Ride: 86 CRX Si/94 Integra
what, if any are solutions for squeaky belts? im hoping its nothing bad and easy to fix. its so annoying.
Regular Member w/ Cheese
Ride: 2000 EJ8 w/ SiR-II
yeah use the tensioner bolts to either tighten or losen them, depending on what they need. i'd go get a haynes or chilton manual from your local auto parts store. it tells you how to do this and many other simple maintence tasks.
![]() maybe some STP belt dressing if they look to be dry. helps them last longer. |
#9 |
HNFTuning
#11 |
the belts seem fine. no cracks and seem tight. so..spraying wd-40 on the elts as it runs will help stop the squeaking? i live in phoenix az, and the temp is already warming up. that might have been a factor.
#12 |
you get the BRAKE
Wow you guys are seriously on drugs. In no way do you ever lubricate a drive belt. Especially the timing belt. If it is making noise adjust the tension accordingly. If that does not correct the issue, replace the belt and tensioner.
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold |
#13 |
There are products made to put oil and moisture back in your belt and prolong the life, like STP Belt Dressing. LS_VTEC, you sayin no to that too? I'm talkin acessory belts, of course not a timing belt!
WD-40 and brake cleaner i still think would hurt. |
#14 |
you get the BRAKE
Any oily lubricant will cause a belt to "slip". Have you ever taken any ASE tests? They have questions on the engine performance test about lubricating drive belts. It is a "no-no".
#15 |
no i've never taken ASE tests. i've taken MCSE tests. i'm not a mechanic. i build computers for a living :P
damn i really thought the stp stuff would help prevent against dryrot so quick in our horrible environment in the northwest. myth eh? it did seem to help some in my mom's odyssey and a few of my friend's cars. |
#16 |
you get the BRAKE
Thats good. Try reading the service manuals on those cars. If you read closely, applying a lubricant to the belts will void out your factory warranty. ;]
#17 |
lol warrenties were allll gone years ago. no worries.
i like to learn, but it's hard to imagine an oil you apply to prevent against dryrot on rubber, much like interior wipes that keep leather from drying out and cracking, are not good. i'm not talking about bringing a bad belt back from the dead. just putting it on with each oil change as preventative maintence. i dont do that with my B16, but this has got me thinking about the subject more. i shreded an alternator belt racing one night. i have no idea how that happened. was a new belt tensioned by the book. wasnt using belt dressing on those. but ya... |
#18 | |
you get the BRAKE
As for your belt getting shredded while you were racing, something may have gotten caught up onto the belt. Happened to me with an a/c belt one time. Some small wires came loose and ended up on the belt and those small wires started cutting into the belt. __________________
#19 | |
Cogito Ergo Sum Steampunk
I have an underdrive ... lemme rephrase that.
MY old ED Civic had an underdrive pulley that was polished. Well, Polished pulleys are fuckin stupid, and I had to downsize - I treated my belt with each install. the belt treatment is for a specific reason, not a repair. But it's ok to use if you need it. __________________
#20 |
gawd dam im confused. :-/ i took a look at the repair book i picked up at checkers. where is this tensioner located? is it by the driver side wheel? what size is the bolt? ill try tightening the belt first.
#21 | |
The belt tensioners are located on each of the accessory pumps. I only have an alternator, so it's located on a swing bracket.
Adjusting tension on the timing belt is done through a pulley with a spring on the back. Replacing that spring is how you tighten it. __________________
#22 | |
idk why that keeps getting brought up. someone said they were talking about the timing belt earlier. no. not now either. accessory belts. On my B16: AC uses a swing pully that you screw a threaded stud into the AC motor mount bracket which pushes the swing pully up to tension the belt. P/S you need to slightly loosen the bolts that hold the P/S pump in place, on the top of the motor, where the pump bolts to the engine mount. Then there is a threaded stud you turn left or right to raise or lower the pump to tighten the belt accordingly. Then tighten down the mount bolts to hold it in place. The alternator has 1 bolt on the top side that needs to be loosened. then pull the alternator back by prying it with a large strong flat head screw driver or crowbar whilst tightening the 1 top mounting screw. Last edited by YBLEGAL; 02-29-2008 at 04:02 PM. |
#23 |
i was changing the oil today and fuckin around i guess i found the tensioner and tightened the belt that was squeaking. it wasnt much, but enuff where its dont squeak. the belts look great, so there wouldnt have been any point in replacing them.
| Timing belts parts needed when swaping a b16b or a ?? | loverboy | HYBRID -> EG-EK / DC | 4 | 05-13-2007 05:00 PM |
| b16b or a into EK coupe 96 (d16y8 engine) - belts ??? | loverboy | HYBRID -> EG-EK / DC | 7 | 04-09-2007 03:47 AM |
| Belts for my swap | Killuminati | HYBRID -> EG-EK / DC | 1 | 11-17-2005 01:55 AM |
| FS: All drive belts and water pump for B18b - All New | wanderinman | Parts: For Sale/Trade/Wanted | 4 | 10-23-2005 12:11 AM |
| Please Need Help For Seat Belts. | ovcrash | Members' Lounge | 1 | 04-05-2003 01:15 PM |
