off the bat.
It makes working on the car 2459783489573458903459083493845 times easier though.
DarkHand is offline   Reply With Quote
Old 02-18-2011, 10:57 AM   #5
hosmer's Avatar
I de-vac'd my browntop ZC and the car idled better...it would search I'm sure because of a dry rotted/cracked vacuum line
hosmer is offline   Reply With Quote
Old 07-10-2011, 05:55 PM   #6
Just did mine, runs a whole lot better.As long as the car does not require an emissions test, remove all that junk. If that does not help, then get a weber carb, So far the stock carb is working fine with all the junk removed.
Elwood is offline   Reply With Quote
Vaccum lines 90b16acivic HYBRID -> ED-EF / DA 4 04-18-2005 12:29 PM
vaccum lines? CRX2NR18 ECU's, Electronics, and Tuning 3 04-26-2004 06:37 PM
Vaccum Lines the_rail HYBRID -> ED-EF / DA 0 04-23-2004 06:22 PM
Vaccum lines 92civicb18b1 General Tech and Maintenance 4 11-13-2003 10:53 AM
vaccum lines rudeludenotmeanthough General Tech and Maintenance 4 01-03-2003 02:45 AM
© 2001-2013 HondaSwap.com
