Leaking tail lights on 1986 CRX
Old 05-05-2008, 11:48 PM   #1
Ride:  Old old Reliant, Bonneville, hopefully my 1986 CRX
Rep Power: 0 1986CRXHF is on a distinguished road
Smile Leaking tail lights on 1986 CRX
I have a 1986 CRX HF and I'm getting water in the wheel well where the spare tire is stored. What can I use to reseal the tail lights or are the gaskets an item I can order from the Honda dealership? Any idea where I can get an original replacement Honda hubcap(about 6"-8") diameter which came with the car? I only have three of them. Don't know what happened to the fourth one. Thanks for any help. Gary
1986CRXHF is offline   Reply With Quote
Old 05-06-2008, 07:48 AM   #2
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 43 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
There is a flood port (hole) in every trunk and is usually sealed completely with a rubber seal or a grommet. When it rains, sometimes (when un-sealed) will splash water inside. Could also be leaking from the hatch seal, as specified by Scott. Take a look around the back and look for water residue and track where its coming from.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 05-06-2008, 10:49 AM   #3
It does look like its coming from the tail lights. No stream or mark where water has seeped down from the hatch at all. I did have a leaking 3rd light but I sealed that up already. Thanks for any more ideas. Gary
Old 05-06-2008, 12:07 PM   #4
..is grounded.
dacheat's Avatar
Ride:  '84 buick (rusted)
Rep Power: 268 dacheat has a reputation beyond reputedacheat has a reputation beyond repute
dacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond repute
i went the opposite way with my taillights; i've had three different hondas that have had taillights that collect rainwater. i didn't seal 'em, i drilled holes in 'em . you can drill a small hole in the bottom of the taillight and the water will just drain down the back bumper. can't see the hole, no stress.
marco....
dacheat is offline   Reply With Quote
Old 05-06-2008, 01:23 PM   #5
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
For the hubcap, have you tried E-Bay? It's worth a shot...
PSN Network ID: BrutalB83
Old 05-06-2008, 02:56 PM   #6
OEM clean
Ride:  88 honda CRX
Rep Power: 4 SIRandy is on a distinguished road
Send a message via AIM to SIRandy myspace
my 88 crx has the same problem and its coming from the hatch seal cause i can see where its driping from its coming from where the hatch shocks are located so i have to put some clear silicone or replace the entire seal.
SIRandy is offline   Reply With Quote
Old 05-06-2008, 06:38 PM   #7
Cogito Ergo Sum Steampunk
Celerity's Avatar
Ride:  1972 Plymouth Satellite, 1988 Jeep Wrangler
Rep Power: 347 Celerity has a reputation beyond repute
Celerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond reputeCelerity has a reputation beyond repute
Send a message via AIM to Celerity Send a message via MSN to Celerity myspace
I get the idea that the leak isn't coming FROM the taillights (You have rust or any other water gathering in place?) so the leak is coming from AROUND the taillight.
That would the trunk seal. I promise you. Or you have a rot hole behind the taillight (You would see it when you remove the taillight inspection panels) and the water is running off the mounting bolt into the bodies steel.
Originally Posted by SlushboxTeggy View Post
Cel is the biggest pussy and the biggest bad ass at the same time. He is enlightened and not . He can go after someones mind with scalpel like precision or smash their head in with a rock tied on a stick. The best way to describe him... He is an enigma.
Check out my new Steampunk experiment: http://www.pandora.com/people/steven.earl#
Celerity is offline   Reply With Quote
Old 05-06-2008, 08:41 PM   #8
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
dont forget that the OEM foam gasket may be disintegrated back there. on my 1st crx i had that issue. i ended up running thin, wide bead of silicon around the metal areas where the taillight met the body. make sure you get the flexible kind otherwise it wont seal right, or it will push the taillamp out.
i actually did this to my mirage not too long ago. a fucking 2000 and the dealer doesnt sell the foam gaskets anymore.
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
1990-93 Acura Integra 2-door tail lights tail lights RSS-Bot Auctions 0 03-10-2008 01:43 AM
94+ Acura Integra Gsr B18c1 Tail Lights Tail Lamps Vtec RSS-Bot Auctions 0 02-10-2008 12:43 PM
aftermarket head lights and tail lights. fastshift Accord 7 02-04-2008 02:09 AM
Which state is it ok to have blacked out tail lights and head lights? tofasttoslowforyou Members' Lounge 12 11-12-2007 06:17 PM
tail lights/corner lights esp4life ECU's, Electronics, and Tuning 8 09-25-2005 02:05 AM
