B16A Swap
Old 08-28-2006, 06:15 PM   #1
Rep Power: 0 Longhorn is on a distinguished road
Default B16A Swap
Hi, newbie here..I am considering in making a swap of a b16a that comes from and EG9 to put it in my EK coupe..is it the right choice of B16?? And if it comes from an EG9, what series is it? Many thanks..
Longhorn is offline   Reply With Quote
Old 08-30-2006, 03:17 PM   #2
daf
Rep Power: 7 daf is on a distinguished road
The only issue I think you may have is the EG is obd1, but if your not in a stat that requires obd testing your good to go. A b16 is a good choice, almost all the B series are fairly straight forward swaps. But this really should have been in the Hybrid thread. BTW, if you splerg and get the EK4 SiR II b16, that baby has 170 hp stock.
daf is offline   Reply With Quote
Old 09-11-2006, 06:28 PM   #3
Rep Power: 0 dthug is on a distinguished road
imo b16's SUCK
they have no torque at all, under 4k rpms is feels just like a d series, i dont think its worth is its a tiny engine 1.6 but if moneys tight you might as well but i think you should save up a little bit more and get a gsr or even ls-t
dthug is offline   Reply With Quote
Old 09-27-2006, 01:08 AM   #4
Robbie_B16A's Avatar
Ride:  Honda civic 4dr
Rep Power: 0 Robbie_B16A is on a distinguished road
lol i pull GSR's with my JDM B16
Robbie_B16A is offline   Reply With Quote
Old 09-27-2006, 08:44 PM   #5
tip
Rep Power: 13 tip is an unknown quantity at this point
i would like to see you even hang with my eg/gsr.........
tip is offline   Reply With Quote
Old 09-27-2006, 10:41 PM   #6
friz's Avatar
Rep Power: 19 friz is an unknown quantity at this point
Originally Posted by dthug View Post
imo b16's SUCK
When I race, mine doesn't spend any time under 4000. The gearing is tight enough that I can keep it in Vtec through all of the gears.
friz is offline   Reply With Quote
Old 09-28-2006, 04:28 PM   #7
Regular Member w/ Cheese
YBLEGAL's Avatar
Ride:  2000 EJ8 w/ SiR-II
myspace
same here :P
Old 09-29-2006, 01:07 AM   #8
Rep Power: 0 SiR_Dank is on a distinguished road
i smoked plenty of gsr's with my b16. i will smoke ur gsr as well. come see me im from kali.
SiR_Dank is offline   Reply With Quote
Old 09-29-2006, 11:05 AM   #9
tip
i am not driving all that way just to spank a little ass ..........but this dude is from here or so it says anyways.
Old 10-01-2006, 02:06 AM   #10
Rep Power: 7 Gno95 is on a distinguished road
hey im planning on putting a b16 a sir ii on my 95 ex...what you guys think get the LSD or not? and while am at it you think I can keep my Intake ,exhaust , headers? im sorry im new..
Gno95 is offline   Reply With Quote
Old 10-01-2006, 02:36 AM   #11
Ellis_d
Ride:  1993 civic JDM
Rep Power: 7 ellisd is on a distinguished road
Send a message via Yahoo to ellisd
Talking
intake and exuast yes but your headers won't fit . as far as a gsr goes they are ok i've pulled them with a d16 model . you see with enough hard work and money even the smallest engine will pull even the most torqued out gsr there is so do your research because manifold adjustment adds up more than you think
EllisD
ellisd is offline   Reply With Quote
Old 10-01-2006, 02:46 AM   #12
YBLEGAL's Avatar
myspace
deff get the lsd!!!
if u didnt know, it slows the rotation of the inner wheel when cornering so you dont have understeer; ie: better cornering, less slipping.
Old 10-01-2006, 12:01 PM   #13
Thanks for the reply's on LSD and exhaust and intake now to follow on that...What headers will I need to purchase . I mean..my car is an ex...or EGEK w/e I dont have a clue when comes to that...What parts will fit in it since the motor is from a hatch? do I look for 1.6l si??? but in some it shows up as a D motor or is it a DOHC Del sol? Im so lost man...I just want this stuff n start messing with damn mustangs minds lmao.
Old 10-03-2006, 10:01 AM   #14
Rep Power: 12 MoSeS is on a distinguished road
look for a 99-00 civic si
MoSeS is offline   Reply With Quote
Old 10-03-2006, 01:25 PM   #15
most sites give you the option to put in the type of engine as opposed to the type of car. for cat-back systems you would get the kind made specifically for your car, for the header you would look for a b16 header, Megan racing makes quality products that look and perform great and they aren't as exspensive as some of the higher name brands, Megan Racing i think. i bought a header from them for my d16, ive had it on for 2 years now with no problems
Old 10-04-2006, 01:34 PM   #16
Rep Power: 7 JDMBOOSTEDEG6 is on a distinguished road
same here , for the cost difference between the b16 and the gsr , i would rather stick to the good old b16a i had one in my old eg hatch and i used to smoke gsr , ls turbos , evos , srt-4s , type-r , h22s in accords you name it , as long as you can drive worth a damn and you spend money on stuff that actually works ... go for it . i recoment a jun spec ecu , 3" short ram intake , 4-1 headers , str8 exaust with no cat/resonator sum stage 2 axles and a good set of tires ( not azenis ) 555r or the neogen nitto's are perfect ..
JDMBOOSTEDEG6 is offline   Reply With Quote
Old 10-04-2006, 04:03 PM   #17
stage 2 axles are overkill. you won't need them unless you are planning on making over 300 hp. don't waste money on shit you don't need
Old 10-04-2006, 07:36 PM   #18
actually there not really over kill ... im sure you havent seen a civic out launch a evo 8 on stock axles and how would stock axles ever survive with nitto 555r slicks ? slap sum on your ride and well see how long ur axles last ... good trick to out launch evos and srts and all those hardcore badasses that cant fix up cars so they buy cars that are already fast , launch @ 5,200 rpm and feather off the clutch dont dump unless you got slicks ... worked for me very well and i got videos to prove it
Old 10-05-2006, 02:21 PM   #19
the reason you upgrade the axles is so you don't snap them off the line and so they will be able to withstand the force of a high horsepower launch. if you aren't making much power then you don't need them. slicks are also a waste of money on a STREET CAR, its retarded.
CRX / 88-91 Civic Hatch B16a swap timeslips? The_MATRIX Racing and Driving Techniques 19 06-18-2007 03:56 AM
FS B16a tranny, b16a head, Tons of swap parts!!!! WannabeSI Parts: For Sale/Trade/Wanted 9 05-20-2004 10:53 PM
OB0 SIR1 B16A JDM SWAP syphonz420 Parts: For Sale/Trade/Wanted 0 03-09-2004 03:29 PM
JDM B16A OBD1 Swap in 95 Civic EX CivicSiR7 HYBRID -> EG-EK / DC 4 02-13-2004 07:26 PM
What would I need for a B16A swap in an 89' civic? hardweapon HYBRID -> EG-EK / DC 12 10-09-2002 11:03 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
