#51 | |
My name is Byron.
Ride: `89 DX Hatch w/JDM B16
Dont PM me with tech questions. I will not answer them. Looking for a P28 and B-series turbo parts, PM me. |
#53 |
My name is Byron.
OBD stands for On Board Diagnostics. 88-91 is OBD0, 92-95 is OBDI, 96-on is OBDII. And yes it does have a lot to do with the wiring.
#55 |
My name is Byron.
This one?
![]() I used this site and book while doing my swap and the info in both made it go very smoothly.
#56 |
Ride: 95 Del Sol, 97 Accord
Well I do believe that's it. Does it tell about the different transmissions too? Both my Z6 and Z1 transmissions have bar code stickers on them. They both say S20 with a series of other numbers that are different. Are those other numbers serial numbers?
#57 | |
resident jester
Ride: haha...
thats a sick lookin engine too block and tranny all gold and shit wow its sexy
DO NOT PM ME WITH TECH QUESTIONS, MOST LIKELY I WILL NOT KNOW THE ANSWER. |
#62 |
Crusher of Noob Ambitions
Ride: 97 Integra LS Coupe
Yes, there is. Although honestly, I don't see the point. For the price of the adaptor plate you could just buy a B-series transmission, which is a no-fabrication bolt-in upgrade for any 88-00 Civic...
If you find something I say helpful, please rep it up! Also, DO NOT PM me with tech questions! Use the forums so we can all benefit from the answers. I will NOT respond to tech-related PMs... 97 Integra LS Coupe: *AEM Intake/Megan Header/Magnaflow Exhaust *Tokico Shocks & Springs *Megan Strut Braces & H-Brace *98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys) |
#63 |
95 del sol D16
Ride: 1995 honda civic del sol stock i/e
stock intake is the little baby plastic one with the resinator box in the frot bumper.
stok exhaust is like 1.25 pipe all the way back to a oval muffler. why do you ask?????
rep is always accepted. ![]() 95 del sol-died 10-24-08 (but will come back to life frankenstein style) soon to be 1973 opel gt- waiting on the clutch a$$ holes havent sent it out yet. XBL Gamertag: jamietoolbox (all one word) |
#65 |
95 del sol D16
oh ok. if you tune it right and drive it like a kinda normal car you can get real good mpg. you have to do the right matainance, like i change my oil every 4k miles and i put in a can of seafoam in everytime (half gas tank half intake).
#66 |
I ended up putting the Z6 head and i/e (I know what i/e means now, learn something new everyday-lol) on the Z1 motor. Few minor problems:
1) I had a broken wire on top plug on passenger wheel well. IDK what this wire does but I pushed the pin out soldered in a splice and it's back together. 2)Power steering bracket and support bracket for the i/m bolt to the block and the head. It seems the distance from the holes in the block to the top of the block is a little shorter. I've got to slot the holes to make them fit. 3)My inexperience-I took the hydraulic fitting off the transmission shifter, now I have to bleed it. Motor sounds good. First time doing this and I'm like a kid at Xmas! I can't wait to get my toy out and play with it. Bolt accessories on, safety inspection, tags and I'm on the road. |
#67 |
One thing I failed to mention:
I seperated the motor from the tranny and pulled only the motor. What a B----. How do you keep the crank from spinning to remove the harmonic balancer??? |
#68 |
95 del sol D16
you dont
#69 |
El Sam
Ride: 94' Honda Civic Ex. (under construction)
Air impact. its a 17mm socket. it'll make it so much easier on you.
For Sale Thread http://hondaswap.com/parts-sale-trad...b-list-157320/ ^^^^updated |
#70 | |
I put the Z1 in with Z6 head, intake and exhaust. Z1 exhaust manifold would not bolt up to the existing exhaust pipe because the bolt pattern is different. Kinda doggy. The stroker sounds interesting. Can you tell me more? |
#71 |
Wait, so did you have an entire Z6, or did you just use the Z6 head from your old engine?
#72 |
I was going to get another Z6 but came across a Z1 before I picked up the Z6. I bolted all Z6 stuff from my car onto the Z1 block and got the car running. I went to get the Z6 but it was no good so I still have the Z1.
