D16y8 n/a build
Old 03-04-2008, 05:45 AM   #1
The name's Sam
philyphreak2127's Avatar
Ride:  98 civic dx sedan, 80 trans am
Rep Power: 26 philyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the rough
Default D16y8 n/a build
Hey guys I have finally decided that I wanna go with a n/a setup my question for you guys is what pistons would be good for this setup? Anything higher than a 10:1 compression would be nice. I already went with arp head studs, and a brand new oem head gasket, a shitty ebay header, and a cai. Basically I am trying to see how far I can go hp wise with a n/a y8. I have seen may too many turbo d's and wanna go a different way. Not that n/a d-series haven't been done before. I plan on replacing the header with a dc sport header, high flow cat, and full 2.5 inch exhaust, and going with a obd-1 conversion and a p28 ecu. The block will be bored at least .30 over. Any suggestions on how I can push the most power from this block would be awesome!! I hear skunk2 intake manifolds are the best for an all motor setup, so I will probably go with that and a 65 mm throttle body.
philyphreak2127 is offline   Reply With Quote
Old 03-04-2008, 09:24 AM   #2
thsancho86's Avatar
Ride:  97 civic ex
Rep Power: 7 thsancho86 is on a distinguished road
d-series.org has a bunch of good stuff to thumb through. I used this while I was looking into stuff for my D building a powerful street NA d16y8/z6 - D-series.org.
thsancho86 is offline   Reply With Quote
Old 03-04-2008, 11:34 AM   #3
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 43 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
D series engines are the babies of the bunch, so to speak. Ive had a few, but I quickly learned B-series is much easier to make power with. For all the money you will spend building that D, you can have a boosted or built na B series. Simple oem ls/vtec builds can net close to 200whp. Just 'food for thought'.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 03-05-2008, 02:57 AM   #4
The name's Sam
I have thought about this plan I merely had a typo. sorry Blanco. not .30 I meant more like .030, yeah it isn't much but although I am gonna try and go far I still need a fairly reliable car, although I also have a back up motor prepped in case. And I understand the d-series motors are the smallest motors honda produces, as well as most of the time the least powerful, however I have 2 d-series motors already, no b-series and would rather just work with what I have. As for me doing ITB's, and such...I posted up there I would be goin most likely with a skunk2 intake manny, and throttle body. I don't know much about ITB's except that they are a little far in depth than I would like to go. I would rather stick to stuff I have experience with. I do appreciate you guys' replies. Sorry if I come off as pissy or something but I have an idea of what I want, I don't expect insane numbers from this motor. I would be happy with around 180 ish. I know to you guys that isn't much, but this is a daily driver first, a toy second. I have a project car that will be the one where the crazy amounts of money will be dumped into. However I do occasionally take this car to the local track, and would like some better times. I normally run the road course. I have more work in the suspension, and handling related stuff than I have done to the motor.
Old 03-27-2008, 07:39 PM   #5
Ride:  99 ek h22, 91 crx b16a
Rep Power: 6 99civicJDMh22 is on a distinguished road
he is right, just buy a h22 and build it to get the desired HP you want. the only way to make a d fast is nitrous or turbo thats why you see so many turboed cause they have learned you cant make it fast with a reasonable amount of money trust me i built my D and it still wasnt that fast so i bought a nitrous kit. Then swapped h22 you will save yourself money in the long run if you just swap and build a little.
99civicJDMh22 is offline   Reply With Quote
Old 03-27-2008, 09:04 PM   #6
dtob's Avatar
Rep Power: 11 dtob is an unknown quantity at this point
I was thinking of building a d before I turboed mine. Just not worth it unless you are satisfied with 135whp on an all honda part build with a cam and itb.
Just put a junkyard turbo kit on it and you'd be making as much power if not more than what you'd make on an 8k NA build.
So you may as well just go ahead and turbo that bitch now.
dtob is offline   Reply With Quote
Old 03-27-2008, 11:45 PM   #7
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
It's doable- you just have to have realistic goals. I had a plan for an all motor D to about 150-160whp, and I was going to do it for about $1000 in parts and labor. Hookups galore.
Easy way to high compression: use PM7 or P29 pistons in the Y8 block/head combo. That will get you to 12.6:1 using the proper head gasket combination. Good luck with tuning- the high domes on those pistons make it fun.
Old 03-28-2008, 12:09 AM   #8
The name's Sam
Yeah you guys talked me into going turbo.
Old 03-28-2008, 02:15 AM   #9
Honda Enthusiast
Luis998's Avatar
Ride:  '94 EG sedan w /Z6, '97 EK hatch
Rep Power: 103 Luis998 has a reputation beyond repute
Luis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond repute
Threads like this one make me re-think my D build and make me want to totally concentrate on my B build, period.
Max? There is no max. Max just means you gave up.
This is my thread: http://hondaswap.com/engine-building...g-wind-110848/
http://hondaswap.com/members-lounge/...thread-278554/
Originally Posted by LS_VTEC View Post
lol... you could say that doing it right will "get you bitches". ;x
Originally Posted by efhondakid View Post
"Im so JDM I sleep on the right side of the bed"
Luis998 is offline   Reply With Quote
Old 03-28-2008, 04:45 AM   #10
The name's Sam
I'll prove to you myself the d-series motors can be beasts
Old 03-28-2008, 04:48 AM   #11
Honda Enthusiast
Luis998's Avatar
I do not disagree with you at all. Personally though, I am going to concentrate on my B build for now and leave my D build, if it does materialize, for later. That is all. Best of luck to you.
