Ride: 94 Del Sol zc
i heard that to get a few more hp out of my d16z6 that i could bolt a d16y8 intake manifold because it flows better and a b series throttle body because its 60mm as aposed to 57. is this true?
Admin with a big stick
Ride: 2003 S2000
Yes, but not by much. It's probably not worth your time to adapt the Y8 manifold when there are other easier things to do- like add a header. I think you said you had an intake and exhaust in the other thread, right?
Ride: 2003 S2000
Custom tune. Run uberdata and tune the car well for premium gas. You'd be surprised how much extra power you can get with a proper dyno and street tune, especially considering that your engine's original fuel map was for 87 octane and not 91 or 93. The chipped program that you're running isn't going to be ideal for your mix of parts or your area's climate anyway.
If you go with internals or forced induction, you'll have to custom tune your car anyway, so you might as well start now. Oh- you might want to look into an aftermarket cam for your car. They're relatively easy to install, and can net pretty significant power gains depending on how aggressive you go. Zex and Crower make pretty good ones. __________________
#5 |
Ride: 94 Del Sol zc
yea but a cam for a d series sems real expensive for relative gains ive done a little research tho, but ill look into the additional tuning, i usually run 93 octane but wasnt aware of the factor basemap being based on the fuel
#6 |
In my own little world!
Ride: 94 DX w D15B
Cam gears are nice, aem and unorthodox racing make some nice cheap 1's worth some money... Also you could try diffrent spark plugs and wires, i've seen some HP gain with them, another thing is try an underdrive pully... just some ideas as well... total u mite pick up 10 WHP if that
yea so a guy told me, "I bet I get laid twice as much as you," so I said, "Two times zero is still equal to zero," totally awesome. Well, a penny saved is worth two in the bush, isn't it? And don't cross the road if you can't get out of the kitchen. |
#8 | |
Ride: 2003 S2000
If you're not running a fuel/timing map built for 93 octane gas, then you're just wasting your money at the pump. __________________
#10 |
Ride: 2003 S2000
You make them yourself. They're what your ECU uses to control your engine.
#12 |
Ride: 2003 S2000
Read up on the forums.
1. get an ECU setup you can tune 2. go tune the car Those are the steps- performing them takes a LOT of practice. __________________
| ECU Question. | knuteiriktveiten | HYBRID -> EG-EK / DC | 4 | 01-13-2009 01:22 AM |
| K-Pro question. What does it do?? | nightrider45 | General Tech and Maintenance | 1 | 08-09-2007 03:42 PM |
| motor mount question and gasket question | 93integraxchic | HYBRID -> ED-EF / DA | 2 | 07-12-2007 01:50 AM |
| can someone do me a favor? (simple wiring question and speedo question) | civiclxb16 | ECU's, Electronics, and Tuning | 2 | 03-29-2007 11:21 AM |
| ECU QUestion | ls/vtec_eg | Engine Building | 12 | 01-16-2006 02:03 PM |
