10 coats
Old 03-30-2007, 02:06 PM   #1
Ride:  93 del sol SI auto to manual swap
delsolcharlie is on a distinguished road
myspace
Smile best clutch for del sol
best clutch for del sol D16Z6??
what clutch would yall recommend
delsolcharlie is offline   Reply With Quote
Old 03-30-2007, 02:36 PM   #2
I need some ligaments!!!
turbo sol's Avatar
Location: laurel, montucky (ten minutes out of billings)
Ride:  89 crx hf, turbo'd 95 del sol si, 87 shaggin wagon(astro)
turbo sol has a spectacular aura aboutturbo sol has a spectacular aura about
Send a message via MSN to turbo sol myspace
modded or not?
turbo aplication: ACT extreme pressure plate and matching clutch disk
slight mods/ under 200 hp: centerforce dual friction package with 20% stiffer pressure plate
turbo sol is offline   Reply With Quote
Old 04-01-2007, 09:46 AM   #3
the newness
philliman69's Avatar
Ride:  94 ex
philliman69 will become famous soon enoughphilliman69 will become famous soon enough
i have min. mods in my ex z6 i run a regular act street clutch heavy pressure plate and matched it with the prolite flywheel. i love it, it made a very noticable diff.
philliman69 is offline   Reply With Quote
Old 04-01-2007, 09:26 PM   #4
myspace
difference as in better accerlation..smoothing shifting??/
Old 04-02-2007, 09:45 AM   #5
turbo sol's Avatar
both... just overall better hold.
Old 04-02-2007, 01:47 PM   #6
the newness
Ride:  94 ex
better shifting and a lot faster acc. im switching to a b20v and im going to put the same setup in.
How to paint/dye my interior? scottp11 Body / Exterior / Interior / Cosmetics 14 07-09-2005 03:10 PM
Men in Coats jeffie7 Members' Lounge 2 05-12-2005 05:35 PM
I need a good Jet Black paint color... ssl2k Body / Exterior / Interior / Cosmetics 8 07-31-2004 06:42 PM
Sand down base coat before clear? cheese9988 Body / Exterior / Interior / Cosmetics 26 07-13-2004 02:38 AM
what psi should i spray my coats at ? ssl2k Body / Exterior / Interior / Cosmetics 5 07-12-2004 08:41 PM
