Blown D16Z6 Vtec replacement?
Old 08-29-2008, 01:30 AM   #26
My name is Byron.
efhondakid's Avatar
Ride:  `89 DX Hatch w/JDM B16
Rep Power: 107 efhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
Originally Posted by Flippinjig View Post
Do the modified engines get lower mileage because you got your foot all the way to the carpet? I'd do the same too if I had a fast car.
There is some truth in that, but think abouit it...it takes what to make more HP, fuel thats right. A stock D will be about the best bet for high MPG.
Looking for a P28 and B-series turbo parts, PM me.
Old 08-29-2008, 01:41 AM   #27
The Kicker of Elves.
Blanco's Avatar
Rep Power: 222 Blanco has a reputation beyond reputeBlanco has a reputation beyond repute
Blanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond repute
Mine got good fuel economy because I spent the money on a really good tuner. I would've been closer to 30mpg if I drove with fuel economy in mind.
Don't misinterpret what I say.
Originally Posted by The Secrets of Body Language
93% of communication is done through body language.
Originally Posted by http://humanresources.about.com/od/interpersonalcommunicatio1/a/nonverbal_com.htm
One study at UCLA indicated that up to 93 percent of communication effectiveness is determined by nonverbal cues. Another study indicated that the impact of a performance was determined 7 percent by the words used, 38 percent by voice quality, and 55 percent by the nonverbal communication.
Originally Posted by Shawn Pelton
It's not good to be a drummer unless you got some bad motherfucker up inside you.
Blanco is offline   Reply With Quote
Old 08-29-2008, 02:19 AM   #28
Ride:  95 Del Sol, 97 Accord
Rep Power: 0 Flippinjig is on a distinguished road
I regularly get 27 to 28 with my Accord (97 EX V6) and have gotten just under 30 when I really pay attention and drive like grandma (that is hard to do though). I've heard some say that they put it in neutral going down big hills but isn't that hard on the drive train when you put it back in gear?
Flippinjig is offline   Reply With Quote
Old 08-29-2008, 03:01 AM   #29
Ride:  Still waiting.
Rep Power: 0 eggo831 is on a distinguished road
Send a message via AIM to eggo831 myspace
I doubt you'll ruin your engine or tranny, but you can ruin your brakes. A lot more force is needed to stop the car with that much momentum. BRAKE FADE.
k
eggo831 is offline   Reply With Quote
Old 08-29-2008, 03:23 AM   #30
Blanco's Avatar
Leave the transmission in gear and push in the clutch. Don't take it out of gear. When you let the clutch back out, rev match.
As far as using the brakes to slow the car down. What costs more in terms of money and time to replace, brakes or a clutch?
Old 08-29-2008, 04:51 AM   #31
Would that cause clutch wear, not worth the little higher mileage?
Old 08-29-2008, 05:53 AM   #32
Blanco's Avatar
The clutch wear I'm talking about comes from over-using engine braking. Use the brakes to slow the car down.
Also, you'll cause damage to the drive-train if you just put the car back into gear from neutral without rev matching. To learn about rev matching, go to: http://www.turnfast.org Even better than pushing in the clutch, is just putting the transmission into the correct gear and then lifting off of the throttle to about 5%...just barely pushing the pedal down. BMWs have a nifty little MPG gauge under the speedometer and when I do this is registers 30-45mpg depending on conditions. And that's with a 2.5l six cylinder on flat ground.
Old 09-09-2008, 05:33 PM   #33
Rep Power: 0 alcides is on a distinguished road
hello, i'm new here, i'm of BRASIL
a) d16z6 automatic (eh6) - Del Sol Si
b) octane with alcool 23%
c) 27,75
+/- 70 miles
im building my motor , with kit Hi Tech 0.10 " = 0,25mm , i 'll bye in autozone.com ( acl duraglide 780 is better?)
Somebody know something about this product ? gasket,bearings,pistons -rings, ?
water pump and oil pump , whats the better? duralast,goop,...?
ty
alcides is offline   Reply With Quote
Old 09-10-2008, 09:13 AM   #34
Resident Fat Ass
George777's Avatar
Ride:  90 Hatch, 91 Rex, 85 Yamaha Virago, 82 CB900F Supersport
Rep Power: 65 George777 has a reputation beyond repute
George777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond repute
Great first post. Way to threadjack...
Originally Posted by Blanco View Post
Eat shit and fucking die you ignorant redneck.
