i need help
Old 05-14-2008, 10:40 AM   #1
Ride:  89 si rex 93 sol
Rep Power: 0 rexinitup is on a distinguished road
cool
rexinitup is offline   Reply With Quote
Old 05-14-2008, 10:54 AM   #2
t3t4delsol's Avatar
Ride:  97 del sol si turbo / dd is a 95 eclipse gsx
Rep Power: 11 t3t4delsol has a spectacular aura aboutt3t4delsol has a spectacular aura about
so what do you idle at? Im not really sure what your saying, we need more information on the problem
t3t4delsol is offline   Reply With Quote
Old 05-14-2008, 11:28 AM   #3
Crusher of Noob Ambitions
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 145 BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
Provide more information please. Plus, you're in the wrong forum. This area is for pre-88 Civics and CRXs. You want the forum below this one...
If you find something I say helpful, please rep it up!
97 Integra LS Coupe:
*AEM Intake/Megan Header/Magnaflow Exhaust
*Tokico Shocks & Springs
*Megan Strut Braces & H-Brace
*98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys)
Old 05-14-2008, 11:40 AM   #4
all sorry man im new dont know what to do lol
Old 05-14-2008, 11:45 AM   #5
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 40 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
I think he is trying to say it breaks up until 4-5k rpm. Could be many things, fuel, ignition, ecu etc. Need more information to help you.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 05-14-2008, 12:03 PM   #6
yeah basically.and i think it has to do with the injectors one of my plugs was diffrent not the one 2 the resistor box butthe outher one coming off the injectors so i wasent giting fuel 2 them. so i cut them and wired them together and got fuel. i hav 2 wires left over the ingen harnes had four and the car harns had six.can find diagram
Old 05-14-2008, 12:10 PM   #7
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
You need to solder those injector clips on. Twisting them together is not the proper way to do it and you will most likely encounter problems later on. You need to make sure, since I think your running obd0, to use an obd0 distributor and obd0 injectors along with the obd0 ecu. Everything must match.
Old 05-14-2008, 12:34 PM   #8
sorry 4 not being vary detaild a just got regester last night and still figuring stuff out.yeah its all obdo i used stock crx si ingen harness avery thang pluged in besides the plug neer the resitor boxs the plug it goes 2 is a difrent shap. the ingen harness had 4 wires and the car harness had 6 so i cut them and wired the 4 injecter wiers togeather and left the outher 2 wires off and it started and runs but it wont rev its got 2 be them 2 wires do you know what thay r
Old 05-14-2008, 12:57 PM   #9
was that not good info lol
Old 05-14-2008, 03:33 PM   #10
Rep Power: 0 hondalove9896 is on a distinguished road
so basically your saying it slowly creeps up to 3 or 4 grand and once it hits that then it revs fine. but when its under 3 or 4 grand its not really bogging down but it sounds like its bogging up. i think what your problem is, is that your wiring harness is wrong. cause if it was the proper one everything would connect properly. those other 2 wires possibly could be another main source of power but im not for sure on that. but they are definately there for a reason.
hondalove9896 is offline   Reply With Quote
Old 05-14-2008, 03:46 PM   #11
yeah thanks man
Old 05-14-2008, 03:49 PM   #12
thats my best thought for it. ide love to be able to help you out man but it could be a bunch of things. are you sure that everything you have is obd0
Old 05-14-2008, 03:58 PM   #13
yeah just cheked
Old 05-14-2008, 04:03 PM   #14
do u know of what wirering harness i might try i used a integra harness on my last one but it dont work on this one
Old 05-15-2008, 07:41 AM   #15
honestly i dont know, your best bet would be to order a crx ls conversion kit.
Old 05-15-2008, 07:43 AM   #16
that way you would have less hassel trying to figure out which wiring harness you need to get and everything.
Forum Jump
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
