This is a discussion on crankshaft pulley in the Civic and del Sol - EG and EK forum
I have a 1993 honda civic with a d15b vtec engine. Need to get a pulley for the crank shaft. Does anyone know if the civic and del sol carries the same crank pulley. Kind of confused. On the internet there are different descriptions....
| | #1 |
| I have a 1993 honda civic with a d15b vtec engine. Need to get a pulley for the crank shaft. Does anyone know if the civic and del sol carries the same crank pulley. Kind of confused. On the internet there are different descriptions. |
| | #2 |
| I would assume your talking about a light weight crank pulley / under drive pully??? or are you talking about the stock pully? A 1.5L non vtec crank pully should be what your looking for, a d16 is bigger than your stock block. a Del sol came threw with 3 diffrent motors... |
| | #3 |
| Its the under drive pulley otherwise known as the Harmonic Balancer. This one is for the1.5 civic lx and dx model and also the 1.5 del sol. Can u say if this one will work |
| | #4 |
| Could anyone give some info please? ? ? |
| | #5 |
| I would just use the stock one. The aftermarket ones always fuck up D/B series motors. |
| | #6 |
| stay with an OEM one not enough power to be gained to make up for the reduction in engine life |
| | #7 |
Similar Threads | ||||
| crankshaft pulley | integrawide90 | Integra | 4 | 09-17-2009 10:52 AM |
| Crankshaft Pulley... how do I get it off? | jisakson | General Tech and Maintenance | 11 | 05-04-2006 12:04 PM |
| crankshaft pulley | stedscivic | General Tech and Maintenance | 8 | 03-16-2006 09:57 PM |
| Crankshaft Pulley | unsivil_audio | HYBRID -> EG-EK / DC | 10 | 08-20-2003 02:47 PM |
| Crankshaft Pulley | intocars | General Tech and Maintenance | 3 | 06-04-2003 01:59 PM |
