98 civic hatch front break problems
Old 03-19-2009, 06:16 PM   #1
Ride:  91 civic 4dr SOHC
efcivic4dr is on a distinguished road
Send a message via AIM to efcivic4dr
Default 98 civic hatch front break problems
I seem to be loosing all my break fluid at a steady rate. There is barely any pressure when i push the break pedal. When i do push the break, it pulls to the right side and often starts to shake the car. When the car is off and i push the pedal pressure will build but not last. I have checked the lines and have no leaks. Someone said the calipers may have gone bad on both sides? I personaly hate break but can not afford to take it in right now to get them fixed so. I need some suggestions. thanks
-Carl-
streetpsi.net
efcivic4dr is offline   Reply With Quote
Old 03-19-2009, 06:20 PM   #2
Err ___ GTFO
Slow&Delirious's Avatar
Ride:  01' Civic & 95' Del Sol
Slow&Delirious is a jewel in the roughSlow&Delirious is a jewel in the roughSlow&Delirious is a jewel in the roughSlow&Delirious is a jewel in the rough
Send a message via AIM to Slow&Delirious
if it pulls to the right then its either your right caliper or a leak going to the left caliper
Slow&Delirious is offline   Reply With Quote
Old 03-20-2009, 04:28 PM   #3
In my own little world!
serrilion's Avatar
Ride:  93 Lude w/ H22a
serrilion has much to be proud ofserrilion has much to be proud ofserrilion has much to be proud ofserrilion has much to be proud ofserrilion has much to be proud ofserrilion has much to be proud ofserrilion has much to be proud ofserrilion has much to be proud of
Send a message via AIM to serrilion Send a message via MSN to serrilion Send a message via Yahoo to serrilion myspace  FaceBook
Dito above. You could go to a scrap yard... mite be cheap and maybe a little better
serrilion is offline   Reply With Quote
98 civic hatch front break problems efcivic4dr General Tech and Maintenance 0 03-19-2009 05:42 PM
ls hatch problems wtf! Freek HYBRID -> ED-EF / DA 9 01-18-2006 11:53 PM
some problems on my EF hatch minitrucka General Tech and Maintenance 1 05-22-2005 10:34 PM
H22 Into 99 Civic Hatch. Any problems? 99civichatch HYBRID -> EG-EK / DC 2 04-05-2004 09:32 AM
92 hatch rear disc break conversion 99 civic? MarkN929RR Wheels / Suspension / Tires / Brakes 3 03-03-2004 01:35 PM