Old 03-28-2008, 05:00 AM   #12
The name's Sam
Okay I was gonna say come on now the dirty d's have potential too. lol but yeah your b is gonna get up and go too.
Old 03-28-2008, 05:19 AM   #13
Honda Enthusiast
Luis998's Avatar
Believe me, I know they do. I just have to get my priorities straight and focus on one thing at a time. B's before D's for me.
Old 03-28-2008, 05:33 AM   #14
Reverend Awptickes
awptickes's Avatar
Ride:  1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
Rep Power: 184 awptickes has a reputation beyond repute
awptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond repute
 FaceBook
Blanco is the killer of D-Series N/A dreams.
Anyone notice that after Blanco chimes in, everyone with a D decides to go F/I?
☻/ DIY/Howto HID Projector retrofit
awptickes is online now   Reply With Quote
Old 03-28-2008, 05:38 AM   #15
Honda Enthusiast
Luis998's Avatar
Holy crap! I'm so tired that I just thought you said Blanco stands for "D-series dreams" in Chinese. WOW! I need SLEEP! Yes, it's time for bed now..
On a side note, ask yourself why that is. Perhaps because he makes SENSE? Then again, he is not against all motor one bit. He, along with others, just shed light on the reality side of making power all motor, which ends up costing more than a nicely boosted set up. That's all. Still, there is nothing wrong with naturally aspirated.
Old 03-28-2008, 06:35 AM   #16
Reverend Awptickes
awptickes's Avatar
 FaceBook
You're absolutely correct. The D-series is the 'commuter' engine. Not to mention that D's rule/run the world.
Building a D makes very little sense. People need to realize that. There's no cheap way to make a D put out more power, it's already at/close to its limits.
Oh well, some people never learn.
Old 03-28-2008, 09:46 AM   #17
Honda Enthusiast
Luis998's Avatar
Originally Posted by Blanco View Post
There's very little point in most all-motor Honda engines. If you want all-motor power, get a V8. Nothing like 330ft.lbs.@1600rpm.
The rumble of a V8 is a beautiful thing too. I remember when I almost bought a Trans Am GTA? I believe. The one with the digital dash and what have you. Anywho, at the time I had never been in or started up a V8 before. Lets just say that I almost jumped for joy when I heard that engine rumble. Still, I love my Hoinda's and with today's gas prices, am glad that I own them.
Old 03-28-2008, 10:06 AM   #18
dtob's Avatar
Vitara turbo setup is cheap but there is no cheap way to make a D put out a decent amount of NA power to warrant building it over swapping besides the novelty of having a D beat a B16.
Old 03-28-2008, 07:24 PM   #19
The name's Sam
yeah I looked more into it and it was just not even worth it. But yeah ironically I have an 80 trans am with the 305 that I want to turbo but I am not sure about the whole carbeurated turbo setup. Yeah I have heard turboed d's are pretty good for power. What do you guys think about a superchager on my motor?
Old 03-28-2008, 07:50 PM   #20
dtob's Avatar
Homemadeturbo.com
Old 03-28-2008, 09:02 PM   #21
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
Thats because its the cheaper alternative to all motor.
Unless you're shittin money and wanna do something somewhat unique, there really isnt a point.
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6-
Matts96HB is offline   Reply With Quote
Old 03-29-2008, 01:40 AM   #22
The name's Sam
well how much horse power could I reasonably push with a turbo setup on a built head and block? with the y8? I'm hoping arund 300ish hp wise.
Old 03-29-2008, 02:19 AM   #23
The name's Sam
alright sweet. do you know of anyone who has done an itb setup with a turbo? I wouldn't do that the tuning would be a bitch but I was just thinking it would be sick. What turbo would you suggest? is the turbonetics t3/t4 okay? I have had success with that on b-series motors but this is my first d-series build.
Old 03-29-2008, 10:10 AM   #24
Calesta's Avatar
Ride:  2003 S2000
As far as I'm concerned, going all-motor with any D or B is, as B puts it, the expensive way to still go slow.
Nah. There are TONS of good reasons to go all motor. But for what most people getting into Hondas want (drag, highway racing, street racing), turbo is the cheapest way to make usable power.
Old 03-29-2008, 10:22 AM   #25
dtob's Avatar
I loved the turbo z6 I had and it was VERY fast but my built NA b series is just different but still fast.
Either way you go you won't be dissapointed but if you want a drag car without spending a ton of cash the turbo d would be the way to go.
Oh and I'm pretty sure someone on Homemadeturbo.com made an itb turbo setup.
D16Y8 turbo build turbodhatch Engine Building 24 09-20-2009 03:25 PM
d16y8 DooMed070 HYBRID -> EG-EK / DC 6 11-09-2007 03:21 PM
D16y8 to D16y7 Downgrade Issues... NHBsi HYBRID -> EG-EK / DC 6 04-11-2007 10:03 PM
what boost to build for given a GT28R vector Forced Induction 6 12-11-2006 11:41 AM
FS: Everything d16y8 related drunkNun Parts: For Sale/Trade/Wanted 16 07-17-2006 05:40 PM
