93 Dx Gsr Swap... Engine Temp Too Low
Old 01-25-2007, 12:14 AM   #1
Rep Power: 12 9000_red is an unknown quantity at this point
Default 93 Dx Gsr Swap... Engine Temp Too Low
Hi, I'm new.
I finished swapping a B18C1 into my 93 DX coupe. I swapped in a Mishimoto radiator for a Teg as well. I put in a 170 degree thermostat.
The car runs and drives fine, but it stays too cold. If it idles for an extended amount of time, it gets up to about 25% operating temp. If I take off down the road, the temp needle drops all the way down. I'm afraid this will keep VTEC from working properly if it doesn't get up to the correct operating temp. I was thinking of swapping back to a higher temp thermostat. Any other suggestions?
Also, my heater works, but works less well when I'm going down the road. I think the thermostat is causing this as well, but I just wanted suggestions. Thanks!
9000_red is offline   Reply With Quote
Old 01-26-2007, 08:25 PM   #2
Ancient Member
welfare's Avatar
Ride:  RHD EG6 jrsc b18c :)
Rep Power: 29 welfare is a jewel in the roughwelfare is a jewel in the roughwelfare is a jewel in the roughwelfare is a jewel in the rough
Send a message via AIM to welfare
I would say you got a bad thermostat, when a thermostat gets stuck partially open it will cause just what you are explaining, since the thermostat isn't keeping the coolant in the engine long enough for it to heat up, and the radiator is cooling it down, so it never reaches proper operating temp.
welfare is offline   Reply With Quote
Old 01-27-2007, 01:58 PM   #3
i put in a 190 degree thermostat, and it seems to have fixed the problem. thanks for the help.
Jdm & Usdm Motor Swap Answers civicsi1415 HYBRID -> EG-EK / DC 15 08-01-2008 01:15 PM
Honda crx engine swap please help! doubleeightynines Civic and CRX - EF 6 09-08-2006 12:02 AM
D15A engine swap rbrascal General Tech and Maintenance 2 09-09-2005 06:11 PM
Civic 95coup Ex Swap / Engine Suggestion seriot HYBRID -> EG-EK / DC 23 06-17-2003 01:02 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
