95 Ex Idle problem
Old 11-16-2009, 11:41 PM   #1
Greenhorn
Ride:  1995 Civic Ex, 1994 Del Sol
95Dvr is on a distinguished road
myspace  FaceBook
Default 95 Ex Idle problem
My 95ex has been idling between 1k-1.5k and reving on its own, somtimes higher or lower rpms but always in the same range jumping 500 rpms or so. I've replaced the idle air control valve based on my brothers advice but it hasn't fixed the problem in any way. Just wondering if anyone here has come across this problem or knows what might be acting up on the car.
95Dvr is offline   Reply With Quote
Old 11-17-2009, 02:00 AM   #2
B
Administrator
B's Avatar
Ride:  2010 Hyundai Genesis Coupe 2.0t Track Edition, 2000 Dakota
B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
myspace  FaceBook
Check/Bleed the coolant system. an air bubble will cause odd revs.
Check the TPS set screw on the back of the throttle body, it might just need to be turned down.
Check the throttle cable, that its not twisted and tb can fully close.
B is offline   Reply With Quote
Old 11-17-2009, 04:54 PM   #3
Greenhorn
myspace  FaceBook
Thanks for the help B, I'll get to work checking everything out
Old 11-21-2009, 04:47 PM   #4
RidetilldeathdousparT
pooksy64's Avatar
Ride:  95 EG coupe,93 EG HB, 95 Supra , 05' CBR RR
pooksy64 will become famous soon enough
Send a message via Yahoo to pooksy64
---due to fast idle valve. check the adj screw. i mentioned this same prob in another thread
pooksy64 is offline   Reply With Quote
b16a idle problem not iacv or fast idle toqeer1986 HYBRID -> EG-EK / DC 13 12-05-2009 11:05 AM
idle problem civic4dr Civic and del Sol - EG and EK 9 11-13-2009 03:43 PM
idle problem d16a6civichatch General Tech and Maintenance 1 03-01-2009 07:06 PM
idle problem? 91integraLS General Tech and Maintenance 0 08-08-2007 01:49 AM
Having a problem with my idle Blanco General Tech and Maintenance 12 08-28-2003 06:09 PM
