Facebook Twitter
92 Civic Si low idle
This is a discussion on 92 Civic Si low idle in the Civic and del Sol - EG and EK forum
OK, so I just bought a 92 Civic Si and the idle is really low looks like 200-300 RPM. I figured it would be the IACV since I know they go on Hondas. I pulled the IACV off my old Z6 that I have sitting ...
Old 08-11-2007, 11:22 AM   #1
Default 92 Civic Si low idle
OK, so I just bought a 92 Civic Si and the idle is really low looks like 200-300 RPM. I figured it would be the IACV since I know they go on Hondas. I pulled the IACV off my old Z6 that I have sitting around from my LSVTEC build. I also replaced the air filter, new plugs and wires. However, my idle is still low after the car has warmed up. car was bought from well almost 1 owner, 2nd guy owned for short time. it is completely stock! any suggestions would help out it is my DD.
LSVtecSdn is offline   Reply With Quote
Old 08-11-2007, 12:19 PM   #2
welfare's Avatar
there are no other problems except the low idle? No check engine lights, no problems driving the car?
welfare is offline   Reply With Quote
Old 08-11-2007, 12:58 PM   #3
correct, it hauls ass when driving just when sitting at light or warm temp, idle is low. I tried adjusting the TB screw the correct way with IACV sensor disconnected, then resetting ECU after adjusting to ~800RPM. no change no CEL
Old 08-11-2007, 07:44 PM   #4
yeah I am trying the steps in this thread:
Honda Acura Forum - Tech Performance Forums : - Troubleshooting Idle Problems
no tach just factory, everything is stock!
Old 08-12-2007, 01:13 AM   #5
welfare's Avatar
Im thinging the IAC may be bad, usually when the iac goes bad it gets stuck in the open position, causing the car to idle up and down but maybe yours is stuck in the closed position, if you have a donor IAC I would try swapping it out to see what happens, because if you followed the procedure and did everyhitng correctly (like you explained above) then you did all you can.
The only thing I can tell is that Alldata says you should adjust the idle to 450 plus/minus 50rpm with No load, ill post the whole procedure
9/1/08 NEW PROJECT RIGHT HAND DRIVE EG6
doing it myself!
6/1/09 RHD on the road, now time for Body Shop
7/10/09 jackson gsr into rhd+hondata
91 rex ls/vtec
b18b block, p30 pistons, pr3 head, p72 cams and ecu, 100% OEM HONDA PARTS, 100% converted to obd1 w/del sol harness NO JUMPER!
13.881@102 on street tires
Reputation makes the world go round, if anyone has helped you and you feel that their post was worthy of some
reptation, then give 'em a point!---,
Old 08-12-2007, 01:14 AM   #6
welfare's Avatar
  1. Start the engine and let it warm up to normal operating temperature (the cooling fan comes on).
  2. Connect a tachometer.
Electronic Air Control Valve (EACV) 2P Connector
  1. Disconnect the 2P connector from the Electronic Air Control Valve (EACV ).
  2. Set the steering in the straight forward position, check the idle speed in the no load condition, with the headlights, cooling fan, and all accessories are OFF. Idle Speed (trans in a neutral gear): Manual: 420 ±50 rpm Automatic: 420 ±50 rpm
Base Idle Speed Adjustment
Adjust the idle speed by turning the adjusting screw on the throttle body.
  1. Turn the ignition switch OFF, reconnect the 2P connector to the EACV, remove the BACK UP fuse in the underhood relay box for 10 seconds to reset the ECU.
  2. Restart the engine, set the steering in the straight forward position and check the idle speed in the no load conditions in which the headlights, blower fan, rear defroster, cooling fan, and air conditioner are not operating. Idle speed (trans in a neutral gear): Manual: 670 ±50 rpm Automatic: 700 ±50 rpm
  3. Idle the engine for one minute with headlights (Hi) and the rear window defogger ON and check the idle speed. Idle speed (trans in a neutral gear): Manual: 750 ±50 rpm Automatic: 750 ±50 rpm
  4. Idle the engine for one minute with heater fan switch at HI and air conditioner on, then check the idle speed. Idle speed (trans in a neutral gear): Manual: 810 ±50 rpm Automatic: 810 ±50 rpm
doing it myself!
91 rex ls/vtec
Old 08-12-2007, 01:16 AM   #7
welfare's Avatar
alldata calls the iac an eacv, but whatever
Old 08-12-2007, 05:32 PM   #8
well I followed the steps from the super-honda site. I was thinking that it was the IACV also which is most typical vs. the FITV going bad. I swapped the IACV from my old Z6 did not solve problem. I cleaned and tested the FITV even swapped the thermo plunger from another donor FITV, this did not work either. I pulled the FITV again from my old Z6 and VWALLA! problem solved it was a bad FITV.
IDLE is back to normal 750 RPM +/-
Thanks for all the input!
Old 08-13-2007, 07:46 AM   #9
OK new update. problem not solved! low idle again at lights it almost sputters a little, I already replace IACV from my old Z6 out of my EX that was running perfect. tach needle set just above 0 RPM only at a stop, if no gas and out gear while rolling idle is fine but within 30 seconds at the light idle gets real low. normal driving, no loss of power or hesitation at all! I changed plugs and wires as well as new air filter, everything on the car is bone stock, no mods.
STUMPED!
Old 01-18-2009, 01:57 PM   #10
This reply is for those who found this thread on google.
imzjustplayin is offline   Reply With Quote
phila pa civic and integra parts cheap must go ek9_civic123 Parts: For Sale/Trade/Wanted 6 08-10-2007 11:57 AM
ecu code 2 long 3 short ?pr3 cvccricebaby@yahoo.com ECU's, Electronics, and Tuning 19 07-19-2007 01:16 AM
Tax Topic: Honda Civic GX = Highest Tax Credit reckedracing Members' Lounge 5 03-01-2007 11:12 AM
94 civic idle problem 94civic25 General Tech and Maintenance 7 07-28-2006 11:52 AM
d16y5 swap 95 civic dx -idle jumps up and down mrather HYBRID -> EG-EK / DC 2 06-01-2006 10:37 PM
© 2001-2013 HondaSwap.com
