93 delsol b16 no start
Old 01-11-2008, 08:23 PM   #1
Rep Power: 0 sihondatech is on a distinguished road
Default 93 delsol b16 no start
just installed b16 obd1 into 93 delsol si sohc vtec. the original ecu is in car still and car wont start. will this virgin sohc ecu run the dohc engine???? help !!!!!!
sihondatech is offline   Reply With Quote
Old 01-11-2008, 10:36 PM   #2
Banned
Rep Power: 0 OKCZombie is on a distinguished road
yes the p28 stock ecu will run the b16 not great but it will work. Does it try to turn over? any clicking? do you hear it try and fire? injectors wired up?
OKCZombie is offline   Reply With Quote
Old 01-12-2008, 08:10 AM   #3
yes it cranks but wont fire,it wants to go but wont. does the sohc ecu need modified to run a dohc??
Old 01-12-2008, 02:54 PM   #4
dtob's Avatar
Rep Power: 11 dtob is an unknown quantity at this point
Look at your other thread about this. I just posted on it.
dtob is offline   Reply With Quote
Old 01-28-2008, 09:01 PM   #5
Ride:  1994 Del Sol
Rep Power: 0 impoppi is on a distinguished road
Cool
Might not be relevant BUT!!
Possible Main Relay Problem.
When you turn the key does all of the lights come on?
Do you hear the relay clciking?
The enginer light should stay on for a few seconds and then go off.
If you don't hear clicks or the check engine light stays on the main relay could have gone bad. If so take the relay apart and resolder all of the connectors. You might see the bad connection and not have to resolder all of them.
impoppi is offline   Reply With Quote
Ground wire problems B16 wont start crxef8b16 General Tech and Maintenance 2 06-20-2005 09:50 PM
93 cx with b16 swap NO START FTPRACING HYBRID -> EG-EK / DC 0 05-25-2005 08:05 PM
b16 gen 1 swap start-up problems bob06 HYBRID -> ED-EF / DA 11 04-15-2005 01:15 PM
All Swap Info for EF Riceras HYBRID -> ED-EF / DA 2 02-07-2005 03:20 PM
HELP B16 SWAP WON'T START Citizen_Insane HYBRID -> ED-EF / DA 20 04-03-2004 01:10 PM
