96 hatch hood latch problem
Old 03-15-2007, 12:13 PM   #1
Rep Power: 6 Civic96 is on a distinguished road
Default 96 hatch hood latch problem
Hey guys, i have a 96 hatch with a failure hood latch. I bought a new one from Honda dealer and after several attends, the hood wont close all the way in because the latch is not push all the way. I noticed that there are three vertical line marks on either side of the latch which i think the latch need to align with in order for the hood to be push down and lock in. so if you have a 96-00 hatch (i dont know if all civic hood latches are the same, my brother's 95 ex has no line marks), please do me a favor and check your hood latch and tell me where the latch need to be align to those marks. thanks.
Civic96 is offline   Reply With Quote
Old 03-17-2007, 12:28 PM   #2
thsancho86's Avatar
Ride:  97 civic ex
Rep Power: 7 thsancho86 is on a distinguished road
On my 97 coupe there are 3 horizontal marks and the latch has two marks that line up with first and third on both sides of it if that helps at all.
84 RX-7 GSL- repair project
97 Civic ex - current DD
86 S10- Gas hog - sold
thsancho86 is offline   Reply With Quote
Old 03-19-2007, 11:08 AM   #3
although the marks are set differently, i will give it a try next week when I put the carbon fiber hood back on. As for now, the hood is mysteriously locked and closed nicely in. I dont know how, but after numerous times of trying adjusting the latch, I failed, and feed up with it. I drove the car with only the hood hooked in a little (just like when you pulled the handle to pop up the hood) its dangerous and iam running the risk of the hood flips up and smashing my windsheld, but i only go under 60mph. I woke up the next day and the hood is nicely locked in, so I will just leave it for now and find out the proper alighements(marks) when puting the carbon fiber hood back on. thanks for the input and keep it comming...
Old 03-19-2007, 12:15 PM   #4
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 384 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
Well, unfortunately you cant copy anyone else. Every civic will be set a little different. You just have to experiment and see what works best. Its the same with the door latches if you look there, you'll find the same refrence marks.
And DO screw with it until you get it right. Your hood may look and feel secure, but it may be barely haning on. Pop the hood, adjust it a little, and drop the hood from about 1 foot high. It should shut and lock. Just tighten the bolts enough for it to hold in place for one trial. Keep adjusting until it closes and locks. when you find the perfect spot, Tighten those bolts down good.
Also, check the alignment of your hood between your fenders. If the gap when closed is tiny on one side and huge on the other, you may need to adjust your hood fitment.
Why did the latch fail in the first place?
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
Old 03-20-2007, 10:57 AM   #5
the latch failed for apprearantly no reason. I poped the hood for a regular oil change and couldnt get it to close. I tried to pop the hood without pulling the lever and its tight and will make sure it is 100% lock in when putting back the carbon fiber hood. thanks
91 hatch timing problem maybe?? help!!! shaunk18 HYBRID -> ED-EF / DA 3 01-19-2007 11:50 AM
VIS Hood Latch, Where is it? B16RacerN2NR Body / Exterior / Interior / Cosmetics 7 11-28-2005 06:54 PM
92 Civic Hood Release turfman General Tech and Maintenance 9 04-28-2005 07:46 PM
quick hood clearance question... sleeper_crx88 HYBRID -> ED-EF / DA 4 03-16-2005 01:27 PM
All Swap Info for EF Riceras HYBRID -> ED-EF / DA 2 02-07-2005 03:20 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
