I want to see if anyone in here can help me. I have an mugen aftermarket steering wheel installed on my ek9 hatchback, and had to remove the srs spring for the airbag and the horn, but I currently have problems trying to get a wire to work for my horn. Whenever I wrap it like a spring under the hub adapter, it tends to shave off the wire coat and the horn ends up grounding and my horn will sparatically sound off. Is there anything made to accomodate the use of an aftermarket steering wheel with the horn wire, because I want my horn to work and the wire keeps messing up.
Yahoo messenger: candeekidone AIM: nocturnalpinoy1 I would appreciate it. |
HS Troll...And Mod
Ride: 2001 Honda S2000
you can always drill a hole for a button and actually wire the horn.
If you PM me with tech questions, you better have a link to the thread in your PM. Anime Informant |
no what there is already a hole drilled in the bottom of the adapter. What I have a problem with is that everytime I put a wire and twirl it around inside the hub like a spring so that way it'll unwrap and wrap as I turn the wheel, well the wire will eventually get torn up, and i'm trying to find a solution to making my horn work just right but with the wiring. Because I had to take out the srs thingy that comes under the oem steering wheel.
HS Troll...And Mod
all i can think of is just wrapping the entire wire in electrical tape...
| How To: Install an aftermarket steering wheel. | Andrew | Civic and CRX - EF | 61 | 04-03-2009 04:17 AM |
| How to wire the horn for a Non-SRS steering wheel | civicious | General Tech and Maintenance | 0 | 05-12-2005 07:32 PM |
| Aftermarket Steering Wheel: For Offroad Use | YangpaNemsay | Body / Exterior / Interior / Cosmetics | 3 | 12-22-2004 02:37 PM |
| How to: Remove an SRS steering wheel | 92b16vx | General Tech Articles | 1 | 03-30-2004 12:55 PM |
| Choosing the Correct Aftermarket Wheel | pissedoffsol | General Tech Articles | 0 | 01-11-2004 08:50 PM |
