92 civic d15z1 vtec-e [=
Old 02-10-2008, 08:25 PM   #1
senior member
HondaElite's Avatar
Ride:  92 civic coupe
Rep Power: 8 HondaElite is on a distinguished road
Send a message via AIM to HondaElite
Default 92 civic d15z1 vtec-e [=
i was jus wondering if i could change my vtec?? i tried using a d16z6 ecu but when vtec is supposed to hit it just jumps..does anyone knoe if i can change the soleniod to a d16z6 one? or if i would have to chip the d15z1 ecu?
HondaElite is offline   Reply With Quote
Old 02-10-2008, 08:30 PM   #2
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin
Wow. Bad idea dude.
The VTEC-E system is design for fuel economy only and you need to run the Z1 ECU. It's pointless to move the VTEC engagement point because it's preset at the optimal RPM from the factory.
If you want a regular VTEC system, you need to swap the head for a D16Z6 or D16Y8 head.
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 02-10-2008, 08:32 PM   #3
senior member
HondaElite's Avatar
but i heard if i do that i lower my compression alot..and it is then pointless unless i run a turbo setup..is that true?
~sold out seats to hear biggie smalls speak~
Old 02-11-2008, 02:28 AM   #4
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 189 BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
Compression ratios can be changed via pistons, head gaskets, etc. There's no way you're going to be able to make your VTEC-E work like regular VTEC. A head swap is your only option.
Besides, people swap the Z6 head onto the 1.5 blocks all the time. If it didn't increase performance, no one would do it.
PSN Network ID: BrutalB83
Old 02-11-2008, 03:21 AM   #5
K2e2vin's Avatar
Yes, the Z6 will drop compression a few points but will still make more power than the Z1 head. There are many different ways to up the compression: swap in P08 or PMS(GX) pistons onto the stock rods, or swap in P29s with D15B1/2/7 rods.
RIP
Old 02-11-2008, 09:01 PM   #6
senior member
HondaElite's Avatar
what if i was to get the head shaved..and went with d16z6 high compression pistons? would that be a decent setup??
Old 02-11-2008, 09:54 PM   #7
K2e2vin's Avatar
The D15Z1 head is very restrictive. It's designed for low-rpm efficiency and has tiny ports. Also, you'd probably run into clearance issues if you throw D16 pistons in that block(unless you use D15B1/2/7 rods, compression will go up like .5 points). People bump compression up in their D16's by using P29 pistons. With the Z1 head, you may run into clearance issues with those(different combustion chamber shape).
RIP
Old 02-12-2008, 01:02 AM   #8
senior member
HondaElite's Avatar
i meant the d16z6 head with the d16z6 pistons...
1973 Civic with B20B VTEC klyph Auto Multi-Media 11 02-04-2007 08:52 AM
(Need Help) 2000 civic si with B18b Ls vtec DrAy Civic - EP, FA, FG 4 01-28-2007 02:23 PM
Question about Civic 1.6 VTEC II - year 2003 Matoso General Tech and Maintenance 1 09-08-2003 12:19 PM
Chassis Code VSMB16A2 General Tech and Maintenance 10 01-22-2003 05:32 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
