Check Engine Light
Old 10-01-2008, 12:51 AM   #1
Honda Noob
KyleKidd's Avatar
Ride:  Honda Civic Del Sol
Rep Power: 1 KyleKidd is on a distinguished road
Send a message via AIM to KyleKidd myspace
Default Check Engine Light
Hi, i have a 93 honda civic del sol si, 1.5l vtech engine automactic. My check engine light is on and i know i need to jump some kind of wire and get a code from the blinking check engine light. I know i saw an article on here about how to do it but i cant find it. Can someone please link me to it or tell me in detail on what i have to do to get the code? I dont need the codes im sure i can find them somewhere, just how to do it
KyleKidd is offline   Reply With Quote
Old 10-01-2008, 02:57 AM   #2
Banned
Ride:  CRX SI
Rep Power: 0 ccsgsr1 has a spectacular aura aboutccsgsr1 has a spectacular aura aboutccsgsr1 has a spectacular aura about
its on the pass side. right side kinda near ecu. its a small plug. loop the circut by using a paper clip. Insert one end in of each prong. then your codes will flash.
ccsgsr1 is offline   Reply With Quote
Old 10-01-2008, 01:17 PM   #3
haao13's Avatar
Ride:  boosted sir eg, suzuki gsx750f
Rep Power: 6 haao13 is on a distinguished road
it kinda more under the glove box i do believe and its a blue plug. i just used a small piece of wire i had laying around to jump it
haao13 is offline   Reply With Quote
Old 10-01-2008, 07:31 PM   #4
Crusher of Noob Ambitions
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 148 BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
Did you do an engine swap? You should have a 1.6, not a 1.5...
If you find something I say helpful, please rep it up!
97 Integra LS Coupe:
*AEM Intake/Megan Header/Magnaflow Exhaust
*Tokico Shocks & Springs
*Megan Strut Braces & H-Brace
*98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys)
Old 10-02-2008, 02:50 PM   #5
Honda Noob
KyleKidd's Avatar
I found the plug, it was in this rubberish green holder thing. I dident even know it was it until i read some article before. All i had to do was pull it out and read the codes after using a peice of cpeer to bridge the connection. Got code 21- vtch solenoid Valve. Whatever that means...
Old 10-02-2008, 04:59 PM   #6
haao13's Avatar
thats wat engages your vtec. its on back of the head on the left side. its got a little cap thing on it and bolts to the head. you cant miss it
Forum Jump
Check Engine Light Si_AN_B-Eazy General Tech and Maintenance 19 02-17-2008 01:07 AM
check engine light shootist General Tech and Maintenance 3 11-22-2004 02:12 PM
Check engine light on MaaseyRacer General Tech and Maintenance 6 07-30-2004 09:20 PM
Check engine light Comes on Ractive78 General Tech and Maintenance 5 08-30-2003 08:12 PM
Check engine light Ractive78 ECU's, Electronics, and Tuning 0 08-22-2003 11:52 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