Originally Posted by B16RacerN2NR View Post
I don't know how to do plastic surgery but I love titties, you don't see me trying to go around giving breast implants do you?
Originally Posted by phyregod View Post
Yup, Its sex on wheels. Violent, vigorous sex. With a super model. Scratch that, super model twins.
George777 is offline   Reply With Quote
Old 09-22-2008, 06:19 PM   #35
Hey, what do you guys think of a D15Z1 as a replacement? IDK the year but do got the tranny for it too.
Old 09-22-2008, 09:52 PM   #36
HS TECH
AHHVTEC's Avatar
Ride:  dc5,mk4 gti,2nd gen civic,
Rep Power: 164 AHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
for good gas ya, performance not so much
Old 09-22-2008, 10:19 PM   #37
Would it make much difference to use the Z6 top end? What are the differences in the tranny's?
Old 09-22-2008, 10:22 PM   #38
HS TECH
AHHVTEC's Avatar
yeah you can put the z6 head on there it will help, and im not sure on the tranny im perty sure there longer geared than the ex or si
Old 09-23-2008, 02:57 AM   #39
Will Z6 ECU work with 15Z1?
Old 09-23-2008, 02:59 AM   #40
My name is Byron.
efhondakid's Avatar
Youll have to get the P28 chipped with the Z1s basemap.
Old 09-23-2008, 03:11 AM   #41
Ok, now I'm really going to show my ignorance. D15Z1 lower half, would you stick with the Z1 head and tranny or use the head and intakes and tranny from the blown 16Z6? I did get a P07 ECU with the Z1 motor too.
Old 09-23-2008, 03:14 AM   #42
My name is Byron.
efhondakid's Avatar
Performance or gas mileage oriented?
Old 09-23-2008, 03:20 AM   #43
I want good mileage but if the performance would be significantly better and mileage suffer not so much then.........
Old 09-23-2008, 05:21 PM   #44
I've got another Z6 motor too. Am I in the ballpark to say that I could get mid to high 40's mileage with the Z1? Can I get low 40's with the Z6 but still have alot more power when I need it?
Old 09-23-2008, 06:23 PM   #45
HS TECH
AHHVTEC's Avatar
i say 30s with the z6
Old 09-23-2008, 10:20 PM   #46
El Sam
94H_Ex's Avatar
Ride:  94' Honda Civic Ex. (under construction)
Rep Power: 9 94H_Ex is a jewel in the rough94H_Ex is a jewel in the rough94H_Ex is a jewel in the rough
Send a message via AIM to 94H_Ex myspace
The only reason why a d15z1 gets great gas mpg, is because the intake ports are tiny, doesnt require so much fuel and air, as well as the pistons are low compression. other than that your stroke and deck heights are the same as every other 1.5 block. Im only using a z1 block for a build because its a good block, No signs of over heating, when i got it, green coolant, block surface looked brand new, new water pumps and oil pump. and i only paid 100. Even though i didnt realize till later. i didnt want the head. I'm switching the pistons from a d15b and the P08-1 head. I'm basically doing the same build as blanco. but not as clean as his is. Even though after seeing his now. I want to take that extra effort to make it look even better. yes.. im jealous of you blanco.
If i were you. Just pop the Z6 in. Unless you want to build the z6. then go ahead and put the z1 in. save gas and money, build a stroker from the z6. Im not sure if i got my numbers right. but you could find a d17 block and use the crank shaft (the main bearings are the same size) and then use 1.5 rods on the 1.7 crank and you have a stroker. of course I dont have my numbers right. I havent taken the time to check to see if that adds up right. but Either way. it'll be cheaper than a full stroker kit.
Originally Posted by Luis998 View Post
You're a bastard. haha
For Sale Thread
http://hondaswap.com/parts-sale-trad...b-list-157320/
^^^^updated
94H_Ex is offline   Reply With Quote
Old 09-24-2008, 02:53 AM   #47
Items F/S:
D15Z1 V-Tec Head
OBD-1 P75 Ecu *virgin
Is this the ECU from the Z1? I got a P07 with mine.
Old 09-24-2008, 03:00 AM   #48
resident jester
cjvictoria's Avatar
Ride:  haha...
Rep Power: 29 cjvictoria has much to be proud ofcjvictoria has much to be proud ofcjvictoria has much to be proud ofcjvictoria has much to be proud ofcjvictoria has much to be proud ofcjvictoria has much to be proud ofcjvictoria has much to be proud of
