HELLLPPPP Please 1990 crx Si obd conversion problems
Closed Thread
Old 08-31-2009, 07:26 PM   #1
Rep Power: 8 Schock3 is off the scale
Default HELLLPPPP Please 1990 crx Si obd conversion problems
Ok. I have a 1990 crx Si w/b16a have been installing a rev hard turbo kit and it is finally competed and sitting. I have bought 450cc injectors and a p28 basemapped for turbo and converted to obd1 with a rywire harness. I have also purchased a TD-44U Dizzy. when i got done the car started. when i went to pull it out of my garage it would bog...i didnt even make it 5 feet out of the garage and it died. NO CEL'S! checked everything but to see if i was getting spark because i have no idea how to check with just one person. I feel that the problem is in the dizzy because after i installed the 450cc injectors when i was still obd0 everything was perfect running like a champ. so.. the wires i have for the dizzy on the engine side are ( yel/grn, blue, blue/yel, Tan, Wht, Wht/blue, Tan/Blue) Ive been searching (on here and on google) and found a few things like OBD0 to OBD1 Distributor Wiring - Honda-Tech
did what it said and the car would just crank and crank. I found something else and got it to start and thats when the problems started. someone PLEASE help me out. thanks guys
Schock3 is offline
Closed Thread
1990 CRX SI D16z6 error code problems 8ballsin HYBRID -> ED-EF / DA 4 03-17-2009 04:21 PM
helllpppp MiamiEgGSr Civic and del Sol - EG and EK 2 08-20-2007 07:29 PM
1990 teg,gage cluster problems Ls/teg Integra 1 02-01-2007 03:33 AM
1990 crx si problems phairse General Tech and Maintenance 11 08-07-2006 05:24 PM
1990 crx si engine problems cameronman General Tech and Maintenance 3 07-30-2005 04:02 AM
