97 Civic Coupe Swap Advise
Old 10-11-2008, 03:10 PM   #1
Rep Power: 0 growurown is on a distinguished road
Default 97 Civic Coupe Swap Advise
I have a 97 Civic Coupe with a d16Y7 engine. It has 280,000 miles and a slight internal leak (Head Gasket, I had it tested)
I have never raced, and dont intend to, but I am thinking that I would like a little more kick for everyday driving. But still want the gas milage. I am really torn between what route to go. I am thinking of a B16A complete swap, but I have read that it is a difficult swap and that the B16C is easier, but more expensive.
I should add that I will not be doing the work myself.
What expieriences or advise can you offer for me ?
Thanks in advance !!
growurown is offline   Reply With Quote
Old 10-11-2008, 04:09 PM   #2
Crusher of Noob Ambitions
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 145 BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
A B16 is a B16. One version won't be any more difficult to physically swap in then the other. The issue you should be concerned with is the wiring. In order to make the swap as easy as possible the donor engine should be using the same OBD setup as your car. Even if it's not, you can simply buy a conversion harness that will make the swap easier...
If you find something I say helpful, please rep it up!
97 Integra LS Coupe:
*AEM Intake/Megan Header/Magnaflow Exhaust
*Tokico Shocks & Springs
*Megan Strut Braces & H-Brace
*98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys)
Old 10-11-2008, 04:14 PM   #3
I <3 HS ;)
Ride:  98 Audi A4 Quattro, b20b EG Coupe, 91 Si hatch.
Rep Power: 0 eurocivic91 is on a distinguished road
An the conversion harness is as hard to install as plugging in a lamp ;]
kinda sorta.
eurocivic91 is offline   Reply With Quote
Old 10-11-2008, 05:34 PM   #4
thanks for the advice, I appreciate it
Old 10-11-2008, 05:54 PM   #5
BrutalB83's Avatar
myspace
Yep, no problem. Pretty much any B-series engine is going to be an easy, bolt-in swap with the proper mounts...
Old 10-11-2008, 07:10 PM   #6
I can't feel my face
Ride:  1996 Civic, 1989 Volvo Wagon
Rep Power: 59 Matts96HB has a brilliant future
Send a message via MSN to Matts96HB myspace
B18C you mean?
I don't believe there is such a thing as a B16C.
1996 Civic 3dr DX - Build
1989 Volvo 760 Wagon
Matts96HB is offline   Reply With Quote
Old 10-13-2008, 05:55 PM   #7
Originally Posted by Matts96HB View Post
B18C you mean?
You are RIGHT, I am indeed wrong I meant the B18C.
I have decided to stick with just a stock engine, the D16 series, I have gotten quotes for the d16Y7(104 HP), and the D16Y8(127HP-VTEC) is roughly $500 more
I would love to have a little more HP but not sure if it is worth it. Would love some thoughts on the two engines.
Forum Jump
Honda : Civic EX Coupe TURBO 1997 Honda Civic Coupe B20 VTEC SWAP! Low Reserve RSS-Bot Auctions 1 09-15-2008 10:59 PM
need advise on del sol swap Dfwflyr85 Civic and del Sol - EG and EK 11 08-12-2008 02:04 AM
my future plans on a b18 swap,an advise? dikonwheelz Civic and CRX - EF 0 11-30-2007 09:14 PM
enigne swap advise si2000-driver Civic - EP, FA, FG 18 12-25-2006 11:13 PM
B16 swap Carb to Injection conversion advise b16dx HYBRID -> EG-EK / DC 6 07-29-2006 06:19 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
